can I downscale a 2400W Heater?
  • newtoCaps101
    • Jul 2011
    • 93
    Hey Guys, So I was wondering, I have this old retro electric halogen bar heater that I repaired last year, I love it, its portable and one of a kind I used it last year during the winter season to keep me warm. Anyhow it has three settings 800W, 1600W and 2400W. I had some cheap heaters in the house those were 400W 800W and 1200W enough to keep my little room warm. Any how even though I only used 800W(1 of the bars) of it it gave me some big electricity bills, So I was wondering if there was any way I could maybe.. you know lower the wattage or power output thus lowering my electricity bill. Without having to spend any more money on some crappy little plastic heater.
  • joshnz
    • Feb 2011
    • 969
    • New Zealand
    Re: can I downscale a 2400W Heater?
    Warning heaters contain high voltage and high current poor connections will lead to fire or electric shock.
    Originally posted by newtoCaps101
    Anyhow it has three settings 800W, 1600W and 2400W.:
    It depends on how it is wired, how many bars does it have?
    My pc
    CPU : AMD PHENOM II x4 @ 3.5Ghz
    MB : ASUS M4A89TD PRO USB3
    RAM : Kingston ValueRAM 16gb DDR3
    PSU : Cooler Master 850W Silent Pro
    GPU : ATI Radeon HD 6850
    • Longbow
      • Jun 2011
      • 623
      From your description, it looks like each heating bar is an 800 watt element. The higher heat ranges add one or two more bars in parallel. So, if you want less heat than 800 watts, you would wire 2 800 watt bars in series to give you about 400 watts. Disclaimer: make sure you know what you are doing. Heater wire has high temperature insulation and it is always crimped, not soldered. Make sure your mains cord is in good condition and rated for heating appliances such as clothes irons.
      Is it plugged in?
      • larrymoencurly
        • Oct 2004
        • 960
        I have a Harbor Freight 1500W heat gun with a 1N5408 diode for temperature control. Is this an experiment in how much the diode's 3 amp rating can be exceeded?
          1500Watts, at 120V, that will be 12.5A, that diode is not going to last if they put that in series with 1500 Watts heating element.
          • ben7
            Capaholic
            • Jan 2011
            • 4059
            lol noo, its used to measure the temperature similar to an NTC. This technique is also used in amplifier circuits, to keep the transistors properly biased.
            Well, just what longbow said, use two 800watt elements in series to make a 400W element. Or use all three in series for a 266W element.
            -Ben
            Muh-soggy-knee
              I do not think the cheaply made Harbor Freight 1500W will be doing anything that complicate. Do not forget, we are talking about Harbor Freight Chinese made products here. You can actually use LARGE enough diode to drop the power in half since you will only use half of the cycle of the supply voltage.
              • 999999999
                • Sep 2006
                • 774
                I am not as confident as others that connecting two 800W in series would result in 400W. Typically things like halogen lights, or even nichrome wire, increase in resistance as temperature rises. I'd expect a significant amount more than 400W, but could be wrong.
                Also, if the filament in the bulb still gets hot enough to glow, you may find the filament vaporizes and deposits on the quarts at a higher rate as the halogen helps to redeposit it at particular temperatures for which the bulb is designed to operate. In other words running a halogen bulb at between half power and full power might even cause lower lifespan than at full power.
                I think I'd just hook up a thermostat to cycle it on and off at the desired temperature. Otherwise it's sort of a shot in the dark whether whatever wattage it ends up being, happens to coincide to your preferred room temp.
                • newtoCaps101
                  • Jul 2011
                  • 93
                  okay, i guess i will just leave my retro heater as it is for now instead of risking down scaling it
                  thanks guys
                  • 999999999
                    • Sep 2006
                    • 774
                    ^ well you could still do it, otherwise the heater elements have no use right? It'd still be somewhere between 400W and 800W as a guess, assuming the lower heat doesn't cause the sum of two to have lower resistance than one hotter tube would.
