Transformer help
  • 2andrewd
    • Mar 2012
    • 41
    • us
    Transformer help
    http://ludens.cl/Electron/esr/esr.gif
    I'm not understanding how T1 is meant to be wired. I made the 400:20 transformer- The primary has 2 leads, the start of the winding and the end of the winding. The secondary is the same... that's 4 leads but the schematic only shows 1 of the primary leads being used. What am I missing here?
  • mariushm
    • May 2011
    • 3799
    Re: Transformer help
    One of the wires of the primary is connected to that capacitor C2
    The second wire of the primary is connected to GROUND of the circuit.
    One of the wires of the secondary is connected to that point above R5
    The second wire of the secondary is connected to GROUND.
    Basically, one wire from each side is connected together and then to GND.
    It's used to send small pulses of AC to the capacitor put between the test points, the 400:20 reduces the AC voltage.
    • Spoonicks
      Samsung 2233SN no CFL backlight
      by Spoonicks
      Have a Samsung 2233SN with no CFL backlight. Testing with a flashlight, I can see the image is displayed, but the backlight fails after some seconds.
      Sometimes, after being off for a while, the backlight will remain on for a couple minutes, but most of the times it fails immediately.
      I tried to follow the guide present in this forum, but so far I haven't de-soldered any components. I need some advice on how to proceed to diagnose this display.
      Following the guide I tested the following:
      The transformer...
      07-01-2023, 11:10 AM
    • peter_wheat
      Looking for SMPS flyback tranformer TAM TO-5622 or equivalent?
      by peter_wheat
      Hi All,
      I'm looking for a SMPS flyback transformer TAM TO-5622, or equivalent, or any information on it? Company is Tamura Corp (https://www.tamuracorp.com). It has Primary, Secondary, and Auxiliary windings. Have emailed the company, but no info back yet. It is out of a Makita DC24SC battery charger.. This transformer has a burnt out the primary (caused by a failed MOSFET). Secondary, gave me a reading of 0.49 Ohms, and Auxiliary a reading of 0.93 Ohms. I took it to bits, thinking I might try and re-wind it, but it was more complex than I realized, and had difficulty removing...
      08-28-2025, 02:03 PM
    • bauto601
      KDM 480W PSU upgrade succes! (opinions?)
      by bauto601
      Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
      A "nice" YoungYear unit? - Badcaps
      The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
      12-26-2023, 03:05 PM
    • hikomalek
      SYMSI70 gas heater, TOP247Y exploded, power supply, snubber network
      by hikomalek
      Hello, I have a SYMSI70 gas heater board, which has issues with its primary side power supply, controlled by TOP247Y chip.
      When I replace a TOP247Y it explode in 1 second. I have desoldered transformer and measured a winding ratio, so transformer looks like OK.
      Transformer:
      |Info| Primary | Aux | AB | CD|
      |Ratio|1|25|40|12|
      |Voltage AC|230V|9.2V|5.8V|19V|
      |Voltage DC (*1.41)|230V|13V|8.1V|27V|
      I have disabled a undervoltage protection of TOP247Y, disconnected secondaries and tried to power it up...
      09-19-2025, 03:30 AM
    • KYBOSH
      Tektronix 422 with No Power
      by KYBOSH
      Picked up a Tektronix type 422 oscilloscope locally for a few bucks last year.
      It wouldnt power on at all so I stowed it away under my bench for later testing.
      Today I remembered it was down there and pulled it out to see what was what.
      I checked for continuity and everything checked out.
      There was a burned smell and a resistor was replaced with a temporary replacement (see yellow box in picture).
      The burned smell is very pungent/acidic and I am not familiar with these vintage electronics to know whether I am smelling the remains of the replaced resistor or...
      02-03-2024, 07:56 PM
