Is matching inverter transformers really that necessary?
    I stumbled across this:
    http://imgur.com/a/J8mV1
    Guy had a broken inverter transformer, so scavenged a random transformer... and wow, it actually works?!
    Perhaps the transformers aren't that critical!
  • crtfool
    • Jun 2010
    • 82
    Re: Is matching inverter transformers really that necessary?
    He did not say what the resistance on the replacement transformer was compares to the originals. It probably was a close enough match to allow it to work properly.
    • smason
      • 1652
      Looks like he used a notebook transformer.
      I wonder how long it'll last...
        I tried inveter transformer sub (not the same P/N) in the DELL once, looks exacltly the same, but not the same impedance or the inductance. The Monitor worked for 2 weeks before it came back with blown MOSFET's.
        • caseyjay_48
          Sony KDL-46BX450 Inverter Troubleshoot Logic
          by caseyjay_48
          I am currently on a troubleshoot of 46” Sony KDL-46BX450 tv. I came back from Washington to Texas on medical emergency and had to leave all my tools up there. All I have is a couple of screwdrivers and a dvm. I wish to ask the community a troubleshooting question. Please forgive stupid questions as meds I am taking produce brain fog.
          I have well maintained Sony KDL-46BX450. It went black one day. After turn-on, I get solid green light and Sony logo in screen center for about 1-2 seconds, then black. No blinking LEDs, no hissing. Flashlight test shows screen characters dimly viewable,...
          09-23-2022, 08:08 PM
        • learnmore
          Help choosing replacement transformer for Levoit 600S SMPS
          by learnmore
          Hello Community,
          I'm attempting to repair the SMPS on a Levoit 600S air purifier. The transformer is likely open. It has six pins. 2 pairs on the primary side (one pair tested open) and 1pair of legs on the secondary side. Legs on the secondary side are spread wide apart (end-to-end). I've circled them in blue. Dimentons of the transformer are 22x23mm. Marking on the transformer are EE16 1.9mH-B. Fuse for the powerboard is fuse 250V 3.15A. I've been unable to find an exact match and I'm hoping for some help here to find a suitable replacment.
          Peace
          LM...
          11-04-2025, 09:35 AM
        • amelbye
          is it ok to replace a dual output transformer with two single output transformers?
          by amelbye
          Hi, some prestory: I was repairing an amplifier - a "Phil Jones Bass". It had some bad capacitors an a faulty power switch. Easy job. However upon putting it back together I screwed up. The connector from the 15V-0V-15V from the transformer is identical to the audio ouput from the preamp board to the poweramp board. I ended up putting +-15VAC into the preamp outputs frying some traces on the circuit board along with the power transformer The transformer is shorted. It blows the fuse immediately even with no load on the secondary.
          Now that's a challenge - luckily...
          08-21-2020, 08:51 AM
        • ohren
          Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
          by ohren
          Hello!
          I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
          Measured voltages with no load:
          After rectifier diodes
          12V: 6.17 V
          5V: 5.67 V
          Secondary transformer pins AC measurement (really don't know if this says anything)
          12V: 2-2.5 V
          5V: 1.04 V
          I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
          03-18-2023, 10:33 AM
        • mikey5791
          Is it possible for transformer substitution?
          by mikey5791
          Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
          Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
          My questions are
          1. How do i test to see if the transformer is in good working condition?
          2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
          Hope you guys understand what i was asking. My intention is...
          11-03-2022, 02:11 AM
