Multimeter buzzer - replacement
+ More Options
Posts
  • tmcw
    • Oct 2010
    • 382
    • Ireland
    I have a multimeter that had a fall a few months back, the continuity buzzer stopped working correctly, instead of a nice clear tone, it was making a faint rattle noise, a bit like a Geiger counter detecting little radiation.
    Anyway, I was looking to see if I could find something on the internet, but can't find any for sale, and very few pictures; I've attached a photo of what it looks like. It's a very thin metal disk (about 5 or 6 stacked would approach the thickness of a coin), 20mm diameter, plain on one side, and a smaller white disk (15mm diameter) on the other (I presume that's the diaphragm).
    I have a much thicker buzzer salvaged from a busted UPS, and it works fine when connected where the original one was, so it must be the original disk buzzer that's broken. I could probably get it in somehow, or maybe a smaller motherboard speaker, or even one half of a headphone set might do the job, but if I could get the proper disk that can be mounted to the circuit board, that would be best.
    Anyone have any ideas, either where to get a replacement, or another elegant solution? I haven't seen any in a loooooooooong while, but are these buzzers like the ones in those musical greeting cards?
    Re: Multimeter buzzer - replacement
    That is piezoelectric transducer, not sure if you can get it from Mouser or Digikey or not.
    • retiredcaps
      • Apr 2010
      • 9271
      396 "in stock" piezo buzzers at digikey
      http://www.digikey.com/product-searc...s=piezo+buzzer
      --- begin sig file ---
      --- end sig file ---
      • tmcw
        • Oct 2010
        • 382
        • Ireland
        Thanks, I know what I'm looking for now. I'm on the other side of the Atlantic from yourselves, so will look for somewhere a bit closer if I can't salvage one out of something else (I'm in no rush to replace it). I might be able to get another obsolete UPS or other device that has one. The test buzzer I referred to in the first post has a similar transducer inside its housing, along with a small circuit board, but it is also of larger diameter than the one that was in the multimeter, I don't know how much of a difference that will make, but I'll see if I can find one the same size or smaller as the original.
        Might find one in an old modem, for example, that might work.
        Thanks again.
        • retiredcaps
          • Apr 2010
          • 9271
          ebay?
          http://www.ebay.com/sch/i.html?_saca...buzzer&_sop=15
          • ben7
            Capaholic
            • Jan 2011
            • 4059
            Get a bunch of cheap small toys from the second-hand store. Take them apart, you will likely find another piezo device.
            Muh-soggy-knee
            • tonylev
              what disk cap replacement can i use
              by tonylev
              hi,im trying to identify this cap for replacement but don't know the value ect... can you help me,thank you this is in a AB763 Deluxe Reverb guitar amp
              08-08-2024, 12:37 PM
            • welp
              PS5 Disk Tray issues.
              by welp
              I have a PlayStation 5 CH-1215A with a Disk drive not reading disks anymore. (accepting and ejecting very slowly.)
              Knowing the PS5 has a married daughter board for the disk drive I made sure to use that and replace the rest of the disk tray as it* was owned previously by an indoor smoker.
              Once the job was complete and put back everything together, I tried to insert a disk with no luck at all...
              So, I checked voltage going from the ps5 to the daughter board and am only getting the 5V rail.
              With that knowledge I preceded to check all the fuses for the 12v rail on the main...
              12-19-2024, 02:04 PM
            • DynaxSC
              ASUS ROG STRIX B550-I GAMING - M.2_2 port not working correctly with SAMSUNG SSD980 1TB NVME SSD
              by DynaxSC
              I have an really very weired issue with ASUS ROG STRIX B550-I GAMING.
              Some NVME (PCIe) SSD's are not working correctly in the second M.2 socket. An example of it is the SAMSUNG SSD980 1TB NVME SSD.
              Some other NVME (I have only smaller ones) disk do work without any problem, also SAMSUNG disks, eg an MZVPV128HDGM-0000.
              The behaviour is also really very strange, i.e.:
              • The disk shows always up in BIOS - so it is recognized, so far so good
              • POST-ing with this disk with fresh Windows 24H2 installation (done in the M.2_1 socket) in the M.2_2 socket
              02-23-2025, 01:33 PM
            • madura2010
              DAY11AM6E0 hard disk drive and optical disk drive not detected
              by madura2010
              Today recieved hp model 17-f100nx laptop with no power.(motherboard=DAY11AMB6E0) after that repaired +1.05v section due to faulty buck converter.after that power issue fixed and laptop turns on.But "no bootable 3f0 error displayed".so then
              i checked the connectivity of ribbon=good communication with hard and motherboard
              changed hard disk and checked=3f0 error persist
              sata power=+5v available
              Then checked data capacitors=all good
              Then checked data lines path connectivity to pch=all good
              reflashed...
              03-12-2023, 09:09 AM
            • chth96
              LG GCC-4521B cannot read any disk
              by chth96
              I bought 6 second hands odd $5 at a flea market and I found that 2 odd(GCC-4521B,TS-H192) won't read any disk.
              But I measured all ESR value of SMD capacitor which is located on the TS-H192's PCB and replaced two capacitor which has higher ESR value.
              And To My joy,this TS-H192 odd finally recognized burned CD as well as pressed CD.😂
              But there was no more good fortune for GCC-4521B..In order to dead GCC-4521B back to life, I replaced three capacitor which has higher ESR value and I rubbed silicon grease on the every glides.I even brushed lens with cotton swab which was soaked...
              02-13-2024, 07:31 AM
