I'm currently having a bit of trouble with a Samsung LCD TV (original thread).
Plainbill brought me away from thinking it's a faulty mainboard, so i started checking the PSU board, which i assumed was fine after a recap.
Turns out it probably isn't. Without the PS-ON line connected to anything (mainboard unplugged completely), all output voltages are constantly present (i.e. not just 5Vsb as i thought).
Tried following the PS-ON line and it lead through a bunch of resistors and a tiny SMD transistor to one of the optocouplers, and also off another way to another blob of resistors, a tiny SMD transistor and a MOSFET, which is labelled "40P03-20", which according to Alldatasheet is apparently a 40P03 P-Channel power MOSFET.
You can see it in this photo at the top (half cut off)
I'm gonna take a better pic of that area soon.
When i went to test it in circuit (diode test mode on my DMM) it showed shorted on all possible pin combinations.
I got it desoldered today and after heating the solder for a few seconds, it started to smell funny (as if it got awfully hot at one point.. the fried electronics smell).
Tried checking it according to the simple method posted here
In this datasheet, there's a block diagram showing a diode between drain and source, so i expected to get a reading one way but not the other.
Unless I'm too dumb to measure this, it looks like there's a short between drain and source, as no matter which way around I connect the leads of my DMM, I always get 0.00 ohm.
Am I measuring this wrong or is it simply bad..
I'm pretty clueless at the moment..
Someone enlighten me please
