Charge 50cc scooter battery with 12v plug?
  • gilly1984
    • Jun 2012
    • 751
    Is it possible? Without blowing up.
    I have a 12v 3A adapter, can I use it to charge it up? Its a 12v battery.
    I have no kick start and battery has gone dead.
    Do NOT touch heatsinks when testing for voltages as they may be LIVE!
  • Elysarian
    • Mar 2013
    • 200
    Re: Charge 50cc scooter battery with 12v plug?
    Charging a 12v lead acid battery (especially a sealed one) at 12v is a bad idea as the battery won't fully charge and you'll likely not get enough terminal voltage to start the engine (as well as risking damage to the battery/PSU).
    you should be charging at around 13.8 to 14.2 volts for best results - a car battery charger will do this and also monitor the charge current for you.
    Is the scooter a manual or automatic geared one? (if it's manual you could try bump starting it and charging off the dynamo/alternator)
    • ben7
      Capaholic
      • Jan 2011
      • 4059
      You need a voltage source of at least 13.8 volts, preferrably current limited.
      End of charge voltage for 12v LA/SLA batteries is around 13.8 to 14.4 volts.
      Muh-soggy-knee
        During charge a battery may operate between 14.2 and 14.8V, with a -30mV/degC temperature coefficient. After charge current is stopped, it should drop down to around 13.2 to 13.8V within a few minutes; at this point, the battery is fully charged. Below 12.5V there is little usable energy, and the battery is considered flat.
        • gilly1984
          • Jun 2012
          • 751
          Its an automatic scooter. I'll just borroa a charger. Not got my CBT until Friday so plenty of time to get it started. Thanks guys.
          • techfreak9356
            Vostro 3400 (LA-K033P) won't charge battery, everything else ok
            by techfreak9356
            09-14-2023, 11:10 PM
          • razenxd
            How can I charge that battery pack?
            by razenxd
            it's not a laptop/desktop related question but I figured that someone here will have the right knowledge.
            At work we use a few Aldebaran(now Softbank/United Robotics group) Nao Robots which they use some custom 6S li-on battery packs.
            Nao robots tends to draw from the battery even if they are shut down, and the BMS tends to be a little aggresive, if the pack stays on a turned off robot for 3 months it's gonna lock and will refuse to charge.
            Now, I have noticed a few things.
            The "dead" battery, while connected to charger and NOT Charging will...
            12-05-2024, 06:11 AM
          • ruletero
            Acer a515-43 low battery charge voltage
            by ruletero
            Hi
            Acer A515-43
            LA-H801P
            Fail: Does not charge battery, has low voltaje on connector.
            Laptop didn't want to turn on, only charge led blinked.
            I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
            I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
            Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
            10-24-2022, 02:31 PM
          • Klevjetack
            Charge a L19D3PDA battery externally from the laptop
            by Klevjetack
            Is there a way to externally charge a L19D3PDA battery from the laptop. I have a broken charging port on my laptop and am trying to find a way to charge the battery for it. I have been doing some research and I have found that there is a module, TP4056, that can be used to charge Li-ion batteries. It says it is used to charge single cell Li-ion batteries. The L19D3PDA battery is a three cell battery. Is it possible to use the module to charge my battery and it would just be very slow? Or would that be a bad idea. Is there a different kind of module I can use to charge my Li-ion three cell battery?...
            03-05-2024, 07:26 AM
          • dclass-pro
            Latitude 3301 not charge battery
            by dclass-pro
            Hi guys I have this dell that with the battery charged it turns on correctly, but if I connect the charger I get the charging symbol but it doesn't charge the battery.
            I found the shorted charger PU4401 ISL9538h that had pins 14 and 15 shorted and I replaced it. but it still doesn't charge.
            I noticed 2 things:
            1) without the battery connected if I connect the power supply, on the SDA and SCL pins of the battery I have 0V I measured the resistance with ground and it is very high, if I connect the battery I have 3v on the 2 lines.
            2) if I try to turn it on without the battery...
            05-06-2025, 06:19 AM
