Building an ESR meter, some help and someone to check my PCB layout
Re: Building an ESR meter, some help and someone to check my PCB layout
I think your layout looks good, just, don't trust me, I overlook things sometimes
BTW, what are the dimensions of the board? It looks a little cramped. What are the maximum allowable dimensions of the board for your meter? I can also give a go at designing a board layout too.Muh-soggy-kneeComment
Hmmm..
Some notes:
You leave a lot of empty space under the 7805 regulator. As you only draw a few mA, it won't heat up that much even with 9v input, so you could move the resistors under it. It's unlikely they'll heat from the 7805 enough to change their resistance significantly.
Otherwise, those resistors seem like ideal to be replaced with a bussed resistor array:
http://www.digikey.com/product-detai...1LF-ND/1089000
It's cheap (not including the shipping from Digikey) and saves you board space, it's SIP, it's spaced at 0.1" (2.54mm) so they can go almost parallel near the 16pin DIP.
Moving the resistors towards the top may allow you to turn the 16pin dip chip 90 degrees taking advantage of the empty space under LSP2 hole.
The new space you have above the R17 and C6 would give you some room to distance those pads a bit so that you'd have room for solder mask and to have nice round copper pads for each hole, without two holes getting their round surface mixed together.Comment
Using SMD would help with the space too, it isn't THAT hard to solder 1206 resistors, that is the size that I use.
Edit-0: A better chip would be the 74HC7540. It is an octal inverting schmitt-trigger buffer chip; the inputs are on one side, and the outputs are on the other. Together with marishum's idea of a SIP resistor pack, you can save a decent amount of space! I think you could use the two extra inverting-schmitt buffers in the circuit without any decrease in performance also.
Edit-1: If you go with the chip above, then you can use this resistor array. (It is from mouser though, I am sure that there will be something similar on Digikey too)
Edit-2: You could also use an LM78L05 (5v 100mA) regulator, instead of the large LM7805 one.Muh-soggy-kneeComment
I have thought about using SMD because I would like to practice soldering them. I am going by a previous design and using what is available to me atm because I am trying to fix a Magnavox 50MF231D/37 that has problems. I plan on going through the board cap by cap and an ESR meter would save me considerable time and offer an alternative to just pulling and measuring capacitance or testing for short.
I did see mini 74HC14M in this surplus store and do have a local distributor for SMD components so I may opt for being able to put it in a smaller case at a later time. As for right now, the meter and the box will fit this with a little room to spare fitting it sideways on one end leaving room for the 9v and the back of the meter.
I have been trying to print out the board on my printer but unless I print black and white, I can not print without resizing the image. Which is driving me crazy. So I have changed it to a png and edited it. Going to try to resize it after lunch and see if I can get it. Having a solid black and white image will mean more toner on the transparency, which means better masking. Sure would be nice if my vinyl cutter was not ruined from being in storage. that would be the easiest method. As soon as I get the board etched I will post some pics of my progress.Comment
Oops, post # 18, that R11 should be 3K3 = 3300 ohms = 3.3K ........Comment
Hi as I said in my previous email ,made some component changes to get more gain out of the amplifier .
Also added a small 14volt bulb in series with the output of the Ic so help to cure the drifting problem, pinched this idea from the first instrument HP made the 200.
Barry WilkinsComment
Does the lightbulb really work? I can see how it might compensate for temp differences, but does it really make any significant change?Hi as I said in my previous email ,made some component changes to get more gain out of the amplifier .
Barry Wilkins
Also, did you mean post, not email?
My computer actually just died, so I can't post any schematics or pcb layouts (I am typing this from my kindle fire)Muh-soggy-kneeComment
by chth96I read EBOOK of Testing Electronic Component and found that
"In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
Is it really possible to test small ceramic disc capacitor with analogue...-
Channel: General Capacitor Questions & Issues
by sam_sam_samI have had with regular AA batteries that leak this meter is expensive new I already replaced the battery battery clips once and the same thing happened again and I am tried of so it is getting modified to accommodate lithium ion batteries that are the same size excluding the positive terminal and removing the battery clips I will have enough room for the BMS protection board
I going to put 3 lithium ion battery in parallel with the BMS protection board and a way to charge the battery externally and heat shrink the battery pack and use a JST connector so I easily remove the battery... -
by jorpecHi
I want to change the scale of an analog meter, to monitor the charge of an li-ion single cell, so the needle at the end would point 4.2 volts and the 0 on the meter would point 2.5 volts or so, i tried to add diodes or a zener in series with the meter but the changes of the ambient temperature also changes the voltage value on the meter
I wonder how i can accomplish this so the meter would be precise at any temperature ?
Thnaks -
by sam_sam_samAbout a month ago we had a transformer jumper wire that burned in two different places between two transformers caused over $200 thousand dollars worth of damage to VFD drives at least 10 of them and a memory card and quite a few power supply as well
Now we have most of the equipment that got damaged back up and running except a feeder that has issues and we are waiting for some parts for
Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the āEā stops and one switching power (24 volt) supply and a transformer... -
by ksysaGood day, everyone! Can anyone please share a board layout (complete with components, test points, etc.) of iPad Pro 10.5 (Model : A1709)? There is already a schematic diagram of iPad Pro 10.5 here but somehow it lacks the complete board layout. I need to know where the specific Test Points (TP) are on the motherboard. I hope someone can help me.
Channel: Schematics and Boardviews
07-16-2025, 02:36 AM -
- Loading...
