Arc gaps on circuit boards?
  • larrymoencurly
    • Oct 2004
    • 960
    On old circuit boards I'd regularly see traces with little pointy areas to act as arc gaps, usually at the AC input or where low voltage signals connected to the outside world. Why do I no longer see those arc gaps very much?
    Re: Arc gaps on circuit boards?
    I see them quite regularly on modern PCBs. It's a cheaper way of reducing the arc which occurs due to the line filters.
    • DaveB1972
      • 10
      Can you post a picture of what you mean? I cant figure out exactly what you guys are talking about.
      • Mad_Professor
        A Mech Warrior
        • Feb 2011
        • 1587
        Same here, I never even heard of an arc gap.
        • shovenose
          Send Doge Memes
          • Aug 2010
          • 6575
          I third that - no clue what's being discussed.
          • mariushm
            • May 2011
            • 3799
            See first picture in this page, circled in blue: http://www.eevblog.com/forum/beginne...s-about-a-pcb/
            Follow the posts below for explanations..
            As to why not seen anymore these days... i couldn't tell you a specific reason.
            • shovenose
              Send Doge Memes
              • Aug 2010
              • 6575
              Ah, now I get it. Maybe because power is much better these days?
              • larrymoencurly
                • Oct 2004
                • 960
                Here's what I mean, the little pointy areas on the copper traces, between the input and ground traces. The screw connectors are for the wall buttons of a 20-year-old Stanley garage door opener. I've seen similar pointy areas on the circuit board of a power supply from an original IBM PC, on the 120VAC side between ground and hot and between ground and neutral.
                • Mad_Professor
                  A Mech Warrior
                  • Feb 2011
                  • 1587
                  So what exactly is their purpose?
                  • larrymoencurly
                    • Oct 2004
                    • 960
                    Surge protection?
                    • redwire
                      • 3910
                      Usually I see them designed in for ESD protection. Some regulatory tests simulate human-body static electricity pulses i.e. 100pF+1k5 resistor at up to 25kV. In Canada static electricity is so bad in winter you can easily generate that.
                      Some instrumentation/RTU's where lightning can reach their inputs, will use spark gaps but their breakdown voltage is wishy washy and they etch away quickly, so not great for recurring spikes or big spikes.
                      The spark-gap is a free way to deal with a low-energy HV spike. I think a MOV works better but costs more.
                      • smason
                        • 1652
                        Yup, and here in Alberta in the winter a single cat and a wool carpet can power a small town.
                        • goontron
                          5000!
                          • Dec 2011
                          • 4108
                          • US
                          Originally posted by smason
                          yup, and here in alberta in the winter a single cat and a wool carpet can power a small town.
                          lol!
                          Follow the white rabbit.
                          • severach
                            • Aug 2007
                            • 1055
                            But the cats all go to sleep at the same time so you need idle base load power at the ready. The cost of free cat power + idle base load power is no less than the cost of running the base load all the time and letting the cats sleep the remaining hour.
                            sig files are for morons
                            • Uranium-235
                              Comrade Glimmer
                              • Aug 2007
                              • 5042
                              • US
                              could be tin whiskers. Might not see them much anymore cause of new mixtures of solder
                              • larrymoencurly
                                • Oct 2004
                                • 960
                                In the 1980s IBM PC PSU I saw the pinty areas were untinned copper, and the board in the picture is about 20 years old.
                                • mertsok
                                  • Jun 2013
                                  An excellent way to protect inputs of electronics components from the very high voltages of ESD and EMI spikes is to use spark gaps. These can be built into your circuit board as parts of the PC board etch.
                                  • redwire
                                    • 3910
                                    I don't find arc gaps that great... you'll still end up with a several kV spike which is too much for the components downstream.
                                    One trick I do is ESD gun the board in a dark room. You can see where the arc is, Murphy's law takes effect and the spark gap can do nothing but instead the arc happens on unexpected pcb traces.
                                    Example is a 0.5mm spark gap gives theoretical 3kV breakdown (with no soldermask). Okay, now that it's from 10kV to 3kV - then what? It can still hop across a resistor and take out the semi's.
                                    In the old days, spark gaps were on CRT sockets to stop arcing and corona from destroying the video amplifiers, later they used spark-gap capacitors.
                                    Nowadays, I think spark gaps are used only to pass IEC-61000 regulatory ESD tests.
                                    For lightning you have to use MOV's or gas-tube arrestors, because the spike has so much energy.
                                    • japlytic
                                      • Oct 2005
                                      • 2086
                                      I don't normally include printed arc gaps in circuit diagrams, unless they are in series with a component.
                                      • ugamazing
                                        by ugamazing
                                        12-17-2024, 07:05 PM
                                      • Alimash
                                        op amp circuit function?
                                        by Alimash
                                        I am repairing a ups which doesn't turn on ,it has the following ICs:
                                        SG3525 used to drive inverter mosfets.
                                        couple of uc3483, one for the power supply and another to drive a big mosfet at the output stage(i think the technique is called boost)
                                        A LM358 and TL074 for control mechanism and of course the uController.
                                        The SG3525 is shutting down every time the ups is turned on.
                                        I want your help to know the function of LM358 and TL074 in the system.
                                        I reverse engineered the LM358 circuit and i think that one of the block(A) is used for battery level...
                                        07-31-2025, 07:45 AM
                                      • VitalComputing
                                        Taking Pictures Of Large Circuit Boards
                                        by VitalComputing
                                        Hi friends,
                                        I am trying to take good quality pictures of rather large desktop motherboards for a project I'm working on. I had a brilliant idea of scanning them with a flatbed scanner I have but it only focuses on the bits of the board that are flush to the scanning glass. And the through hole components tend to lift the main board from the scanning glass. Everything else just looks out of focus. So it seems that that option wont run.
                                        I have been capturing the images with my iPhone 11 and it's okay but wont capture the whole board. I have to grab it in sections and...
                                        11-22-2022, 04:15 PM
                                      • Astonished
                                        Fixing the Charge Circuit of the Batteries of the DC Motor
                                        by Astonished
                                        Hi friends of electronics
                                        What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
                                        The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
                                        Please help me fix this circuit.
                                        (the datasheet of the IC: https://pdf.datasheet.live/28...
                                        01-28-2025, 06:24 AM
                                      • rddube
                                        Lenovo L490 Ram voltage circuit malfunction
                                        by rddube
                                        Hello friends,
                                        Looking for some guidance here. The RAM voltage circuit on this motherboard keeps burning out PU301 which is a RT8231AGQW. Copy of the board with the burnt chip attached with some voltage measurements and copy of the schematics also included.
                                        I think I've checked almost every component in the circuit, but when I change the RT8231, the laptop starts I have 1.2V on the inductor for about 10 seconds and then the RT8231 goes south and no more voltage on the inductor. All other voltages on the laptop are good, this is the only one conking out for a reason I...
                                        07-15-2025, 04:41 PM
