sharp lcd tv lc42sb45u dead set
  • amcdtony100
    • Aug 2012
    • 3
    • usa
    found stby chip ic903 blown out, i need part id like generic# on the ic or svc manl. appreciate the help
  • selldoor
    Slow Learner
    • 7870
    Re: sharp lcd tv lc42sb45u dead set
    Picture of the board would help and quote the board part number
    Welcome to the forum-
    We can help a lot more if you please post good clear pictures of the whole chassis, and then pictures of each board, front and back and close up of connectors, (max resolution 2000x2000 and 2MB) using the manage attachments button, which is found by clicking "go advanced" under quick reply.
    Examples of what is needed
    https://www.badcaps.net/forum/attach...1&d=1290283049
    https://www.badcaps.net/forum/attach...7&d=1280167246
    • selldoor
      Slow Learner
      • 7870
      attached perhaps depending on your board
      https://www.badcaps.net/forum/attach...5&d=1328837024
      • amcdtony100
        • Aug 2012
        • 3
        • usa
        Thank you, this info is just what i needed.
        • borstar_micke
          Dead Sharp Aquos LC-32LE430E
          by borstar_micke
          My 12y old daughters tv (that she got after her grandpa, has sentimental value to her) was just dead without stby light a couple of weeks ago.
          I´ve repaired a couple of computer monitors, classic blown capacitor replacements, a 55" Sammy led with t-connboard replacement and a 42" Panasonic edge led where I replaced the led-strip.
          Not a master with the multimeter, which is cheap and 10-15year old btw...
          So please make it basic...
          To the issue at hand.
          As stated, the tv is totally dead with no standby light....
          03-23-2023, 09:14 AM
        • metropical
          Sharp lc32d42u seems dead
          by metropical
          plugged in after being off for quite some time. No OPC lights. Tried flashlight test for backlight check, nada.
          Pulled the PS and checked all diodes including the 5w(?) D7908 that was the issue last time. All diodes check OK in circuit with DVM diode test.
          No caps look unhappy. It is 17 years old. Was gonna fix and give to my brother.
          But is there anything else to try or is it likely met its match.?...
          09-28-2024, 05:41 PM
        • Judderman69
          Sharp LC-40FG2241KF dead
          by Judderman69
          Hello and greetings from the United Kingdom, I'm looking for some help in repairing my grand daughters 'dead' Sharp LC-40FG2241KF smart tv. I have replaced the following damaged parts on the main PCB (TP.MS6486.PB711) :- fuse FB1, switch mode chip UB101, MOSFET QB101,capacitor CB116, resistor RB106, RB148 and a track from UB101 pin 6 to QB102.
          Unfortunately resistors RB105 and RB108 are also open circuit and because of their size (0201) I don't know their value. Could some kind soul please tell me or point me toward a schematic with a parts list, a very big ask but for this I would...
          02-02-2022, 11:29 AM
        • double_DD
          How can I be sure that my EC chip is dead?
          by double_DD
          As the title suggests, how can I be sure that my EC chip is really dead?
          I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
          Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
          03-12-2025, 07:47 AM
        • disorder
          ps5 edm-033 dead after hdmi/usb ports destroyed
          by disorder
          hello guys,
          i need help to repair a edm-033 ps2
          history : as always hdmi port and usb ports destroyed after unplugged
          after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
          so i changed it
          now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
          but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
          i don't see any projection of liquid metal on pcb.
          01-14-2025, 12:48 PM
