need a roll of desoldering braid..
  • Mad_Professor
    A Mech Warrior
    • Feb 2011
    • 1587
    I'm running out. I need a new roll of desoldering braid. The braid I have is made by soder-wick with rosin size #2 50-2-25. It does alright, takes a bit of effort to get the solder on to the braid, I was wondering if there are any better ones that can attract solder better.
    Or maybe I'm doing something wrong, anyways I was wondering what you guys use or have any tips for me?
  • mariushm
    • May 2011
    • 3799
    Re: need a roll of desoldering braid..
    I usually add a drop of liquid flux on the braid on both sides or on the side that's going to be in contact with the stuff i want to desolder.
    Then I put some solder on the solder iron tip and put the solder tip in contact with the braid on the side that's not in contact with the soldered stuff.
    The bit of solder on the tip and the flux help transfer heat better from the tip to the wick, and the flux helps with the oxides on the soldered stuff.
    As for specific solder wicks, I get whatever's cheapest, I don't use it often enough to buy in volume.
      I say avoid the stuff on dealxtreme. It's usually fluxless. I've used nice thick wick before (7mm or so) and don't want to go back - costs a bit more, but it's excellent for getting bigger semis off a board.
      • pfrcom
        Oldbie
        • Jun 2006
        • 1230
        +1
        Especially the stuff they sell branded Goot - it must be counterfeit, doesn't work like the last of my (presumably genuine) Goot bought from local supplier Jaycar
        better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
          Originally posted by pfrcom
          +1
          That was the last stuff I bought, didn't work. So, yeah, I'm avoiding it in future.
          • severach
            • Aug 2007
            • 1055
            Solder on the iron won't do anything. The braid immediately strips all solder off the iron. Flux on the braid is what makes it work. Braid is nice but I've fluxed wire cut from bad power supplies as DIY braid.
            sig files are for morons
            • Mad_Professor
              A Mech Warrior
              • Feb 2011
              • 1587
              any purpose to no clean or rosin activated?
              • mockingbird
                • Dec 2008
                • 5484
                Avoid this wick from China:
                Bought a roll for next to nothing... It is fluxed, but the copper strands are packed too tightly and flattened. The stuff won't absorb anything.
                Rosin Activated or Rosin Mildly Activated flux is stronger than no clean flux but they need to be cleaned off afterwards. It's up to you.
                • LDSisHere
                  • May 2012
                  • 727
                  • U.S.A.
                  This is what I bought last and it works better than other braid I have tried so far.
                  http://www.mouser.com/ProductDetail/...yq6Z7bCCqBk%3d
                  • larrymoencurly
                    • Oct 2004
                    • 960
                    Doesn't Chemtronics still give out samples?
                    • corrize
                      Best way to solder LVDS connector for beginner (and qfn) ?
                      by corrize
                      Hello, I'm a beginner for micro soldering. Right now I have some difficult to solder a qfn 20, I guess I put too much solder on the thermal-ground pad, the result is a corner of chip wich don't touch the board (last try).
                      I use a wire solder with hot air, I tin the board and chip before with iron and I use good flux.
                      I will have to solder a LVDS connector (40 pins, laptop pc), I saw a solder paste in seringe, good quality (it does not scatter).
                      See the test :
                      https://youtu.be/bNAzC-EvqHs?t=1767
                      With hot air from bellow the board, that's...
                      03-09-2023, 02:57 AM
                    • myth77
                      UV solder mask - high temp resistent, recomendation?
                      by myth77
                      Can someone recommend any good UV solder mask? But i need a solder mask that will stand high temperetures. The thing is...sometimes i have a bigger cooper ripped from the board, lets say mosfet pad... i reconstract it with cooper sheet, then i "glue it" with solder mask...then i use UV light...and let it cool a bit. After, i try to clean the cooper of extra solder mask..and till that part all is ok. But, when i use a soldering iron to solder that pad/cooper...the solder mask gets weaker or destroyed and finally the pad is ripped again from the board .
                      Is there any solder mask...
                      03-28-2022, 04:04 AM
                    • petemanuk
                      BGA solder balls not connecting - help pls
                      by petemanuk
                      So I though in my spare time I’d set myself up repairing motherboards mainly pin damaged lga1151 sockets types.
                      I’m using an achi ir sc pro rework station (gave up on my Achie ir6500 - don’t recommend)
                      I’ve managed to get my rework profile somewhere in the correct region (after a lot of trial and error) to get the old sockets off and reflow new ones back on again, the problems I’m getting is not all of the solder balls are re-attaching when re-flow occurs. I know this because when socket is removed pads still look clean and have no solder...
                      11-16-2022, 05:21 AM
                      by sam_sam_sam
                      03-31-2024, 02:12 PM
                      Multifix 425-01 and 450-01 Rework Flux Datasheet
                      REWORK FLUXES Multifix 425-01 and 450-01 are tacky fluxes designed for use in a wide range of electronics assembly and rework processes. They represent a range of activities and residue levels to meet different customer requirements.
                      - No Clean Formulations
                      - Low residue
                      - Range of activity to deal with different component solderability
                      - Halide free
                      - Suitable for dispensing
                      - Compatible with solder coatings and/or No Clean flux cored solder wire product range
                      Both products are supplied in syringes or cartridges for application by dispensing....
                      10-07-2024, 06:02 AM
