SMD work
  • reabbott
    • Jul 2012
    • 10
    SMD work
    Has anyone ever successfully hand soldered any surface mount components ? Ive reading up about this next step in my soldering evolution and it looks surprisingly straightforward. Does anyone here have any experiences or stories, failure or success ?
    Russ.
  • smason
    • 1652
    Re: SMD work
    It looks easy. But when your eyesight starts to go. and you're sleep-deprived and caffeine-fueled it's not so good.
    I wasn't paying attention the other night and removed a small surface mount diode instead of a fuse. Took 20 minutes to find it, glasses and a 20x magnifier to fing which end was the cathode, and another 15 minutes to put it back on the board.
    Sucks to get old....
    • Mad_Professor
      A Mech Warrior
      • Feb 2011
      • 1587
      Re: SMD work
      https://www.badcaps.net/forum/showthread.php?t=23477
      That and some zener/diodes, smps chip replacement too.
      All I can say, smaller the chisel tip is, the better, also get some headmount magnifying set, prefer one with adjustable lighting position. Also thinner solder helps too.
      • randtek
        • Oct 2011
        • 280
        • US
        Re: SMD work
        I have been replacing SMD components for many (30+) years. I was working with SMD devices in the military long before they appeared in consumer equipment. You want to use very fine solder. If you don't have much need for solder this fine, I have had reasonable success using standard diameter solder, but I take a piece and VERY SLOWLY and gently stretch it until it breaks. There will be about 1/4" of thinner, stretched solder where it breaks. That is plenty for most small SMDs. Not really practical for the IC's with many pins.
        After removing the old device, clean ALL old solder from the pads using solder braid. You want the pads to be smooth, with no lumps of solder. Add a small amount of solder to one of the pads, so it has a small bump of new solder. It is unnecessary to add solder to the new device prior to soldering, they are pre-tinned. Set the SMD component on the circuit board, in close proximity to it's final position. Using a pair of very fine needle nose pliers, move the component onto the pre-soldered pad, while holding the soldering iron on the pad to melt the solder. Hold it in place for a few seconds after removing the iron, until the solder solidifies. It won't take long, as the pads, solder and component are all pretty small. Once you have one pad holding the component in place, put down the needle nose pliers, and add a tiny bit of solder to each connection, by placing the soldering iron tip at the junction of the component and solder pad. Just touch the solder to the junction long enough to melt a tiny bit onto the connection, then remove both the solder and the iron. The solder should melt pretty much instantly, as soon as you touch it to the junction.
        • 999999999
          • Sep 2006
          • 774
          Re: SMD work
          Go to a mom-n-pop computer shop, or Goodwill, and grab some free or nearly so old electronic items with SMD components and practice. Computer motherboards and hard drives come to mind as two likely candidates, you may even have some lying around to practice on.
          • spleenharvester
            • Mar 2010
            • 921
            Re: SMD work
            Recently started, and by recently I mean I've done it a couple of times. It's easy enough if you have a low-wattage iron (mine is 12W) and you learn to drag solder.
            Get a decent pair of tweezers, some flux etc. Try it on some dead motherboards (I always keep dead hardware round for practicing on).
            If you've not soldered before you may not be so adept. But a few hours replacing my 40W iron with a 12W iron I'd already managed to solder one of these (though bear in mind I had to use an airgun once the pads were tinned): http://img522.*************/img522/7900/pict0101eo.jpg
            Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
            • hollox123
              ASUS ROG Strix G713QR - Keyboard, backlight and side LEDs don't work
              by hollox123
              Hello, I have an "ASUS ROG Strix G713QR" laptop, and for approx. 3 months I have the following problems:
              1. Laptop keyboard doesn't work
              2. The backlight on the laptop keyboard doesn't work
              3. The x2 side LEDs (red) on the laptop don't work
              The power button works, the touchpad works, and all the USB, HDMI, Ethernet, etc. ports work.
              I already tried to reinstall all the drivers and reinstall Windows. So I don't know what to try anymore that is software-related.
              But I am strongly aiming that it is somehow a BIOS-related problem,...
              05-11-2025, 08:05 AM
            • resistor83
              lenovo 330s-15ikb, led num lock key always on and numbers don't work
              by resistor83
              hello everyone, I have a particular problem with this lenovo ideapad 330s-15ikb. I had to replace the motherboard due to liquid damage, after replacing it I noticed that some letters on the keyboard do not work. So I bought a new keyboard and now all the keys work except the numeric keypad area. In practice the num lock key LED always remains on and the numbers do not work. Has anything like this ever happened to you? I also tried changing the keyboard again but the same defect remains on the numeric keypad.
              I tried updating the bios but the problem remains
              https://s...
              05-29-2025, 08:06 AM
              DYMO Rhino 5200 Industrial Label Maker that the backlight does not work any ideas
              I just bought a used one for a decent price for a used device it prints very nicely and clean and clearly so I am not going to complain about it but I would like to get it working again anyone have any suggestions on how to repair this back light
              If I can not get the controller to work properly then I will probably have an external power supply for the backlight because it is difficult to see the screen without out it
              One —>the LEDs might be bad
              Two —> the buck converter or regular might be bad
              Three —> the controller might not...
              08-08-2023, 05:12 PM
              Surface Mount Fuses Fundamentals Datasheet
              TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
              TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
              10-07-2024, 06:07 AM
            • Rhaverz
              My touchpad doesn't work, Asus laptop motherboard X455LJ REV 3.1
              by Rhaverz
              Good afternoon friends
              I have an Asus laptop motherboard X455LJ REV 3.1 that the touch pad does not work, I was trying to check if something was wrong at the drive level but I did all the necessary installations and the touchpad still does not work.
              I have a feeling that the error goes more to the board level because the touchpad is not recognized by the device manager and it is supposed that even if it does not work correctly it has to be detected.
              I even checked that the data bus made a connection between the touchpad and the motherboard and everything...
              03-30-2023, 03:56 PM
