Newbie Testing P Channel Mosfet
  • orientalsniper
    • Apr 2013
    • 461
    Hello all, I've read across different sites (badcaps included)
    To test a P-Channel mosfet, I have concluded the following:
    1) - plug to gate, + plug to source = open circuit reading
    2) + plug to drain, - plug to source = open circuit reading
    3) + plug to gate, - plug to source = open circuit reading
    4) + plug to gate, - plug to source = short circuit reading
    Now, the mosfet I'm testing is this
    I've performed the test to 3 same mosfet in a laptop motherboard and I've got different measurements, they are still soldered to the board, would that make any difference, or did I misunderstand the basic tests?
  • capkid
    • Oct 2010
    • 1339
    Re: Newbie Testing P Channel Mosfet
    I'd de-solder them if your results are inconclusive.
    LG Plasma Mal-Discharge Correction Service
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      Can't test these in circuit, there tends to be enough circuit stuff that will discharge the gate before you can make a good reading.
      To test a P-channel device basically you can do the exact same measurements as an N-channel, except swap the probes.
      In circuit there should still be no "shorts" unless the transistor is somehow on (which it shouldn't if it's not powerred up). If you see any shorts when testing in a dead circuit, likely that transistor is fried and something else killed it.
        master hoarder
        • May 2008
        • 12175
        Not true.
        The lower drive MOSFETs on CPU and GPU VRM may (and usually do) appear shorted. It all depends on the GPU and/or CPU, though. Some GPUs/CPUs have low internal resistance, others not so much. So just beware when checking those. You'll be troubleshooting a problem that is not there.
        • dj_ricoh
          • 2073
          • uk
          In circuit there should still be no "shorts".
          90% of all mosfet near cpu show short untill you take out the CPU
          • orientalsniper
            • Apr 2013
            • 461
            Thanks guys, so the general consensus is to desolder them and test out of circuit.
            Also can someone confirm the 4 steps test I'm doing is correct?
            • capkid
              • Oct 2010
              • 1339
              Here's how I test N-channel mosfets with my Fluke 87. P-Channels will be the opposite:
              (1) + Drain, - Source = Open
              (2) - Drain, + Source = Reading around 0.5V
              (3) + Drain, - Source then quickly touch + to Gate and back to Drain = Voltage climbs steadily as mosfet is charging
              (4) Touch Gate and Source simultaneously with your finger(s) while maintaining probes in position to discharge = Open
              (5) Repeat step 3: + Drain, - Source then quickly touch + to Gate and back to Drain = Voltage climbs steadily as mosfet is charging
              You can also build your own cheap mosfet testers (see attachments).
              • redwire
                • Dec 2010
                • 3912
                orientalsniper, I think your 4 steps are wrong.
                First, what do you consider a "short circuit"? For a proper test, I would use diode test on the multimeter and also ohms. Both give different and good information. Write down your readings.
                Second, the gate (on a good mosfet) will always read open circuit (your step 4 shows a problem) if the mosfet is out-of-circuit. Only N-ch mosfets used in car ignition modules have a zener diode connected D-G.
                Third, I have seen when testing a mosfet out of circuit, stray static electricity or multimeter can charge the gate, the mosfet turns on and testing says D-S leaky or shorted, when really the mosfet is just turned on. Shorting G-S ensures the mosfet is off for the D-S test.
                I do a multimeter test in-circuit and if I get suspicious readings, I pull it out and then test out-of-circuit.
                Most mosfets fail with a shorted D-S or G-S so I look for that first.
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8701
                  Ah that's true, it does depend on the circuit, the resistance is pretty low for the D-S junction for low voltage high current loads (I'm too used to the main switcher in on-line SMPS). In any case G-S/G-D should not be shorted even in circuit, and yes removing from circuit is needed for accurate measurement.
                  • orientalsniper
                    • Apr 2013
                    • 461
                    Haha, let me see if I get that.
