what is this burnt part
    Re: what is this burnt part
    That is fine, it means the bridge or the MOSFET are not shorted out.
    The voltage is a little bit on the low side, if your AC is at 120v then the voltage on the cap should be 120 x 1.414 = 170vdc.
    So at this point, the power supply has no DC outputs at all?
    This power supply should be putting out 16vdc as shown on the label?
    • CR Designs
      • Dec 2012
      • 430
      budm,
      What does this voltage tell?
        It is telling me that the bridge rectifier and the filter cap are functioning but I do not know if you are getting the 16VDC out put or not. If not, then the switching circuits are not working and will need more troubleshooting.
        By the way, you never tell us what the TV is not doing or what the power supply is not doing beside the over heated board/traces.
        • CR Designs
          • Dec 2012
          • 430
          it will not power on the set is dead. Where should i check for the 16vDC out put?
          • selldoor
            Slow Learner
            • 7870
            In your picture bottom left corner there is a socket Two pins appear to be labelled 16v
            Are the other pins labelled. It is these 4? pins you need to test
              The white connector with 4 pins is the 16vdc OUTPUT connector. Check the reading between the two red circles with your DC voltmeter, do not worry about the red/black probe of the meter, just get the two probes to the red circle.
              • CR Designs
                • Dec 2012
                • 430
                Have 16.24 volts
                • selldoor
                  Slow Learner
                  • 7870
                  #28
                  Can you reconnect to the main board and test again.
                  • CR Designs
                    • Dec 2012
                    • 430
                    Connected to main board tested had 16.30 volts
                      Your power supply is fine, problem is some where else.
                      You need to provide good clear pictures of other the boards, there is link some where here in thsi forum on how the pictures should be.
                      • selldoor
                        Slow Learner
                        • 7870
                        #31
                        I have been looking at some of the joints on the base of the boards.
                        Can you check the ones I have marked and if they look at all bad resolder them. Are the yellow ones the main cap? ( My top to bottom geography is not good)
                        • Behemot
                          • 4845
                          • CZ
                          #32
                          Isn't the thermistor just overloaded, heating it too much? It can heat to much over 150 °C and operate normally. Yet the surroundings won't with this temperature
                          • CR Designs
                            • Dec 2012
                            • 430
                            Will take more pictures of boards
                            • CR Designs
                              • Dec 2012
                              • 430
                              budm,
                              I turned the TV over to move to take more pictures of boards and the TV is working again. I guess the re solder of the burnt part did the job. Thank you for all your help !!
                                You did scrape off the green stuff and solder the current limiter back in place using flux as suggested, right? Glad to see that all it was, I have seen many colder joints for the current limiter, it will get worst and worst as joint resistance go up and more heat built up until the trace burnt or the solder crystallized.
                                I have Scepter TV with same problem, with good soldering re-work, TV is still running great after 3 years.
                                • CR Designs
                                  • Dec 2012
                                  • 430
                                  Yes, I used fine steel wool to clean up the board,down to copper and re solder as you said. Thanks you were a great help !!
                                  • edugimeno
                                    Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
                                    by edugimeno
                                    Hi There!
                                    I'm trying to help my friend who owns a restaurant be just bought.
                                    He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
                                    It's stuck using, I guess, the 2 sided tape that comes with the strip
                                    The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
                                    09-05-2024, 09:34 AM
                                  • G-Sting
                                    iPad Pro A1876 SHORT Part Identify Help Needed
                                    by G-Sting
                                    So My iPad was not charging and booting up . i went to a local technician and he checked with thermal and this Part marked in 1st Photo is Short.
                                    So then i went on to boardview and downloaded the schematics and identified this part in 2nd Photo. Now i am confused what exactly is the part called ? where should i get this from ?
                                    i contacted my technician and he sent me his BoardVIew screenshot in 3rd Photo. In his Boardview the part is called X2826.... Something
                                    SO My main concern is what part should i order what should i search the name for ?
                                    on Ipad...
                                    05-15-2025, 09:30 AM
                                  • Yanleb
                                    Panasonic part number in service manuals
                                    by Yanleb
                                    In the Panasonic service manuals, both in the board schematics and in the part listing, the part numbers that are given are Panasonic part numbers instead of the actual part numbers.
                                    This is especially annoying for small SMD components like diodes and transistors when you only have 1-3 digits printed on the component body.
                                    For an example, look at the attached PDF.
                                    Do you have a way to cross reference the Panasonic part number with the actual part number?
                                    Thanks....
                                    07-03-2023, 08:16 PM
                                  • FreakyMex
                                    Trouble to identify part (Lunii screen) for replacement
                                    by FreakyMex
                                    Hello guys. I'm a complete noob in electronics. I'd like to repair my child Lunii's (a "story box"), basically an audio player that allows the childs to choose between several options the places, characters, objects of the story, and then play a story according to the choice of the child. There is a screen that display the selected option before each choice. The Lunii fell and the screen is now broken.
                                    I'd like to repair it (probably just have to change the part, because the lunii still works perfectly fine) but I can't manage to identify the part/order it online. Do you have any...
                                    02-17-2025, 01:16 AM
                                  • electomech-fixer
                                    First post -Intel NUC 10i5 -BXNUC10i5FNH not powering on -IC burnt- request for IC details/datasheet
                                    by electomech-fixer
                                    I came across this very active forum with knowledgeable folks on electronic circuits and components, while google searching for the details of my burnt IC marked 7603 in Intel NUC board. I joined this forum today and this is my first post here.
                                    I recently got an Intel NUC 10i5 and had installed Linux Mint and was using it for about a month when it died suddenly and did not power up after that.(Power Adaptor is ok). When I opened the NUC , there was a burnt IC marked 7603 (and ILCB in second line). I am unable to find the details/datasheet of this IC. I will be grateful if...
                                    Yesterday, 01:42 AM
