Is the fuse Good?
+ More Options
Posts
  • alexanna
    • Mar 2010
    • 1346
    Is the fuse Good?
    I think everyone will like this.
    A friend of mine got his dad an electric stair lift.
    It was a used unit and when they installed it they had to cut the tracks for it to fit their stairway.
    It has contacts at the top and bottom of the tracks so it will charge a battery in the chair, the top contacts were not in the correct position so the dad tried to adjust them. Well he accidently shorted the contacts and had some really neat sparking going on for a short while.
    The mom and dad called in a service call, and after a short time the service guy said it needed a new circuit board, it was only $800.Well needless to say I got a call asking for help.
    He pulled out the board and brought it over for me to look at. The board didn't look fun, it had about an 1/8” of some kind of clear sealer all over it, there was no way to read any numbers on any components.
    Looking things over it had a glass main fuse with a piece of white ceramic center with a copper wire wound the length of the ceramic, Looking at the fuse it appeared to be intact. I am really glad I got the ohmmeter out. It was open and the $800 repair turned out to be around 75 cents
    Moral to the story even if it looks good TEST IT.
  • cadillacman
    • Feb 2011
    • 524
    Re: Is the fuse Good?
    i hear that.
    I work on alot of coin operated arcade games and stuff. Ive had more thn one fuse that looked good and was totally open or dropping signifigant voltage.
    In my case, its usually caused by poor contact of the fuse holder itself. Connection loose so it runs hot. melts the solder in the end of the fuse, tada open fuse.
    • alexanna
      • Mar 2010
      • 1346
      I was fortunate to be able to attend the GM 40HR. SET class, The instructors would have fuse that appeared good to the eye, They would then let you diagnosis the circuit.
      Us good guys would take the extra step and get the volt meter or test light out. Needless to say the people who just used their EyeBall took a long time to find it.
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        Had an application in the navy that used these fuses with pop-up indicators on the end to show they were blown.
        I ordered a 10-pack at some point and they showed up already popped [blown] as new in the box.
        Mann-Made Global Warming.
        - Dr Seuss
        • mockingbird
          • Dec 2008
          • 5484
          Question about failed fuses and resistors in a lot of vintage electronic repairs in videos I see on Youtube:
          These guys are often replacing 20+ year old resistors and mosfets on boards with caps that have most likely seen their best of days. They never take the caps out and test them properly out of circuit, rather, they just replace what has failed and not what has caused it to fail. I also see this on the sustain boards that the very reputable Koppel TV Repair sends out... Why bother reconditioning sustain boards with substandard capacitors?
          Why is this common practice among many repairmen?
          • Jack Crow
            It's a CLASOB!
            • May 2008
            • 823
            Guys,
            I owe my best interview in years to one bozo's inability to test a fuse.
            The job was to fix mountain top microwave radios.
            I was being considered because the guy that had the position ‘epic failed'.
            The story came to me like this.
            They hire a computer guy to fix microwave radio.
            So one fine day he gets a 'trouble ticket' to a site.
            Takes the company vehicle full of tools and spares up the hill, opens up the enclosure and sees that the equipment is dark and not working.
            He gets on the phone and calls HQ for ideas.
            They ask "did you check the fuse?
            There is a long pause and he comes back on the line and says 'it looks ok'.
            HQ asks did you use your meter and test it.
            He asks, what meter?
            This idiot did not last long.
            If all goes well I might get this job.
            I think I can manage this.
            Be well all.
            Jack Crow in VA
            "You are, what you do, when it counts"
            The Masso
            "Gravity, the quickest way down"
            Mayor John Almafi
            "You ever drop an egg, and on the floor you see it break?
            You go and get a mop so you can clean up your mistake.
            But did you ever stop to ponder why we know it's true?
            If you drop a broken egg you will not get an egg that's new?"
            MC Hawking
            • Th3_uN1Qu3
              Believe in
              • Jul 2010
              • 6031
              • Romania
              Because it gives 'em work every couple years.
              A working TV? How boring!
              • lti
                • May 2011
                • 2545
                That is the exact reason. More work means more money. Replacing an entire board when a component like a fuse is bad is another thing they do to get more money from the customer.
                I try to repair things myself because repair costs are too high or nobody would want to look at any devices I can afford. Even with such cheap devices, repairing them myself is cheaper than replacing them. That is why I repaired a boombox (which appears to now have a bad filter cap) and a 13" CRT TV.
                • alexanna
                  • Mar 2010
                  • 1346
                  Some good news happened!
                  The repair company called the older couple, and offered to discount the power supply by $100.
                  Well the wife explained that they already had it repaired by replacing the fuse.
                  The phone person for the company sounded surprised, but is going to send them a $85 refund for the service call.
                  Wonder if the Tech learned a lesson?
                  • jm1234
                    microwave rotary switch contacts go bad requently
                    by jm1234
                    Hi, I have a 11 year old microwave Siemens and the main function selector switch is a rotary type. It goes bad every few months, there are carbon (?) pads and the metal contacts that drive on them create concentric circle tracks from the residue.
                    I clean the tracks and the metal contacts with IPA and it works few months again. Here you can see the contacts:
                    Once I tried this contact cleaner: Kontakt 60 https://www.tme.eu/Document/3f58feb2...TAKT60.DTE.PDF, but it only lasted few weeks, so probably not a good choice.
                    Is there any...
                    05-04-2025, 10:45 AM
                  • jesterace
                    Samsung UE46ES8000 Blown fuse but no other signs of short
                    by jesterace
                    Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                    09-11-2024, 03:14 PM
                  • jshhh
                    Help replacing fuse on my Mimaki CJV300-160 vinyl printer
                    by jshhh
                    Hi guys,
                    I'm inexperienced with electronics repairs, I've done a little bit of soldering caps and whatnot, but i have a blown fuse on this mimaki printer I got which I have bought a replacement for.
                    How do I remove this type of fuse (see picture)...it kinda looks like it would pull out of that bracket but it didn't come at first pull and I didn't want to brute force it incase it's soldered on there like most of the rest of the components.
                    Anybody know how to remove this type of fuse?
                    (The fuse is toward the bottom of the image labeled F2)...
                    06-17-2025, 01:35 AM
                  • Babbar
                    by Babbar
                    04-12-2024, 01:12 AM
                  • drykid
                    Matsui 175S microwave fuse replacement
                    by drykid
                    I recently picked up a used Matsui 175S microwave that was powering up (starts, turntable rotates) but not heating. From looking online the most likely culprit was the fuse, but unfortunately in this one the fuse had heated up and fused with the (badly designed) fuse holder and couldn't be removed. I guess this might indicate further issues beyond the fuse itself but at this stage I just want to replace the fuse and see how I go from there.
                    Anyway since I couldn't get out the fuse itself the easiest fix was to replace the fuse holder assembly that runs between the...
                    12-21-2020, 01:15 PM
