smoothing out voltage spikes and dips?
  • scampo77
    • 233
    #41
    Re: smoothing out voltage spikes and dips?
    Sorry I didn't realize that there was a 3 wire divider in a float set up like this.
    I had nothing before, this is a one off thing of left over parts
      Most fuel senders are 2-pin variable resistor setup, never seen 3-pin type used in the car. 3-pin potentiometer type are used in most electronics such as you volume control on the radio.
        Be carefull on what you see on internet.
        Google 'Fuel gauge using LM3914'
        Example:
        http://www.electro-tech-online.com/e...ng-lm3914.html
        Did the author actually built and tested what get posted?
        • ben7
          Capaholic
          • Jan 2011
          • 4059
          Example:
          LOL, that was an epic design fail!
          Muh-soggy-knee
          • ben7
            Capaholic
            • Jan 2011
            • 4059
            This is the revised circuit.
            1x LM3914
            3x 1N4148 (D1-D3)
            10x red/green/yellow (your choice) LEDs
            2x 10uF 25v capacitor (C1-C2)
            1x 100uF 16v capacitor (C3)
            1x 2N3904 (Q1)
            Optional - 1x 1A fuse
            R1 - 1k
            R2 - 4k7
            R3 - 10k
            R4 - 90 1/2watt
            R5 - 10k
            R6 - 10k
            R7 - 2.2k
            All resistors are 1/4watt unless specified.
            The 9.35v connections connect to each other, and the Vref connections connect to each other too.
            Also one important thing, does the float sensor read a higher resistance or lower resistance when all the way down? (when the tank is empty)
            When we finish the design and you build the circuit, its a good idea to install a 1A fuse also, for good measure.
            Muh-soggy-knee
              Originally posted by scampo77
              is this new diagram based on me keeping the Rsensor as a 0-100ohm float? and it is empty (one bulb lit up) at 5 ohm? and full (all 10 bulbs) at 85 ohm?
              Hi Ben, 85 Ohms = full, 5 Ohms when empty if I read his post correctly.
              By the way, most sensor assembly has one end attached to the tank which is ground the other end go to the Gauge on the dash with regulator circuits.
              • scampo77
                • 233
                #47
                am i understanding this correctly?
                please excuse my horrible horrible drawing (yes i am university educated)
                • ben7
                  Capaholic
                  • Jan 2011
                  • 4059
                  You have the diodes backwards, and the 2N3904s pinout is EBC with the flat side facing you.
                  Muh-soggy-knee
                  • scampo77
                    • 233
                    #49
                    thanks ben i switched them around and it took off. i just wanted to make sure i had the collector leg integrated into the circuit correctly. if you look at the time i wrote the picture it was the middle of the night and i was half asleep and just threw something down on paper.
                    it is working! but in reverse. tank is empty, 0 ohm, 10 bulbs lit up and full 85+ ohm i have one light on.
                    and absolutly no damping of the pin 5 circuit. it is still reacting very much in real time. and i even have a .47uF in C3 spot
                    i am having trouble getting my fingers on a 90 ohm 1/2 watt resistor. wat happens if i ....
                    a) put in 100 ohm in R4?
                    b) put in a 82 ohm in R4?
                      BTW, I am still working on the diagram for you, just trying to simulate it on my computer.
                      • ben7
                        Capaholic
                        • Jan 2011
                        • 4059
                        You will need to connect Rlow pin of LM3914 to ground, and the Rhigh pin connects to the voltage divider made by R5 and R6. This means that D2 is not going to be used at all.
                        Try a 100uF or 470uF cap for C3.
                        Muh-soggy-knee
                        • scampo77
                          • 233
                          #52
                          ok i switched them now they just all come on and stay on. and my hi ref fluctuates from 2v to 2.2v
                          • ben7
                            Capaholic
                            • Jan 2011
                            • 4059
                            Does your circuit look like this now?
                            (I did add D2 back in. Its in a different place now. Also the float sensor and the R5-R6 voltage divider has been connected to the Rhigh pin instead of the Rlow pin. see if it changes anything)
                            Muh-soggy-knee
                              OK, this is REV1 for what I come up with, based on calculation with sensor 5 Ohms min (Empty tank, no LED ON) and 85 Ohms Max (full tank, LED#10 ON).
                              I left out the damping circuits for now to see how well the range of the sensor is.
                              The calibration is done by setting the sensor to full resistance then adjust VR1 till LED #10 is ON.
                              To make LED1 to be on at empty will be a little more complicate due to the voltage windows (sensor @max and sensor @min).
                              Notes: you will have to find out which end of the sensor is tied to the chassis ground.
                              • ben7
                                Capaholic
                                • Jan 2011
                                • 4059
                                To make LED1 to be on will be a little more complicate due to the voltage windows (sensor @max and sensor @min).
                                Good job!
                                Muh-soggy-knee
                                  Thanks, tt is only good when it does what he wants to do, then I will make inprovement from there, crossing my fingers.
                                  • ben7
                                    Capaholic
                                    • Jan 2011
                                    • 4059
                                    I was using the diodes D2 and D3 along with R3 and C3 to make a time delay. D3 prevents the capacitor from draining through the float sensor pot.
                                    lol, is this becoming a competition to see who could make the best circuit?
                                    EDIT: Did you get the 5-85 ohm pot idea here? Because I think he was just asking. He should measure the resistance of it when full and empty. That would help a lot
                                    Muh-soggy-knee
                                      I have a feeling he did not hook up your circuit like you have shown in the drawing.
                                      I try to make the circuits as simple as possible. I hope he can try mine also.
                                        Please disregard the diagram of REV 1, I drawn the connection wrong on the Ref adjust and Refout pin connection.
                                        Here is the REV2 with the correction.
                                        Hi Ben:
                                        Yes,I hope the 5 Ohms-85 Ohms range is the correct info.
                                        By the way how did you do the link like that with the word here and it links to the URL.
                                          If this is an automotive system, I'd *highly* suggest an TVS (e.g. 1.5KE) and fuse (auto 1A if possible will be more than enough.)
                                          • harp
                                            high voltage high resistance marking resistor
                                            by harp
                                            Is there any reason why high voltage high resistance resistor use weird marking and value on it? Standard nomenclature, EIA value not used?...
                                            08-26-2024, 01:42 PM
                                          • jinu_j
                                            by jinu_j
                                            Hi
                                            05-03-2025, 10:51 PM
                                          • mikey5791
                                            Need help to replace burned resistor in 350w atx psu
                                            by mikey5791
                                            Hi to all forum members,
                                            Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
                                            The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
                                            Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
                                            Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
                                            12-26-2024, 04:55 AM
                                          • rddube
                                            Lenovo L490 Ram voltage circuit malfunction
                                            by rddube
                                            Hello friends,
                                            Looking for some guidance here. The RAM voltage circuit on this motherboard keeps burning out PU301 which is a RT8231AGQW. Copy of the board with the burnt chip attached with some voltage measurements and copy of the schematics also included.
                                            I think I've checked almost every component in the circuit, but when I change the RT8231, the laptop starts I have 1.2V on the inductor for about 10 seconds and then the RT8231 goes south and no more voltage on the inductor. All other voltages on the laptop are good, this is the only one conking out for a reason I...
                                            07-15-2025, 04:41 PM
                                          • MidnightRoller
                                            Can a resistor lose resistance after hot air?
                                            by MidnightRoller
                                            I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
                                            I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
                                            02-02-2022, 11:46 PM
