Crazy idea I just had
  • Tom41
    • Oct 2005
    • 336
    • England
    When summer comes round again, I would like my PCs to cool down quickly after shutting down. Thing is, the CPU and case fans cut off when the PSU goes into 'standby' mode after shutting down.
    I had an idea that I could wire a rechargeable battery or large capacitor in parallel with each fan, so that the fans remain spinning for a couple of minutes after shutting down - while still spinning as normal while the power is on.
    Is that something I could do easily with wires and solder, or would I need some kind of special circuit to detect the power on/off and switch power over? I am concerned about the power from the battery flowing back up into the PSU, powering the regulator backwards and causing all sorts of problems - would a diode help?
    You know there's something wrong when you open your PC and it has vented Rubycons...
  • arneson
    • Sep 2005
    • 1267
    Re: Crazy idea I just had
    Tom,
    Not a bad idea, I used to time delay relays with a large cap and an isolator diode.
    Your idea is simple and effective.
    Jim
    • gonzo0815
      • Feb 2006
      • 1600
      Ok, if you want a more sophisticall circuit, you can use the 5v SB line for aftercooling. IMHO there are some devices ready to buy, wich do thatbkind of aftercooling. AFAIR it wasn`t that expensive.
      For your initial idear, you should use one diode to protect the battery from the supply (to avoid that it would accidentaly be charged and blow up) and one diode into the + line of the fan to avoide that other things could source power from it. Then i guess you have to ad a switch or timer circuit to avoid a empty battery each time you power the system of.
      • willawake
        Super Modulator
        • Nov 2003
        • 8457
        • Greece
        http://www.ioss.com.tw/web/English/RD7%20CA.htm
        • arneson
          • Sep 2005
          • 1267
          My DVD R runs the fan for a full minute after shutdown and the front projectors keep the fan on the bulb going for at least a minute.
          I have to run the air conditioning to keep the living room cool while watching movies.
          Jim
          • willawake
            Super Modulator
            • Nov 2003
            • 8457
            • Greece
            i was on a yacht and in the wheelhouse there was a switch which was labelled "plasma fan" i asked what it was for and its because they have two saloons each with a plasma tv on either side of the same wall. so when both are watching tv have to switch on a fan in the wall
            • arneson
              • Sep 2005
              • 1267
              I could use a fan that comes on when I sit on toilet.
              It should pretty much stay on after that.
              Jim
              • willawake
                Super Modulator
                • Nov 2003
                • 8457
                • Greece
                we could use that for the office toilet.
                some of these playing something also for those monday morning beer shits
                • 999999999
                  • Sep 2006
                  • 774
                  I don't mean to be offensive but there is no reason to cool down an "off" system faster, no benefit to it. On different devices where there is a direct correlation between hours on at elevanted temp to lifespan, it would save some of that lifespan, but it is negligable on a PC/computer in any case, even that much less so to have it cooled for a couple mintues versus the substantially longer on-time.
                  Regardless, it might be prohibitively expensive to parallel enough massive capacitors to be able to run a fan for a couple minutes. Perhaps some surplus electronics websites have good deals on super capacitors and you could parallel enough of them to get the needed runtime, but it seems unnecessary when you already have a live 5VSB rail on an ATX system that you could tap instead.
                  If you had a fan in mind that could run reliably from 5V (5VSB PSU rail), you could tap into that rail and use a NE555 /similar timer IC to drive a transistor-switch, solid state or mechanical relay, etc, to run the fan for the required period then switch off.
                  You could use batteries, but I don't see a gain in doing so instead of off the 5VSB, since any typical brushless DC fan spec'd for typical 12V will use a pretty small amount of current at 5V, within the margin of what you'd expect to have still available on a 5VSB rail if the PSU is decent, and with a battery you have the other factors of what happens when the voltage drops too much, if the fan then goes into an instable mode or pulsating behavior for quite a long time, or otherwise needing to add a cutout circuit when the battery reaches too low a voltage else you'd be draining the batteries quite a bit which will be hard on them in the longer term. I mean that idealy it would seem this circuit should remain working without having to replace batteries for the life of the system and draining rechargables too low, perpetually won't be very good for them.
                  Considering the time to do any of these, it could be as worthwhile to just get that "Cooling After" product alreadylinked but as I mentioned above, there isn't any need to cool a PC after it has ceased to produce heat (but a minor level, lower than the passive radiation rate acceptible from 5VSB powered circuits).
                  • unimatrix93
                    TV backlight zener diode
                    by unimatrix93
                    Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
                    So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
                    Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
                    The led strips has 9 6V leds.
                    02-10-2025, 12:13 PM
                  • NicRac
                    monowheel repair,Is the diode the problem?
                    by NicRac
                    Hello everybody☺️ I am glad to be here and looking forward to a good discussion.
                    First of all, I am new here. Therefore I will shortly introduce myself.
                    I am Nico and currently I study Physics.
                    In my freetime I like to build and repair stuff. Especially big battery's.
                    A few years ago I got myself an electric unicycle, monowheel or however you call that.
                    The battery bms was broken so I replaced and resolder that. Nothing big.
                    I used this thing for some years and had a lot of fun. Unfortunately I used it last time in heavy rain. Usually everything...
                    07-26-2024, 06:13 AM
                  • dennis_elx33
                    NO BODY MARKING Diode
                    by dennis_elx33
                    Hello Everyone,
                    I have 1 diode on a circuit that I suspected to be faulty because the forward and reverse bias has a voltage drop reading.
                    While compared to the reading of another diode from the next channel it won't read at reverse bias.
                    Now the problem is; it does not have any body marking.
                    So I tried to sketch the diagram and found out that it is connected to the base and collector of the C3632 transistor.
                    What do you think is this diode?
                    Can you please suggest what part number can i use to replace this faulty diode instead?
                    Hoping that you...
                    06-14-2024, 12:36 AM
                  • eccerr0r
                    Electric lawnmower...purpose of diode...
                    by eccerr0r
                    I was looking at an old battery powered electric lawnmower I picked up as the previous owner didn't want to buy a new board to replace a ruined old board. Tried to study how it was designed - it appears it has a huge 80A contactor...or rather, a 80A relay. It appears to be SPDT to control the motor. A 30A relay protects the circuitry.
                    The weird thing I don't quite get is how this thing is connected. The common contact is connected to the motor. The NO contact is connected to the battery, which is expected, so when the relay is activated, the common is connected to the NO contact and...
                    08-27-2022, 12:54 PM
                    NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
                    I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
                    I bought this from an eBay seller but unfortunately they only had one
                    I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
                    I bought three of from them to also make battery packs with this output power limit in mind
                    I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
                    04-23-2025, 05:50 AM
