P-Channel MOSFET testing
  • Scenic
    o.O
    • Sep 2007
    • 2642
    I'm currently having a bit of trouble with a Samsung LCD TV (original thread).
    Plainbill brought me away from thinking it's a faulty mainboard, so i started checking the PSU board, which i assumed was fine after a recap.
    Turns out it probably isn't. Without the PS-ON line connected to anything (mainboard unplugged completely), all output voltages are constantly present (i.e. not just 5Vsb as i thought).
    Tried following the PS-ON line and it lead through a bunch of resistors and a tiny SMD transistor to one of the optocouplers, and also off another way to another blob of resistors, a tiny SMD transistor and a MOSFET, which is labelled "40P03-20", which according to Alldatasheet is apparently a 40P03 P-Channel power MOSFET.
    You can see it in this photo at the top (half cut off)
    I'm gonna take a better pic of that area soon.
    When i went to test it in circuit (diode test mode on my DMM) it showed shorted on all possible pin combinations.
    I got it desoldered today and after heating the solder for a few seconds, it started to smell funny (as if it got awfully hot at one point.. the fried electronics smell).
    Tried checking it according to the simple method posted here
    In this datasheet, there's a block diagram showing a diode between drain and source, so i expected to get a reading one way but not the other.
    Unless I'm too dumb to measure this, it looks like there's a short between drain and source, as no matter which way around I connect the leads of my DMM, I always get 0.00 ohm.
    Am I measuring this wrong or is it simply bad..
    I'm pretty clueless at the moment..
    Someone enlighten me please
  • trebo
    • 514
    • Wales, UK
    Re: P-Channel MOSFET testing
    thats a bad mosfet,
    you can read conformation in this link
    https://www.badcaps.net/forum/showpo...0&postcount=13
    just scroll down to mosfet
    the testing you put up is for a mosfet that is working (but not functioning propely)
    yours has a short, its not working
    • retiredcaps
      • Apr 2010
      • 9271
      It is a scary day when one of my testing procedures is used to enlighten someone.
      Long time members will recall I didn't even know what a short, mosfet, and multimeter was back in April 2010.
      --- begin sig file ---
      --- end sig file ---
      • Scenic
        o.O
        • Sep 2007
        • 2642
        ^lol
        And thanks
        Now I just need to find a suitable replacement.. all I've found so far were TO220, not TO252.. (or I'd have to order 1k of them..)
        edit: this kinda got me thinking if I could use a relay instead of that P-channel MOSFET.. (like other Samsung LCD TVs do)
        The PS-ON signal is 3.xV and from the looks of it, it switches one of two 13V rails
        • LLLlllou
          • May 2011
          • 201
          Originally posted by Scenic
          ^lol
          Too bad you don't live in the US:
          http://search.digikey.com/us/en/cat/...376381?k=40P03
          Um, nevermind, 2K minimum for TO252 version.
          • Toasty
            • Jul 2007
            • 4171
            In TO-220-
            eBay: http://stores.ebay.com/leemoom611
            http://www.ebay.com/itm/170744677931
            A little cutting and filing perhaps...?
            veritas odium parit
            • Scenic
              o.O
              • Sep 2007
              • 2642
              Making a TO220 MOSFET fit shouldn't be a problem really..
              And i found that exact seller too.. That's the only option I have atm apart from buying 1k+ of the damn things lol
              One strange thing though.. the auction you linked to doesn't appear in his shop at all on ebay germany. Only the 5pcs and up ones.. weird
              PS: I love using that -smiley.. fits me so well
              • Toasty
                • Jul 2007
                • 4171
                I would message him via eBay and see what can be done. Easy to set up a 'private' sale via eBay for just you.
                >>PS: I love using that -smiley.. fits me so well <<
                Yes! Your original avatar was a classic, kinda like JunkParts' Bobble-head Bill. But, since only the 'upper crust' can have animated ones now.......
                I attached it here so it will remain on the board.
                Cheers!
                Toast
                PS: What/who is the manufacturer? Or, the complete number(s) on the device?
                veritas odium parit
                • Scenic
                  o.O
                  • Sep 2007
                  • 2642
                  I can view that auction just fine with the link you posted, but that auction just doesn't appear in his shop at all when I go there from ebay.de instead of .com.
                  My orignal avatar (the blinking text smiley i think (?)).. well.. I found it was kind of annoying/distracting. That's why i replaced it.
                  No need to attach stuff. My webspace isn't going anywhere
                  I've been using it for well over 5 years now. No problems apart from some small hiccups (server maintenance)
                  As for the original MOSFET..
                  There's no logo or anything on it. Only 2 lines of text, which are very faint.
                  40P03-20
                  AA8OAX (the O could be a zero.. not sure)
                  I've tried taking a photo of it, but after about 50 of them which turned out to be just a more or less blurry pixel-salad, I gave up. Below is the best i could manage. Ironically, my cellphone cam gave me much better results than my digital camera, as I'm able to manually set the focus.. lol
                  It looks like there's an underscore below the "40" and the "20"
                  • Toasty
                    • Jul 2007
                    • 4171
                    >>No need to attach stuff. My webspace isn't going anywhere <<
                    Yup. But now it's part of the boards and I have it bookmarked for my use...
