Hello folks.
I have a few devices around that are powered by battery packs salvaged from laptop batteries.
First one is a cordless drill, powered by some 3 flat li-ion batteries (connected in series), as it did not have any original battery. Works well, they give little over 12V, while the original was rated at 14.4V, but it just works, whatever. The controller for the battery was discarded long time ago.
Another device is self built small ventilation system in my appartment (a fan, 2 switches and few components for a timer) that are powered by 4.4Ah battery pack. It is laptop batteries
two of them are connected in paralel X 3 and then all 3 packs are connected in series.
I am charging both devices by adjustable ATX, but i have to check the temps constantly, as well as current and voltage (it has to be adjusted every 10 minutes)..
I want to build an IC based charger circuit that would control pre-charge, constant current and constant voltage itself. Most of those chips are rated at 4.2V (for charging one battery at a time or more of them in parallel - just multiply the current by number of batteries).
I know that laptop controllers have connections between the cells, but does it mean that they can use 4.2V controller? Not sure.
The problem is that i am not able to find suitable IC for that. Most of them are rated at 4.2V, the ones that are able of charging in higher voltage are too complicated for me, they have a shitload of pins and adjustments), and again they are rated either for 12V or for 14.4V. My pack has a charging voltage of 3 x 4.2V = 12.6V. Then again most of them are smd components that I do not like soldering. Aren't there any 12.6V old school 8, 14 or so pin chips that would work for amateur like me?