                    Basic test for P channel mosfet (assuming N channel would be opposite):
                    -G +S = Open
                    -G +D = Open
                    -D +S = Open
                    If they are shorted, mosfet is gone gone.
                    • dj_ricoh
                      • 2073
                      • uk
                      -G +S = Open
                      -G +D = Open
                      -D +S = Open
                      but you have to test it in diode mode to and see the value.
                      • redwire
                        • Dec 2010
                        • 3912
                        I made this table, I think it might help, or add confusion...
                        • trebo
                          • 514
                          • Wales, UK
                          @redwire
                          thanks redwire
                          your post and table really help us to understand the testing method of the mosfet
                          can you just clarify for us, as to wether we short G-S (as in #8 post) or G-D (as in #12 post) to turn off the mosfet, or is it okay to use either method to turn of mosfet.???
                          and thanks to all who have contributed to this helpful thread
                          • dj8452000
                            How To Test a P-channel Trench Mosfet Using A Multimeter In Diode Mode
                            by dj8452000
                            I am new to electronics and I'm understanding most of what I'm reading but I have a mosfet on my board that I've identified as a P-channel Trench Mosfet. I haven't a clue how to test this and what I should expect to see with the multimeter probes. I am hoping someone with years more experience than myself can help me understand how to use a multimeter to read this. Please look at the drawing I have attached to this and can you try to explain to me what I should be doing with my multimeter in diode mode and what results I should expect from a good mosfet?...
                            02-18-2025, 08:28 AM
                          • tmaster21
                            Ideapad 100 NM-A841, P channel mosfet on laptop in.
                            by tmaster21
                            Hello guys. i'm having problems here with this lenovo 110 with board NM-A841 laptop. There is an P channel(pq302) and after it i start ,i have 19v but with time, it decreases or if i press "power on" switch or jumper j6 , it falls to 0 and back to 19v. There is no short and works good on battery, but won't charge or charge until the voltage drop like i explain after P mosfet.
                            Well i suspect that this mosfet is no good. if you look to skematic i have steady 19v on P2 but start to decrease on P3 like if the mosfet is dying . the gate of boot N an P mosfet are the same: is steady...
                            07-17-2023, 09:48 AM
                          • bendeg
                            Test circuit for curiosity : 2 x NE555 (astable + PWM) + n-mosfet + var 10k + pc fan
                            by bendeg
                            Hi reader,
                            I'm trying to control a pc fan speed by giving PWM to the gate of a n-mosfet.
                            1) generation of a clock with a 555 timer (~ 1,5 kHz, as seen in the datasheet, fig.12) (Vcc = 6V).
                            Output to TRIG of second timer (pin 2) + red led
                            2) generation of a PWM with a second 555 timer (as seen in the datasheet, fig.18), CONT (pin 5) modulated by a variable 10k resistor (Vcc)
                            3) Using output of second timer to "pulse" n-mosfet gate (MDP13N50) + yellow led
                            4) pc fan (12V, 0.18A) in series in drain-source of...
                            05-01-2023, 07:59 AM
                          • CDNBrewer
                            Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
                            by CDNBrewer
                            Hello Everyone,
                            I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
                            Symptoms:
                            • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
                            • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
                            • I swapped the Left and Right surround
                            08-05-2025, 09:29 PM
                          • phuzzyday
                            My horror movie continues.. "70X690E Power Supply- the Sequel - Attack of the Backlight circuit!"
                            by phuzzyday
                            This was my initial thread.. https://www.badcaps.net/forum/troubl...-m-at-wits-end
                            (All the Electrolytics are brand new.)
                            I started a new one, hope that's ok, because my question is different now! (Strangely enough, after I walked away for a few weeks, it stopped lighting up at all!!)
                            I am determined to fix this power supply because I have the skills to replace bad components, I just need to find out...
                            05-30-2025, 05:20 PM
