Cheap cash register with a dead transformer
  • Toasty
    • Jul 2007
    • 4171
    Re: Cheap cash register with a dead transformer
    I understood that. Realize they won't run the reg, but battery backup in a sub-$100 register is just surprising. I've seen ones that cost $1,000 not have that.
    veritas odium parit
    • dood
      Deputy dood
      • Mar 2004
      • 2462
      Interesting.. I'm not familiar with registers at all. Didn't know that battery backup was that unusual.
      Ludicrous gibs!
      • Toasty
        • Jul 2007
        • 4171
        It's not that it is unusual. The fact it is in such a low priced unit I found unusual.
        Get it fixed yet?
        veritas odium parit
        • dood
          Deputy dood
          • Mar 2004
          • 2462
          Get it fixed yet?
          Yep, swapped the xformer out of one of the other registers, and all is well.
          One down, two more to go!
          Ludicrous gibs!
          • Toasty
            • Jul 2007
            • 4171
            R U DUN? It's THURSDAY!!!
            veritas odium parit
            • dood
              Deputy dood
              • Mar 2004
              • 2462
              Got the 2nd working... Actually ended up using the internals of the one I stole the xformer from. I really wish he just would've given me all of them at the same time... The 3rd one I got had dead keys, but even after I cleaned the circuits off, it was acting weird. All the keys responded normally, but it would freak out and blink the screen and run the receipt printer at random times. I took the keypad and transformer off of it, and transplanted into the other, which just had a few dead keys. So, he got 2 working registers back, and is happy
              He has a 4th register, so I hope to be able to make that one work too, but it's not the same model as the others.
              Ludicrous gibs!
              • Toasty
                • Jul 2007
                • 4171
                #27
                The freak out could be too much ripple on the line which the CPU beats with its own freq.
                -or-
                There's a margarita under the keyboard. Literally.
                Check those ribbon cables when you can. A little corrosion where it plugs in to power/logic board, or under one of the chips.
                Good job! Hope you were well compensated for the ER work.
                Toast
                veritas odium parit
                • riotpack
                  • Jul 2008
                  • 27
                  #28
                  Look at the V regulator on that heatsink and see what type it is 7805 etc. Look at the electrolytic capacitor voltage after the bridge rectifier and you should get a rough idea what the transformer voltage was. Say the Electros are 16V then you could assume the transformer would be 9VAC (9*1.414=12.726V DC) and not 12VAC as that would be greater than 16VDC. As for current, well the peak of course would be when that motor kicks in and from what I see and from the existing Xformer would be less than 1A peak.
                  Thats not a Fuhjyyu I used in your antec PSU its a HITACHI!! rofl lol lmao funni gui!
                  • dood
                    Deputy dood
                    • Mar 2004
                    • 2462
                    The one that was freaking out had been thoroughly doused with beer. The keyboards clean up easily with some water and alcohol (ironic), but I think the mainboard took a hit. Or at least shorted when the beer was applied, and messed something up. I couldn't see any physical damage to the mainboard, and I wasn't looking to put too much time into these by tracing circuits, etc.
                    I was compensated in the form of a few tasty craft brews...
                    Ludicrous gibs!
                    • riotpack
                      • Jul 2008
                      • 27
                      #30
                      I have seen liquids hide under ICs and remain conductive causing problems, sounds like noise getting into the logic(cpu) side of things and the high Z sections (like the Xtal) can easily be influenced by even high resistances. It doesn't have IC sockets does it? regardless it may be good to get some parts from
                      • double_DD
                        Transformer replacement for a dead coffee machine
                        by double_DD
                        Hi guys,
                        I have a dead coffee machine, and it seems that the culprit (no 1, at least) is a dead trafo - primary coil seems to be blown open (type shown on the picture below).
                        Now, I'm unable to find direct replacement anywhere on ebay or aliexpress, and all similar that I' was able to find are rated too low (<1A).
                        If someone knows a shop to buy replacement (EU/CH), that would of course be my 1st option.
                        My other ideas:
                        - to buy 220/20Vac trafo with 30VA, and to "manually" create secondary 12V output just via resistor
                        - to buy...
                        06-23-2025, 05:43 AM
                      • Wolf1977
                        dead transformer on ceramic oven
                        by Wolf1977
                        hi in ceramic oven the transformer is damaged
                        and writes
                        2x115v/2x12v/6VA 50-60hz ta105/f
                        can you suggest me a compatible transformer ;
                        i have found in 70 degrees celsius do you think is suitable for ceramic oven ;
                        09-02-2023, 03:43 PM
                      • learnmore
                        Help choosing replacement transformer for Levoit 600S SMPS
                        by learnmore
                        Hello Community,
                        I'm attempting to repair the SMPS on a Levoit 600S air purifier. The transformer is likely open. It has six pins. 2 pairs on the primary side (one pair tested open) and 1pair of legs on the secondary side. Legs on the secondary side are spread wide apart (end-to-end). I've circled them in blue. Dimentons of the transformer are 22x23mm. Marking on the transformer are EE16 1.9mH-B. Fuse for the powerboard is fuse 250V 3.15A. I've been unable to find an exact match and I'm hoping for some help here to find a suitable replacment.
                        Peace
                        LM...
                        11-04-2025, 09:35 AM
                      • ohren
                        Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
                        by ohren
                        Hello!
                        I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
                        Measured voltages with no load:
                        After rectifier diodes
                        12V: 6.17 V
                        5V: 5.67 V
                        Secondary transformer pins AC measurement (really don't know if this says anything)
                        12V: 2-2.5 V
                        5V: 1.04 V
                        I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
                        03-18-2023, 10:33 AM
                      • mikey5791
                        Is it possible for transformer substitution?
                        by mikey5791
                        Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
                        Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
                        My questions are
                        1. How do i test to see if the transformer is in good working condition?
                        2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
                        Hope you guys understand what i was asking. My intention is...
                        11-03-2022, 02:11 AM
