I broke the led indicator.
  • Mad_Professor
    A Mech Warrior
    • Feb 2011
    • 1587
    I just got done recapping the dell e196fpf monitor and when I went to test it, I was searching for the power button on this flimsy piece of shit pcb and now the led doesn't work, buttons work but green/amber non-functional, monitor works though. Thing is freaking tiny. It's surface mounted led array pad.
    Is there a way to fix or replace the broken led array?
  • Mad_Professor
    A Mech Warrior
    • Feb 2011
    • 1587
    Re: I broke the led indicator.
    I managed to remove it and using the DMM diode setting to test it, it does not work. Then I took a 3.5mm green LED use the diode setting to make sure it would light and it does. THen I got the idea to jury rigged it and to where I traced it back on the switch board then bridged the ground to one of the holes on the pcb. The led lights up then I disabled the monitor on my computer to put it into sleep mode and test the amber and it lights up too, so I need a new LED array I think I found the correct one since it matches the width and length.
    http://www.digikey.com/product-detai...44CT-ND/341198
    What do you guys think?
    • Mad_Professor
      A Mech Warrior
      • Feb 2011
      • 1587
      I got the replacement L.E.Ds today and that was the most difficult repair I have ever done. But I did it.
      L:1.6mm x W:1.25mm H:0.55mm
      • spleenharvester
        • Mar 2010
        • 921
        Fair play mate, I'd never have had the patience.
        Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
          master hoarder
          • May 2008
          • 12175
          • Bulgaria
          Tiny SMDs are tiny
          As long as they have only 2 pins, they're easy, though.
          I had to solder a 4-way SMD resistor array in a similar size before - what a PAIN!!!
          • Mad_Professor
            A Mech Warrior
            • Feb 2011
            • 1587
            Originally posted by momaka
            Tiny SMDs are tiny
            YES this was a pain in the ass.
            This was a bi-color led, so I had green and amber to solder. Easiest way was to get a blob of solder on both pads and led pads then used desoldering braid to remove the excess, what ever is left is under the led and surface pads. Looks clean too. To confirm you have a good connection, my DMM on diode setting puts 3.2vdc out. So it was simple black to ground, and red to pin out to confirm I have a good connection via the LED lighting up.
            • Time2Retire
              • Aug 2012
              • 256
              That's a nice bit of information. I have never used desoldering braid before, but this is a good reason to try it.
                by momaka
                03-15-2023, 10:17 PM
              • keepread
                Dell monitor PSU vs Dell laptop PSU
                by keepread
                Hi there!
                Someone gave me their old monitor, it's Dell S2715ht.
                The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
                Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs...
                10-30-2025, 04:45 PM
              • wattage
                AOC AG493UCX 49-inch monitor - Firmware request
                by wattage
                Hello Badcaps Community,
                I purchased a preowned AOC monitor that is not working and out of warranty. It was sold as not working. I am looking for guidance on self-repair. In particular, I am after the firmware for the monitor. At the end, I have included monitor model information and links to pics and vids of the issue.
                The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
                07-13-2025, 04:41 PM
              • ant3202
                HP 27es - LED monitor - Monitor Flashing On - Off
                by ant3202
                Hi Everyone
                Lately I am experiencing the deja-vu incident on one of the led monitor like this.
                https://www.badcaps.net/forum/troubl...lashing-on-off
                The monitor is HP 27es LED Monitor
                https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
                The monitor will randomly blackout and display no signal and will recover again.
                Sometimes need to power and off again to restore the display but...
                03-20-2025, 07:30 PM
              • Rick_1234
                LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
                by Rick_1234
                Good evening, gentlemen.
                I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
                To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
                https://drive.google.com/file/d/1L6S...ew?usp=sharing
                Things I tried
                - Bought a new AC adapter thinking that was the problem but the problem...
                06-22-2024, 04:44 PM
