Help finding replacement resistor
  • Hoosier
    • Feb 2012
    • 14
    Need help finding a replacement resistor for fluke mutimeter 76 series.
    Top one in pic has burnt open. Bottom resistor value is 750 ohm.
    Here is the fluke description of the 2 resistors, both the same value.
    RES,CERM,750,+-2%,2W,100PPM,MELF
    Resistor length is approx. .370"(9.398mm)
    Resistor diameter is approx. .110"(2.794mm)
    Have have been searching but can't find anything close with measured length/diameter/rating. May have to call fluke tomorrow for part.
    Any help would be appreciated. Thanks
  • PeteS in CA
    • Aug 2005
    • 3580
    • USA, Unsure of Planet
    Re: Help finding replacement resistor
    It's .335"L x .126"D and +/-1%, but this might work.
    PeteS in CA
    • Hoosier
      • Feb 2012
      • 14
      Thanks PeteS for reply. I clicked on link & out of stock. Can't find in stock online. Not having much luck either trying to do a cross reference.
      • Elysarian
        • Mar 2013
        • 200
        • United Kingdom
        the important information in there (for further googling) is that the package size is 0309 & the resistor type is MELF (metal film) with a power rating of 2 watts, you could probably go tighter on the tolerance but I wouldn't go looser in a meter as you may well lose accuracy.
        • Hoosier
          • Feb 2012
          • 14
          Google is not being very friendly finding a replacement. Seems to be very few 750 ohm resistors, at least 2 watt, & 2% or less tolerance in the size/style I need.
          • PeteS in CA
            • Aug 2005
            • 3580
            Depending on available room, you might consider getting a 2W metal film through-hole part and forming its leads.
            RCD has a part worth looking for.
            PeteS in CA
              May work:
              http://www.digikey.com/product-detai...ECT-ND/3029241
              • Hoosier
                • Feb 2012
                • 14
                Originally posted by budm
                Thanks for the link. Resistor at link looks to be too narrow of length & too wide to sit on pads where old resistor is soldered onto.
                Called Fluke parts dept. today & resistor is no longer available from them. Search continues.
                • Hoosier
                  • Feb 2012
                  • 14
                  This looks like the best/closest match that I have found.
                  My inside pad is approx .210" apart at ends of resistor.
                  My pad length is approx. .180" long/.200" wide.
                  This resistor will only sit on/overlap pad approx. .025 on each pad. Think this will be a problem?
                  Working voltage is 200V. Not sure what original resistor is.
                  Anyone see any problem using this resistor? They are not cheap, $6.73 each.
                  They are 2.5 watt, haven't found them in 2 watt. These are low profile height.
                  My resistor pads for the 2 resistors are approx. .055" apart, Resistors mounted on pads now are .155" apart.
                  Hope my description isn't too complicated.
                  Here's a link to resistor:
                  http://www.digikey.com/product-detai...BCT-ND/2508191
                  Here's a link to better specs.
                  https://www.mouser.com/ds/2/427/php-73510.pdf
                  • Hoosier
                    • Feb 2012
                    • 14
                    Thanks to all who gave me suggestions for replacement resistor. I bought the resistor in link on my post above & meter works now. These are very compact 2.5 watt resistors. Resistance measured right on spec.
                    • retiredcaps
                      • Apr 2010
                      • 9271
                      Thanks for reporting back and good job on the repair. I hate threads that just suddenly end without any resolution.
                      --- begin sig file ---
                      --- end sig file ---
                      • jinu_j
                        by jinu_j
                        Hi
                        05-03-2025, 10:51 PM
                      • Tomylee
                        No LCD image after connector replacement – lifted components and damaged resistor (Nintendo Switch Lite HDH-CPU-02)
                        by Tomylee
                        Sorry for the person who’s going to read all this !
                        I'm on a Nintendo Switch Lite, motherboard HDH-CPU-02.
                        While replacing the left joystick, I had to remove the motherboard to access the connector underneath. When I lifted the LCD connector latch, it broke (the plastic had become brittle over time), so I replaced the entire connector.
                        During the desoldering of the LCD connector using hot air, three small components located just below the connector (likely 0402 capacitors) came off and remained stuck to the bottom of the...
                        07-11-2025, 11:52 AM
                      • mikey5791
                        Need help to replace burned resistor in 350w atx psu
                        by mikey5791
                        Hi to all forum members,
                        Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
                        The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
                        Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
                        Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
                        12-26-2024, 04:55 AM
                      • MidnightRoller
                        Can a resistor lose resistance after hot air?
                        by MidnightRoller
                        I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
                        I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
                        02-02-2022, 11:46 PM
                      • artvandalai
                        What resistor ohm will work better to repair this waterpik?
                        by artvandalai
                        The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
                        01-05-2025, 04:10 PM
