trying to identify this tcon/tab connector
  • tvtech101
    • Sep 2012
    • 3
    http://farm9.staticflickr.com/8116/8...1cd3a92d_c.jpg
    any idea on what it is known as and where they can be purchased ?
    the cable that goes into it is marked as
    YS0915 002065
    thanks in advance
    Mark
  • selldoor
    Slow Learner
    • 7870
    Re: trying to identify this tcon/tab connector
    I am pretty sure if you look it will have a board number on
    Post a picture of the whole board - looks like a tcon but he picture is of such a small part of it could be a few things Also if you say what it is off make and model number
    usually helps
    • tvtech101
      • Sep 2012
      • 3
      Hi thanks for the reply, what I am looking for is the name of the connector ie Molex, IDC, they are on nearly every tcon if not all tcon boards I have seen, my problem is I have a corroded one and a burnt one from a 40 inch Samsung panel that has the following tcon FHD60C4LV1.1 the panel has the same connectors as the tcon...... quick update, just found out its called FPC, now to source some lol
      • selldoor
        Slow Learner
        • 7870
        Hi - does it have 68 contacts- I keep miscounting.
        Any makers clues here is a Hirose -one look for the HRS logo
        • reformatt
          LCD Connector identify or source
          by reformatt
          Trying to identify where to source the LCD connectors on the motherboard side for a HP 14-cf2051la. This one came in with liquid damage to the connector and the flex cable. It appeared to clean up ok, however customer says that display blanks out intermittently. It's a 30 pin EDP flat ribbon cable on motherboard side. Believe it to be a HEDWIG-6050A3155301-MB-A01 motherboard.
          I've stolen the connector from another HP motherboard which matches up but it's not the best since it's been kicking around my donor pile for a while. This connector is different to most flip type ones I have...
          03-25-2024, 08:29 PM
        • kca
          by kca
          Hello all ~
          08-31-2025, 06:38 AM
        • Tomylee
          No LCD image after connector replacement – lifted components and damaged resistor (Nintendo Switch Lite HDH-CPU-02)
          by Tomylee
          Sorry for the person who’s going to read all this !
          I'm on a Nintendo Switch Lite, motherboard HDH-CPU-02.
          While replacing the left joystick, I had to remove the motherboard to access the connector underneath. When I lifted the LCD connector latch, it broke (the plastic had become brittle over time), so I replaced the entire connector.
          During the desoldering of the LCD connector using hot air, three small components located just below the connector (likely 0402 capacitors) came off and remained stuck to the bottom of the...
          07-11-2025, 11:52 AM
        • k-krzych
          Identify board to board connector
          by k-krzych
          Hello, can you help me with an id of this board to board connector, or the the tiny silicon flat wires for replacement? It is found on GPS unit and connects main board with pushbotton small board....
          07-08-2025, 12:32 PM
        • x_orange90_x
          TCL 50S535 bad tcon or panel issue?
          by x_orange90_x
          Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
          03-29-2025, 11:02 PM