                    I wonder what'd happen if you just put a diode in series with one of them.
                    • 999999999
                      • Sep 2006
                      • 774
                      I mean in series across a length of wire so the diode doesn't overheat.
                      • cadiman
                        • Mar 2010
                        • 397
                        I would make sure your electrical panel is balanced by checking each leg going into it.(check it with your heaters plugged in with an ac inductive amp meter).
                        You may find one leg is pulling way more amps than the other and that will stress that leg of the panel and also make your electric bill a bit higher.
                        I like 220v baseboard if you must use electric heat. They keep the panel balanced and are more cost effective and safer than the cheap portable heaters.
                        • edugimeno
                          Vaillant 242 Gas Water heater. Shortcut in board anc compatibility with model 282
                          by edugimeno
                          Hi!!
                          Yesterday I was installing a new Wifi thermostat for my domestic gas water heater model Vaillant 242/2-3, and accidentlly one wire from mains touched one wire from the thermostat output contacts. This shut off the heater so I finished installing the thermostat and then went out to check the heater
                          I found one fuse blown (T2 250V). Replaced it with another equivalent fuse and it blew right away. I measured L-N in mains input and I sometimes got 4K but sometimes, not sure why, I got 100 Ohm...
                          At a certain point, moving stuff around, I put all wires back in place and...
                          03-24-2024, 02:31 PM
                        • madan1
                          Diesel heater emergency power supply / poor man's UPS
                          by madan1
                          Hello everyone.
                          Some background - I have one of those chinese diesel heaters, which I'm using to heat a garage. Probably most of you are familiar with that units, but here is some basic info - the main heater body is enclosed with the motherboard+sensors unit inside a plastic case. The heater has a glow plug, that works only when the unit is starting (start the fire in the burner) and stopping (make sure to completely burn the fuel inside the burner) and two fans on a single motor. One fan is used to push fresh air in the burner, the other is used to push cold air in the case and...
                          12-18-2022, 08:05 PM
                        • Akira81
                          LG 55LF652V-ZA flashing led bars despite their replacement
                          by Akira81
                          I have this 55" LG 55LF652V-ZA smart TV which suddenly started flashing intermittently every 2 seconds with the backlight.
                          If I aimed the light bulb of my cell phone I could see the underlying image even in those fractions of time when the LEDs were off and the audio instead came out continuously.
                          Armed with a lot of space and patience, I decided to open the TV, immediately noticing that a LED had flamed out and also burned a portion of that reflective white panel behind the transparent LED diffusers.
                          04-14-2023, 11:50 AM
                          Heater element wire type instead of a fuse when troubleshooting a short circuit DIY
                          I was Ollie today which is a close out / surplus outlet store I do not go in there to often because you find things that you should not be tempted by but that is a another story
                          I saw a small space heater that used a wire type of heater element which I been looking for a while but not really hard mind you but when I saw this I grabbed it I going to go back tomorrow and buy the last one that is like the one I bought today because I need the heater element and the ceramic insulators and more of heat element wire because this one has two different wattage settings one 1300 watts ( tap...
                          12-16-2023, 08:39 PM
                        • sew333
                          Apartment to buy with coal heating. Any sense to buy electrical heater and new pc?
                          by sew333
                          Hi guys. I have an question. Overall i am currently selling my house ( apartment with 1 room ) to buy some cheaper with 1 room too, and save cash for new pc in autumn 2024.
                          So i choosed some cheaper apartment in smaller city,but there is coal heating. I dont wanna heat for coal.
                          So i m thinking to buy electrical heater. And my question . Is this any sense to buy electrical heater when i will be using new pc with rtx 5090 and new intel ( when will be released ) ultra + Psu Seasonic 1600W?
                          I expect that i will pay more for bills. But i wanna know this. Will using electrical...
                          06-14-2024, 07:30 AM
