To overload or not to overload?
  • KeriJane
    Mac Enthusiast
    • Sep 2008
    • 681
    Re: To overload or not to overload?
    Haha
    Budm, I am having a similar misunderstanding about my posts in a different thread!
    Behemot, you do appear to be jumping to conclusions.
    And missing some well-stated points.
    It's been a pleasure dealing with all present if I get canned here....
    The More You Learn The Less You Know!
      Only people that did not do any research or ask question or only build circuits on the a piece of paper or use simulation on the computer. You will be surprised how many people thinks ground at any point are the same because it is tied to ground.
      • Behemot
        • 4845
        • CZ
        #43
        Ideal ground, yeah, but nothign is ideal You can help that by beefing it, which I just did yesterday, but I still won't use it. Especially when it is on the other side of the board (and attaching the crocodile to Main ATX is tough ).
        • Behemot
          • 4845
          • CZ
          #44
          As for the Intel directives, I understand that as having the two caps on every rail on the PSU, right?
            I've seen postgrads that have finished their course still put a buck switcher near an ADC, even for a a little microcontroller with a 10-bit one, it matters. Local ground now has a massive current loop and your ADC readings are useless.
            The true test is to fail. If you do not fail to make something work sometime, you will never learn. And I've had plenty of failures, but lots of successes, too.
            My battery analyser worked first time, or so I thought. And it did, with one analyser, on a desktop PC. Then, I connected five of them to a crusty old Win2000 laptop with two USB ports and ran a battery discharge overnight. USB voltage started sagging to 4V as the laptop cycled from charging to running off battery, and with 700mA load from 5 micros running continuously. I did a lot of battery tests then and had to throw away all the results because the ADC was going crazy, dips every 3 minutes, didn't realise it until I saw the power LED flickering!
            But you live and you learn.
            • ben7
              Capaholic
              • Jan 2011
              • 4059
              LOL, haha!
              We all have had our fair share of dumb mistakes! (Hopefully not life threatening though!)
              Like the first time I used a potentiometer, I put too much current through it and it sparked and caught on fire xD Or, when I accidentally (I was really unaware that I had done it until the end!) put a capacitor in backwards. There was a bubbling/boiling sound, then the power led dimmed, I look at the capacitor and it was bulged and tilted to the side, about to explode! I shut off power and ran out of the room
              Muh-soggy-knee
              • Behemot
                • 4845
                • CZ
                #47
                Well I several times onced soldered backwards whole ASUS board and one of them even turned on. Luckily only couple caps vented But that's bloody ASUS and their lame backward drawing.
                As for that load… Intes says caps accross load, but load is on +5 V SB, +3,3 V, +5 V, +12 V and -12 V so is it fine soldering two caps per every rail? Now that tantal has ESR of 1 ohm and 390 mA ripple. Would Nichicon PW 22 uF with 0,95 ohm and 120 mA be adequate replacement?
                • Behemot
                  • 4845
                  • CZ
                  #48
                  Since we opened several matters here, I have another one.
                  On some PSUs - not on all, usually on those with very bad ripple - I have noticed there are not just slight differences in ripple depending on where do I take the readings from, but sometimes differences in tens of percent.
                  Now I use spare ground wire with no load flowing through it. Than what is generaly the best place for voltage reading? Directly on Main ATX/other loaded connector, before/after the recommended capacitors, or on totaly different connector with no load attached? Because, it seems, the decoupling capacitors are doing very much difference. Seems Johnny G has them directly on the probe itself.
                  I found different site suggesting to take the readings as close to the measure point as possible.
                  • i4004
                    • Oct 2006
                    • 2029
                    #49
                    (dunno if this was the most recent place you discussed this subject, but anyway...)
                    did any of you measure impedance of mobo on 5 and 12V rails vs. impedance of those resistors?
                    i feel measuring in these 2 conditions is like measuring load of pure wood on the truck vs. a water container always half empty (same weight as wood) .and with truck constantly stopping/starting to move.
                    (looking the load on truck's engine/gearbox)
                    why not just measure the temperature of coils and caps on mobo that make vrm (on full cpu load), more ripple=higher temp (in the end that temp. destroys caps...)
                    or, just take the noise alone (ie ac components of the signal, via capacitor) and power a rather small bulb with it, more light=more noise! instant indicator of noise!
                    or rectify that (now ac) noise and measure with precise voltmeter.
                    intel pdf also suggests diff. scope probes: anybody used those?
                    (read the small print:
                    checked the price of those? checked how hard a those tek probes to calibrate?
                    http://www.eevblog.com/forum/testgea...-power-supply/ )
                    even the method is called "differential".
                    i would suggests different road: have one decent psu and one mobo to use as a load, and then try few ways of measuring and pick the one that gives you highest "resolution". then compare other psus to that one.
                    definition of "decent psu" is this: one that lasts a long time and that doesn't destroy mobos.
                    (particularly funny thing is that you even have dmms that can detect ripple/noise, and these need not be expensive ones...perhaps mastech makes such where it just so happens that sampling periods coincide well with noise waveform so a lot of last digit fluctuation=lots of noise )
                    either way, as others suggested, play with it, that way you'll learn the most.
                    while at play, think about your safety too!
                    to that extent about place to measure: why not measure at few places and see what you get, try mobo, try the load you made, try on molex, try on molex in faraday cage further away from mobo etc.
                    5 and 12V rails will be loaded the most on usual pc.
