where to find soldering services?
  • Logistics
    • Apr 2007
    • 721
    I was thinking of goofing with some pieces of hardware I have; replacing some of the memory ic's with upgraded ones, but they are SOJ, and I don't trust myself to try this. Any idea where I can go to have the work done? Even online?
    I'm in San Jose, CA btw.
  • Anndy
    • Aug 2012
    • 10
    Re: where to find soldering services?
    Well, any electronic repair shop should have electronics techs who would
    know how to do such a thing. Other than that, some electronic stores also
    offer such services (and just to be clear, by electronic stores I'm referring to stores who sell equipment for working with electronics, as in soldering irons, capacitors, resistors and the like)
    • twbranch
      Mad Nerd
      • Oct 2012
      • 153
      PM you can send them to me! I live in NC though!
        by Vesko356
        08-11-2023, 03:27 AM
      • Ady2017
        SMD fuse soldering advice please
        by Ady2017
        Hi all. I need to replace an SMD fuse on my camcorder and this is the first time I have had to do any SMD soldering so your advice would be appreciated. Below is a picture of the board that I am working on and I have highlighted the fuse that needs to be replaced. I managed to zoom in to take this picture but the fuse is really tiny and is sandwiched between other components so this is going to be a new milestone for me. I appreciate that I am going to have to buy a new soldering iron if you could advice on what I need please. I was thinking about putting a big soldering iron across the whole...
        11-07-2025, 12:03 PM
      • danielgerman681
        ENCONTRAR DATOS DMI EN EL CHIP BIOS IDEAPAD5 15ITL05 / FIND DMI DATA ON IDEAPAD5 15ITL05 BIOS CHIP
        by danielgerman681
        Hi, Im trying to find the area on the chip that contains all of my laptops information, but I havent found it. The laptop won't turn on anymore. I was updating the BIOS, and it was supposed to reboot itself, but it wouldnt turn back on. I ve tried every possible solution, every alternative on Lenovo forums, everywhere; I ve taken it to technicians, and no one has been able to fix it. I've already read the chip that contains the BIOS (Winbond 25Q128JSVQ) and searched for my laptops data, but they're nowhere to be found. I only find scribbles and lines of text indicating errors. Has anyone had a...
        08-27-2025, 01:17 PM
      • corrize
        Where to find a very small fpc connector 0.3mm between 2 pins ?
        by corrize
        Hello, I search this connector (oxydated).
        It's a fpc zif low profile connector. It come from camera sensor, it is very small : 0.3mm between 2 pins.
        I ordered 2 from Aliexpress called « 0.3mm pitch » but one was 0.5mm between 2 pins and the other 0.6mm. In fact « 0.3mm pitch » seams to be the pad width and not the distance between 2 pins.
        I can't find it. The other websites like mouser dont show the datasheet, and I can't check if it is 0.3mm between 2 pins ?
        Do you know how to find this connector please ? What is the exact name for find it ?
        08-06-2024, 05:25 PM
        Where can I find a DD3 128000 type memory but 32 MGB in one module because this laptop has only one slot
        This Dell computer is a pain in the a** because of it only has one memory slot this computer only had 4 megabytes of memory and slower than shit I found a 8 megabyte memory module and it is better but still slow as shit the maximum is 32 megabytes of RAM but I was not able to find one I found some that are 16 megabytes but they are 1600/128000 type and I am not sure if this computer will work with this type of memory or not
        Dose anyone knows where I can find a 32 megabytes memory module for this computer because the battery still works fairly well still I would like to use it on my...
        07-07-2024, 02:34 PM