                    There are so many situations where that is appropriate. hehehe
                    Use the "Ask the Seller a Question" link in the 5pc auction. See if he'll do what you need.
                    Toast
                    veritas odium parit
                    • Scenic
                      o.O
                      • Sep 2007
                      • 2642
                      I've already bought the 40P03's from that chinese seller. However.. looking through his feedback it seems most of the stuff takes about a month or so to arrive. With christmas in between, I kinda doubt I'd get it before january
                      So I went looking for what i could get locally (and hopefully faster).
                      One thing that turned up was a Vishay SUD50P04-13L-E3
                      Compared to the 40P03 datasheet, the specs look "close enough" from what I can tell.
                      Drain-Source breakdown voltage is 40V instead of 30V, continuous Drain current is max. 60A instead of 30A (at 100°C it would be 43A instead of 18A), and RDS on is 22mOhm instead of 28mOhm.
                      And to top it off, it's TO252 (like the original) instead of TO220.
                      Would that one be a good substitute
                      I've attached both datasheets.
                      Last edited by Scenic; 12-16-2011, 04:13 PM. Reason: forgot the datasheets.. *facepalm*
                      • Toasty
                        • Jul 2007
                        • 4171
                        You can always put it in and see if goes *BANG!!*...
                        It looks okay as a sub.
                        The others to watch are:
                        t/d (on & off)
                        t/r
                        t/f
                        t/rr
                        In this case the t/d(off) is double for the 50P04, but the other 4 are better than or close enough. Even a 100kHz switcher (10,000ns) is slow compared to that number (60ns).
                        Toast
                        veritas odium parit
                        • Scenic
                          o.O
                          • Sep 2007
                          • 2642
                          I'd prefer not to damage it more than it already is :P
                          I've wasted enough time and money on that TV already.. sometimes thinking if i should just bash it to pieces with a bat for all the frustration it caused
                          I kinda doubt that MOSFET is all that's wrong with the PSU and I can pretty much forget about giving the TV to my mom for christmas anyways..
                          (I'm not like rich or something that I could just go and buy a (most likely crappy) new cheapo one for 350+euro (roughly 460usd))
                          • Scruit
                            MOSFET testing question
                            by Scruit
                            I am testing an NPD603AL (N-Channel Logic Level Enhancement Mode Field Effect Transformer) from an old Comapq Proliant 1500 CPU daughterboard. Symptoms are no post / no video, with only the psu / blackplane / cpu daughterboard and CPU in place.
                            First question: This is not explicitly listed in the datasheet title as a MOSFET, however in the description it states it uses D-MOS technology. I assume this means it's just a MOSFET, and the "logic level" means it only needs 5v gate-source charge instead of 10v. Is that correct?
                            I am testing this because...
                            04-10-2022, 07:50 AM
                          • Nooy
                            VGA MOSfet permanently shorted and loss of MOSfet pad
                            by Nooy
                            Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
                            I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
                            02-14-2024, 02:26 AM
                          • redbaron1007
                            Help identifying mosfet on Razer Blade RZ09 (CH570_MB_NT)
                            by redbaron1007
                            I have a Razer laptop (RZ09 MB# CH570_MB_NT) that has a shorted mosfet marked BND M03 E067 that I'm unable to find anywhere online. Does anyone either know what the part number is for this mosfet or have a schematic I can find it in?
                            Backstory on the whole thing the laptop was plugged into a lamp at a hotel. The lamp got unplugged while it was charging and now the system won't power on anymore. I found the caps around this mosfet shorted and when I injected voltage into the caps the mosfet got hot and my bench psu was pulling 5A. Pretty sure this is all that's wrong with the laptop...
                            09-09-2025, 11:10 AM
                          • AppleLover123
                            Asus X712EA 3 volts after the first mosfet
                            by AppleLover123
                            Hey guys,
                            i have a asus motherboard here and as the title says after the first mosfet (in the picture) there is nothing more than 3.15v.
                            I injected 19v and max. 1 amp at the charging port and there is not voltage drop or smth. It's just taking 19v and 1 milliamp.
                            Then i tried to inject 19v and max 1amp after the current sensor and there it first takes 19v and 4 milliamps and after 2 seconds it is taking nothing (no current).
                            I measured on the coils on board everything seems fine. Also the main power rail is not shorted (infinite resistance).
                            Now i thought something...
                            12-15-2024, 07:49 AM
                          • MicroSMD Lab
                            by MicroSMD Lab
                            I used the same replacement part (purchased from Mouser) and I'm certain the soldering was done properly since it took just as much effort to remove as before. What could cause this same mosfet to fail? I'm thinking if it was unsuitable then the others would fail too. I looked for similar failures on YTube and the mosfet was replaced with AOE6930 in one instance and AOE6932 in the other but it's possible that the...
                            01-10-2024, 06:36 AM