                    • Behemot
                      • 4845
                      • CZ
                      #50
                      I think nobody who does not have stuff like Chroma is using differential probes. Anyway, using motherboard or something like that is not even wild guessing, that's useless. Sticking to Intels method is at least trying to be close. OFC everybody is probably measuring something slightly different, but at least people are close to it and constant. Messing with MB is not only pointless, it's wasting time for bad data.
                      • Th3_uN1Qu3
                        Believe in
                        • Jul 2010
                        • 6031
                        • Romania
                        #51
                        The Intel guideline says that the filtering capacitor are to be used at the probe end. So when you take readings with your oscilloscope, you should fit those capacitors in your probe.
                        The probe does not need to be differential if you are using an isolation transformer to connect the PSU, or if your oscilloscope is battery powered.
                        A working TV? How boring!
                        • i4004
                          • Oct 2006
                          • 2029
                          #52
                          https://www.youtube.com/watch?featur...3eduRj4#t=1913
                          (wouldn't hurt to watch complete video either! <wink>
                          and now the thread has mikeselectricstuff and dave jones videos, what more do you need? hehe)
                          unique, i would say your psu will have "dirty ground" even with isolation transformer, because it's the way it works. that's why you need differential probes to do this properly.
                          (and that's why i'm suggesting totally different concepts...heh..because it soon gets rather complex and/or expensive...would you like pre-amplifier to better see those signals? i would...)
                          btw. where does intel guideline mention where to put caps?
                          behemoth i don't think any measurement is a waste of time. if you see nothing you still learned something. <wink>
                          i would, for example, like to use 10ghz scope so i can see all the noise and can analyse it precisely (you would eventually learn what noise is cpu producing, what south bridge etc)...hehe...but these are not cheap.
                          did you try something basic, few different psus powering the pc and scoping the 5 and 12V on molex which would be as far away from pc as possible? with those diy probes dave mentiones... <wink>
                          aim should be to know what kind of noise and ripple is flowing thru the wires that connect psu and mobo. you don't know that with purely resistive load.
                          which is not to say it's totally useless, but you're not measuring what's really happening.
                          btw. you know what jonnyguru lacks? tests with new and then (after few years) used psus. i would prefer a psu with slightly more noise that remains on same noise levels to the one that falls apart after few years and destroys my mobo/hdds....
                            "i would prefer a psu with slightly more noise that remains on same noise levels to the one that falls apart after few years and destroys my mobo/hdds." falls apart after few years due to?
                            • Behemot
                              • 4845
                              • CZ
                              #54
                              I tried embedding them (not directly on the tip but between the probe and O-scope), it filters everything. But I am doing the measurement as close to them in circuit as possible. Actually, at some points I am connecting the probe to the electrodes of the caps. Sure it can be made better, just not now.
                              i4004: as a matter of fact, I tried some of that and I can tell you this, you have no idea what you are talking about. The thing is, nobody cares about actual noise. According to Intel guidelines, you are simulating motherboard and than measuring what comes out of that. That includes limiting the band to 20 MHz (so some GHz are ), connecting or terminating especially the long wires so you don't catch radio frequencies etc. If you just stick a probe into that you will read things several hundreds percent off.
                              • repair-it
                                TOSHIBA DLP 52HM95 How to reset timer module on bulb
                                by repair-it
                                I replaced the bulb only on my Toshiba DLP The bulb is a TB-25. This is the first time I've done a bulb only replacement. Supposedly there is a timer module that needs to be re-calibrated or reset. I don't know where the module is located. I see some vendors selling the bulb with the housing stating module included which leads me to think the module is located inside the enclosure the bulb mounts in, but I didn't see it. Maybe it's inside the plug attached to the bulb?
                                Anyway - I am seeking information on how to reset this so called module so that the lamp will operate. Apparently...
                                10-11-2023, 07:18 PM
                              • ezenia
                                LUMIMAN Smart Bulb IC ID?
                                by ezenia
                                I have a LUMIMAN Smart Bulb that suddenly stopped lighting one day. The bulb is still detected in the app, but won't light. I've probed around and nothing seems to look off with any of the diodes, caps or resistors. The Bluetooth/Wi-Fi module seems to be working as it's still detected in the app. I even tried deleting and re-pairing the bulb (it didn't light, but I was still able to follow the pairing instructions), it re-paired fine, but still no light.
                                In diode mode, the LEDs all light up when probed so I'm guessing this means the LEDs themselves are OK. I was expecting...
                                04-28-2025, 05:56 PM
                                Lenovo ThinkPad T16 + Extra 8GB memory Notebook Specification for Upgrade or Repair
                                This specification for the Lenovo ThinkPad T16 + Extra 8GB memory Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T16 + Extra 8GB memory boardview and T16 + Extra 8GB memory schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                09-07-2024, 06:21 AM
                              • wnlewis
                                New wire for my RDE3340 Whirlpool electric range
                                by wnlewis
                                OK. I got the rocker switch figured out thanks to the good advice on this forum.
                                Now I need to figure out the correct wire to go to the switch from the broiler element and from the oven element.
                                This is a Whirlpool RDE3340 electric range.
                                The common wire on the switch appears to have a high temperature insulating material. I am guessing that both the wire to the broiler and the wire to the oven elements also need relatively high temperature insulation. What do I need to look for? The broiler is rated at about 2400 watts.
                                Where may I find parts...
                                01-08-2025, 11:21 PM
