Here's the deal. I have this power supply load tester of mine.
It has been first made for loads up to 520 W (13x40W bulb) on +12 V rail(s). Now I would like to push it forward, first to 650 W (13x50W bulb) and later to 975 W (13x75W bulb).
Now I have mostly 3A switches on that. But it's 3 A per 250 V, that means I can pull 6 A at 12 V just fine, right? These switches tend to do 6 A ad 125 V, that's still 10x bigger power
As for bulb sockets, I think they can do it too. Extra airflow will be added as well, holes are already drilled into the board, I will also make some wooden construction to pick it up slightly (so the air can flow through the holes) and to mount the fan on it permanently.
Now, what I am not sure about at all are thermistors. Rated for 4 A (JNR13S100L), they already get hot at 3,33 A. I would suck 6,25 A from them using 75W bulbs. So, should I add another one in parallel with each existing one? I have enough of them and I should be able to squeeze them into it. The question is not so much about them being able to provide 50 % current through them, but more like being able to provide the current over many times of usage. At least couple hundreds cycles. It is more pleasant for me to solder all of them now than replace damaged ones all the time.
- I have already increased thicknes of the conductive paths by adding thick copper wire and like a ton of solder
- added some extra wire on the wire junctions (tried to keep it at some 6 A per wire at max)
- added some molex connectors and will try to add at least two 6pin PCIe connectors (so the power will flow through at least 12 pins, equaling in aprox. 6,8 A per pin and wire - I think this needs further reduction by adding at least one extra 6pin PCIe, the problem is, I have to connect it using wires, there is no room left for it
Half of the computer problems is caused by bad contacts
I am thinking about separate boards for different voltages. Load will be achieved by high-power rated resistors in TO packages mounted on heatsinks. Some linear load for fine adjustments too.
