Bought some cheap solder, More like chalk.
  • gilly1984
    • Jun 2012
    • 751
    Well, I bought some solder off ebay as i needed some badly, i tried using it yesterday and it takes ages to melt, and when it does melt it looks more like a soft chalk than molten solder. Is this my crap soldering iron or crap solder?
    My iron melts solder thats on various boards when removing badcaps and stuff.
    Here is what i bought.
    http://www.ebay.co.uk/itm/2808124688...84.m1439.l2649
    Do NOT touch heatsinks when testing for voltages as they may be LIVE!
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Bought some cheap solder, More like chalk.
    I can't make out the description on the packaging, so I can't tell the composition of the solder. Since you are in the UK, it is probably lead free solder. However, it is my understanding that you can buy 60/40 solder if you choose to.
    I have had positive/negative experiences with "sort by lowest price" cheap solder on ebay. The first 2 that I got were 60/40 solder and they were awesome. Then after watching the 3 eevblog part series on soldering, I went with thinner solder and 63/37. I regret that decision. It could be just the cheap ebay solder, but it is nowhere near as good as my original 60/40.
    In fact, I'm running out of the 60/40 and need to find a good replacement.
    I invested in a Hakko FX888 so I know it is not the soldering iron. I set it to 350C and have a 1.6mm and 3.2mm chisel tip.
    --- begin sig file ---
    --- end sig file ---
    • gilly1984
      • Jun 2012
      • 751
      Friend gave me some more solder, its like a dream to use compared to that ebay stuff.
      Would be more at home in a welder than using as solder.
      • PeteS in CA
        • Aug 2005
        • 3580
        • USA, Unsure of Planet
        It may be lead-free, which melts at a higher temp than the non-PC stuff, and can have a duller appearance.
        My fervent wish is for the RoHS lead-banning envirocrats to find their lives dependent on medical equipment built with their lead-free PC solder!
        PeteS in CA
        • 999999999
          • Sep 2006
          • 774
          It's just the particular solder retiredcaps, decent 63/37 is even easier to work with than 60/40. Everyone has their own preferences for solder, especially some exotic stuff praised in audiophile circles, but I only buy Kester. Pity it tripled in price compared to a few years back, Digikey now wants FIFTY FOUR (!!!) dollars and up for a 1lb spool of # 285
          MPJA has some 44 series 1lb. 60/40 for $25. http://www.mpja.com/prodinfo.asp?number=19101+TL
            master hoarder
            • May 2008
            • 12175
            Probably the solder since you say your soldering iron works fine.
            That said, the solder you got is likely either lead-free or lacks a flux core (or both ).
            I would suggest to let your iron heat up very well (if not temperature regulated), otherwise set it to 320 to 350C. If the solder still looks bad when you apply it on a joint, try adding some flux (both liquid and paste are fine) to the joint prior to adding the solder.
            I have a spool of some type of lead-free solder. It's very thick and lacks a flux core. Impossible to put on joints if I don't use flux. I think it's for plumbing. Says 95/Tin, 5/Ant. wire.... I'm guessing that means 95% Tin and 5% Antimony? Anyways, with flux, it works very well and I've used it for many repairs now.
            I think flux and lots of heat is all you may need to make your solder work well... Unless the Chinese have figured a way to make solder out of chalk, that is .
            • acedogblast
              by acedogblast
              11-02-2024, 05:13 PM
            • corrize
              Best way to solder LVDS connector for beginner (and qfn) ?
              by corrize
              Hello, I'm a beginner for micro soldering. Right now I have some difficult to solder a qfn 20, I guess I put too much solder on the thermal-ground pad, the result is a corner of chip wich don't touch the board (last try).
              I use a wire solder with hot air, I tin the board and chip before with iron and I use good flux.
              I will have to solder a LVDS connector (40 pins, laptop pc), I saw a solder paste in seringe, good quality (it does not scatter).
              See the test :
              https://youtu.be/bNAzC-EvqHs?t=1767
              With hot air from bellow the board, that's...
              03-09-2023, 02:57 AM
            • myth77
              UV solder mask - high temp resistent, recomendation?
              by myth77
              Can someone recommend any good UV solder mask? But i need a solder mask that will stand high temperetures. The thing is...sometimes i have a bigger cooper ripped from the board, lets say mosfet pad... i reconstract it with cooper sheet, then i "glue it" with solder mask...then i use UV light...and let it cool a bit. After, i try to clean the cooper of extra solder mask..and till that part all is ok. But, when i use a soldering iron to solder that pad/cooper...the solder mask gets weaker or destroyed and finally the pad is ripped again from the board .
              Is there any solder mask...
              03-28-2022, 04:04 AM
            • petemanuk
              BGA solder balls not connecting - help pls
              by petemanuk
              So I though in my spare time I’d set myself up repairing motherboards mainly pin damaged lga1151 sockets types.
              I’m using an achi ir sc pro rework station (gave up on my Achie ir6500 - don’t recommend)
              I’ve managed to get my rework profile somewhere in the correct region (after a lot of trial and error) to get the old sockets off and reflow new ones back on again, the problems I’m getting is not all of the solder balls are re-attaching when re-flow occurs. I know this because when socket is removed pads still look clean and have no solder...
              11-16-2022, 05:21 AM
              I bought three of these Sparkle Power FSP460-60GLC - Computer Power Supply 460Watts recap need
              I have bought computer switching power supplies from Electronic Goldmine before and every one of them the capacitors were bloated and or leaking out of the capacitors so I am sure that these are going to be the same way five or six years ago I had bought some 300 and 350 watt computer switching power supply from Electronic Goldmine these are all from FSP brand
              Here is the listing for this switching power supply they only had three of them in stock and I bought all three of them
              https://theelectronicgoldmine.com/products/g28149
              I have one old computer that...
              07-18-2024, 06:55 PM
