Acronym U: what for?
  • Behemot
    • 4845
    • CZ
    As the title says, got SMD components marked as, say, U12, U23 and so. What is that?
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: Acronym U: what for?
    Moved out of FAQ. Seriously, you have 1000+ posts... you should know better...
    Parts marked with a U are usually ICs... Sometimes it can include transistors too (but they usually are marked with a Q). Beyond that, you'd have to look at the chip itself or a service manual schematic.
    sigpic
    (Insert witty quote here)
    • kikkoman
      • Jul 2007
      • 691
      On the silkscreen or on the parts themselves?
      If on the silkscreen, it usually means it's some sort of IC (anything up from a simple voltage regulator, so anything that's not a discrete part.).
      If on the parts, that is much trickier. What's the footprint and silkscreen marking?
      "Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats." - H.L. Mencken
      • martin114
        • Feb 2013
        This might help...
        SMD Codes U1, U1**, U12, U13, U16, U17
        http://www.s-manuals.com/smd/u1
        http://www.s-manuals.com/smd/u2
        Cheers,
        Martin.
        • Behemot
          • 4845
          • CZ
          Here it is. Supposedly the lady owner somehow managed to push the plastic crap inside the USB onto the board and tear off couple SMD components. But it seems the U, whatever it is, was not even present before?
          ratdude747: I am not sure whether I'll ever understand the schematics of this part of the forums
            Are you talking about IC U25 the 8-pin IC?
            • Behemot
              • 4845
              • CZ
              Nope, U39, there is SMD cap and inductor teared off. Eh, do you think it's the big GST5009 chip? Don't I see a forest because of the trees?
              • kc8adu
                • Nov 2003
                • 8832
                • U.S.A!
                l58=l66
                c740=c821
                just look off the port to the left.
                • Behemot
                  • 4845
                  • CZ
                  Yeah for sure, I haven't been initially sure about what's the U39, but now I see it clearly that the positions I though were for two components are actually for the single inductor, and U39 is most likely the big chip.
                    C740/C821 are more likely the filter caps for the +5V for pin 1 of the USB.
                    The two small traces (connected to the Diff-mode inductor) are more likely to be for the + and - pins of the USB.
                    You can test out the connections of the USB pins to those missing components. You can also put the jumper on the missing Inductor (for noise filter?) to test out if the USB port will function.
                    • redwire
                      • 3910
                      Since there's two USB ports, I see that L66 is the same as L58 (which is busted off) a common-mode (dual, 4-pads) choke. C740 is also busted off but the same as C821 for EMI on the USB connector shield.
                      In a pinch, I would just jumper the two USB data traces on L58 and that should get the port working at least. C740 is usually 10nF and not that important because it's EMI related.
                      U39 on the silkscreen refers to the part below it, the GST5009 Ethernet transformer.
                      • redwire
                        • 3910
                        Second look and C740 as Budm says, might be for 5V power (like 10-100uF) but it's weird the cap is mirror-image position to C821.
                        • lti
                          • May 2011
                          • 2551
                          It looks like there is a tiny cap above C740 that has also been removed.
                            That is more likely to be .01UF cap in parallel with the larger value missing cap (10uf or more as redwire suggested).
                            By the way, typo on my part, it is common mode choke for common mode noise rejection as redwire had indicated. Just bypass it for now.
                            • Behemot
                              • 4845
                              • CZ
                              I may actually have few of the missing componens.as for the inductor, I guess two in parallel may do the trick? If I won't find any, than I'll just use some wire
                                The inductor windings are not connected in parallel, the windings are on the same core. just look up commomn mode choke to see how it's done, I would just bypass it for now to test, if the USB cable is short and not close to electrical noise then you mat get by without it.
                                • Behemot
                                  • 4845
                                  • CZ
                                  Ah yeah, common mode, I see. Two differential will have to do
                                  • Mark D
                                    Samsung UN65JU67ODFXZA Version TD01 Schematic and Parts List
                                    by Mark D
                                    The TV is a Samsung UN65JU67ODFXZA Version TD01. I replaced the power source board and the TV is now working, but I decided to try and troubleshoot the old board to fix at the component level. Trying to get a schematic and a parts list has proven to be an issue. Trying on my own, I can't tell you how many times my Norton security has flagged sites as "malicious". I ordered a service manual from ServiceManuals.net, paid $16.99 and got 66 pages of everything BUT schematics and component parts list! Can anyone steer me in the right direction? Some of the surface mounted component parts...
                                    10-29-2024, 03:15 PM
                                  • Yanleb
                                    Samsung UN58TU7000F no picture
                                    by Yanleb
                                    I have a Samsung UN58TU7000FXZC (same as UN58TU7000FXZA, just the Canadian model) with no picture. Backlight is on and sound is coming out just fine. Just no picture.
                                    What is frustrating is that there's no voltage test point and no component labelling of any kind.
                                    What I have found so far:
                                    1. No voltage at pins 91-94 of the 96 pins connector CN1300 (marked 1 on the picture). This TV set has no T-CON board. The 96 pin flex cable goes directly to the right (when facing TV) lower panel board. Itself is linked with another flex to the other side.
                                    2. Voltage...
                                    01-19-2023, 01:44 AM
                                  • 2elw
                                    SVOD4 PCB pictures + parts
                                    by 2elw
                                    Hey, I find it very absurd that the SVOD4 costs so much and has zero documentation. I had no other choice than to buy it to unlock ECs, if there was any documentation or firmware avalible I could've made it or something simmilar. Anyways here are some of the most important parts:
                                    STM32H723VGT6 MCU - It's a microcontroller by STMicroelectronics and its the whole brain of the SVOD4. It has flash memory for the firmware which can be updated by the SVOD4 program. Its also powered by the AMS117 which converts 5v into 3.3V. 7€ on AliExpress.
                                    GW1N-UV9UG169C6/I5 FPGA - Its a...
                                    07-04-2025, 12:23 PM
                                  • Maniackk
                                    Reader PocketBook InkPad 3 – identification of a black component marked 'CT' on the microUSB line
                                    by Maniackk
                                    Device: PocketBook InkPad 3
                                    Mainboard: XRZ_E091_PB740-VTTOA-V1.1 / 2017-10-12
                                    I'm replacing the broken microUSB connector on this e-reader, and during inspection after desoldering, I noticed a loose black SMD component marked "CT". One of them was torn off along with the pad, while the other one (marked in the photo) is still in place.
                                    I would appreciate help identifying this component.
                                    Measuring the loose component with a multimeter gives 5.84 MΩ in both directions, while the one still on the board shows no measurable...
                                    05-16-2025, 08:53 AM
                                  • SurrealMustard
                                    What parts can be salvaged from a plasma with a damaged display panel?
                                    by SurrealMustard
                                    I recently found myself the proud owner of a later-model Samsung plasma (the PN59D7000 for those keeping score at home) whose panel was, unfortunately, damaged in transport. I'm now preparing to part it out, but am curious as to whether or not any damage would have come to any of the components by attempting to power it up with the panel being broken. I read in one Avsforum thread (for whatever that's worth 😂) that the "scan driver boards" (by which I assume he means buffer boards) could be impacted by doing so. Is that actually the case? If so, since I don't intend on selling bad...
                                    03-09-2025, 08:29 PM
