I am repairing the motor controller of my neighbors washing machine after it decided to self destruct once it had completed its cycle.
Theses motor controllers control a 3 phase permanent magnet motor
has 6 IGBT transistors two for each phase one upper and one lower
but has a common fault either the upper or lower short and when the controller turns the other half on... boom!
So I am wondering if I can replace this IRGBC30FD2 with a MOSFET.
I pulled out 2 IR840 out of a newer controller (phase3 model) not realizing this controller (Phase 1) used IGBT not MOSFET, So put the Mosfets in replaced fuse powered on, all good but no break or drive. Powered off checked .22Ohm current sense resistor it was open replaced it now the machine has break and drive but seems to be missing a lower or upper due to it is missing a step.
As the drum is rotating around 5 steps are good but one is missing, I am guessing one of the mosfets are not working (or drive circuit damaged) or one
of the IGBT transistors are open.
