part id help
+ More Options
Posts
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    part id help
    hi i am looking at a faulty rope light it has ac going in dc coming out of the power lead the only component in the round plastic housing is a small bridge rectifier part number HY RU 3KBP10 need help with a replacement part is very small about 3/4 inch long and half inch high any help on a replacement part cheers
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: part id help
    this is the datasheet
    Cant find any 3A locally nearest I can spot is 4A but it is quite a bit bigger
    http://uk.farnell.com/taiwan-semicon...00v/dp/4084802
    • vinceroger69
      • Mar 2012
      • 6714
      • uk
      Re: part id help
      cheers selldoor there my mates rope lights basically the lights consist of 10 meter white constant on led rope lights this bridge rectifier was enclosed in like a torpedo shape molded plastic block (had to cut it open to get inside ) then found this part and only this part so this has 240 volts in then it goes through the bridge converts to dc volts out? then goes to the rope light run. so could i run this of a adaptor like a old laptop one? how can i work out what the output of that rectifier is? and is it 3 amps.cheers vince
      • selldoor
        Slow Learner
        • Dec 2010
        • 7870
        Re: part id help
        No- if and only if that is the only component between the mains and the light string then it will be output 230 * 1.41 approx 325VDC.
        If size is not a restriction so others are available
        http://cpc.farnell.com/taiwan-semico...00v/dp/SC09280
        78p - currently free postage and packing
        • vinceroger69
          • Mar 2012
          • 6714
          • uk
          Re: part id help
          cheers for that i will enclose it in a project box or something i need to make a capacitor order up so will use the link for that as well cheers any idea how long the free postage handling offer is on for?
          • selldoor
            Slow Learner
            • Dec 2010
            • 7870
            Re: part id help
            I dont think it says but it has been running for a few weeks now.- best get in quick Its normally only free for over £45.
            Doesnt affect me as I live nearby.
            • vinceroger69
              • Mar 2012
              • 6714
              • uk
              Re: part id help
              hi guys just got a gbu407 rectifier can someone confirm the correct wiring for me as in which pin is ac live and neutral and which pins are the dc live and neutral data sheet here thanks vince
              https://cdn.badcaps-static.com/pdfs/...183dcf2f61.pdf
              • selldoor
                Slow Learner
                • Dec 2010
                • 7870
                Re: part id help
                Wow thats the big one! 1000v.
                Anyway the picture and the diagram of the part on the datasheet shows the pin designation and it is probably on the part itself..
                Centre Pins are AC doesnt matter which is which and the DC + is at the end with the slope.
                • vinceroger69
                  • Mar 2012
                  • 6714
                  • uk
                  Re: part id help
                  cheers selldoor did not realize it was 1000 volts should still work ok ? as its only 240v ac in.
                  is the 1000 volts max voltage it will Handel? just got to figure out which is live and neutral on the actual rope light now somehow.
                  • selldoor
                    Slow Learner
                    • Dec 2010
                    • 7870
                    Re: part id help
                    Hi - Yes I think it will be ok -that is the max v.
                    I am guessing the bulbs are not leds and if they are tiny grain of rice bulbs
                    are they 150 bulbs at 1.5v so supply 225v would be good.
                    If that is the case and they are 1.5v filament bulbs I dont think it will matter
                    which is live and which is negative, BUT I dont KNOW for certain.
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      • uk
                      Re: part id help
                      203 white leds about 2 or 3 mm each led so do you think this will work? like this they dont flash or any thing just plug in turn on.
                      http://www.ebay.co.uk/itm/12m-LED-Ro...-/360771459287
                      • selldoor
                        Slow Learner
                        • Dec 2010
                        • 7870
                        Re: part id help
                        Obviously it should work - you have just changed the bridge. BUT if they are leds then I think it does matter which is pos and neg. So you need to wait until someone who knows
                        chimes in. Did the bridge you took out have any markings - did you take a pic of it in situ.
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          • uk
                          Re: part id help
                          no it was broke in bits after removing it it was in like a torpedo of molded plastic ie have mains plug then wire then this torpedo molding with the small bridge rectifier part number HY RU 3KBP10 molded in side then a length of wire onto the rope light on the out side of the torpedo molding plug end stamped ac rope light end stamped dc if makes sence.
                            Re: part id help
                            Please post the pictures. White LED has forward voltage between 3~3.6V so the configuration of your LED rope must be LED strings connected in parallel.
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              • uk
                              Re: part id help
                              bud will try posting pics but they are sealed in like a clear/glitter hosepipe so i dont think a pic will pick up each led i have just looked really closely yes they are in parallel and every ninth on has a resistor.
                                Re: part id help
                                If you can count the quantity of the LED on each string, then you can figure out how much voltage it will need to forward bias all the LED in the string + the current limiter resistor.
                                • Steph.hen
                                  Bridge rectifier identification part number KPB305G
                                  by Steph.hen
                                  Hi all, a newby question about a bridge rectifier I'm trying to identify.
                                  I'm in the midst of reparing a battery charger in work which went pop, The bridge rectifier has shorted and took out a couple of other components. The rectifier in question has a part number KPB305G, and it looks like it's obsolete. Does any one know what I could replace it with?...
                                  08-29-2024, 09:52 AM
                                • mpn78
                                  Fujitsu Q556, What capacitor for bridge rectifier?
                                  by mpn78
                                  Hello
                                  My Fujitsu Esprimo Q556 motherboards blew up. At least fuse, bridge rectifier and capacitor got damaged. I have changed fuse and bridge rectifier (DF1508S), but I don't know what capacitor it is (picture). I know that capacitors size is 47nF, but I don't know other specs for it. Can you help me to choose right capacitor for my motherboard?
                                  There is 240V AC on input side of bridge rectifier and 340V DC as output on capasitors side.
                                  Thanks....
                                  04-05-2022, 12:31 PM
                                • edugimeno
                                  Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
                                  by edugimeno
                                  Hi There!
                                  I'm trying to help my friend who owns a restaurant be just bought.
                                  He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
                                  It's stuck using, I guess, the 2 sided tape that comes with the strip
                                  The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
                                  09-05-2024, 09:34 AM
                                • G-Sting
                                  iPad Pro A1876 SHORT Part Identify Help Needed
                                  by G-Sting
                                  So My iPad was not charging and booting up . i went to a local technician and he checked with thermal and this Part marked in 1st Photo is Short.
                                  So then i went on to boardview and downloaded the schematics and identified this part in 2nd Photo. Now i am confused what exactly is the part called ? where should i get this from ?
                                  i contacted my technician and he sent me his BoardVIew screenshot in 3rd Photo. In his Boardview the part is called X2826.... Something
                                  SO My main concern is what part should i order what should i search the name for ?
                                  on Ipad...
                                  05-15-2025, 09:30 AM
                                • EasyGoing1
                                  Reading input and output of bridge rectifier on the same scope?
                                  by EasyGoing1
                                  I have a 40 volt AC transformer that I put a bridge rectifier on, and I wanted to see the input signal and the output signal on the same screen on my scope, so I set one channel up with the test lead on one side of the input and the ground lead on the other side of the input, then I used another channel on the scope and clipped the test lead on the positive side of the output then the ground on the negative side of the output.
                                  When I connected the transformer to power, the wire that was connected between the ground lead on the second channel and the negative side of the bridge rectifier...
                                  06-26-2022, 12:52 AM
