Netgear ADSL router DG834
  • midibob
    • Nov 2008
    • 285
    Interesting problem with this router. The device was emitting a strong hash around 3.68MHz and also at some other frequencies above 4MHz. As this is in the middle of the amateur radio band it was annoying to say the least.
    Sniffing around with a small coil attached to my receiver I found the noise was predominantly coming from the wall wart and the rear of the router where the power connector was.
    The wall wart feeds 12v AC to the router where it is rectified with a bridge and smoothing cap, so pretty standard.
    Putting a ferrite choke on the power lead reduced the symptoms a little but nowhere near enough.
    With scope attached to the smoothing capacitor the waveform was horrible. Loads of spikes and all sorts. Looking at the smoothing cap I noticed it was a 2200uF Teapo!! Oh dear!
    Changed the cap out and the reduction in noise and the waveform was very noticeable. Also I added a 0.2uF across the smoothing cap and that completely eliminated the noise.
    On testing the Teapo the ESR was fine and the value, on my cap tester, showed to be correct too?
    Anyone care to try and explain that one?
    Midibob
  • ipman
    • Jul 2011
    • 159
    Re: Netgear ADSL router DG834
    A high capacity electrolityc capacitor will not filter that high anyway, no matter which ESR have.
    If I were you, I would have tried the clasic 0.1 microfarad or even bellow.
    • midibob
      • Nov 2008
      • 285
      I would tend to agree but the difference in noise output between the two caps was very noticeable. I did originally try the 0.2uF across the Teapo but it was nowhere near as effective.
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        As you didn't mention what series the Teapo was or what you replaced it with I'm assuming a lower ESR helped the High Freq a tiny bit more than the Teapo could.
        As you found a 2200uF doesn't do that much at all for higher frequencies.
        It's probably coming into the wall wart through your wiring.
        Might be a POS power supply with no input filter [on about anything] or a local radio station. Could be a lot of things.
        Mann-Made Global Warming.
        - Dr Seuss
        • midibob
          • Nov 2008
          • 285
          The Teapo is marked up as :-
          SC105c
          08/03
          A3
          I don't know what the SC or A3 mean as I haven't looked into it.
          The interference was generated by the router and obviously used the wiring to the wall wart as an aerial.
          The good bit for me was changing the cap (I can't remember what the replacement was, it was just one I happened to have in stock and used to substitute) the interference from the router was greatly reduced and completely eliminated with the addition of the 0.2uF cap. Just don't understand why the Teapo should have been that bad considering the ESR reading?
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            SC is the series.
            A3 is a lot number or something.
            2200uF Teapo SC come in lots of sizes.
            - Dr Seuss
            • ay_erdi
              Netgear R7500 Router Dead
              by ay_erdi
              Hi everybody,
              My router netgear R7500 is dead.There are four burnt components inside.Can you help me identify?
              VR8-U17-U78...
              02-16-2024, 10:58 AM
            • double_DD
              Why does my ISP router hate my "homemade" power supply??
              by double_DD
              It's gonna be a long intro, so please buckle in, as it's a problem that's been bugging me for several days now. Thanks in advance.
              So, I have 2 modems/routers, whatever the proper nomenclature is, one from ISP and one mine. I want to power them via USB-C rather then their original mains adapters (for reasons, that are hard to explain to sane people). Both routers come with 12V/3A mains adapters.
              For this purpose I acquired USB-C charger with 250W and 5 ports, 2 of which can supply max 20V/3A. Since 12V isn't a standard PD voltage option (and to future proof,...
              07-12-2025, 03:09 AM
            • EasyGoing1
              UPNP, "Standards" and hardware that implements it
              by EasyGoing1
              I've been writing a program in Java that is really just a robust front end for the use of GitHiub Gists, providing a nice interface for developers to organize, maintain and access code snippets that we tend to need from time to time in our different projects.
              One of the features of the program is the ability for people to share their Gists with others who use the program over a LAN or over the Internet. The program just basically serializes a Java class and encrypts it then wraps it into a UDP datastream and sends it over to another user.
              So I decided to implement UPNP...
              07-16-2022, 07:12 PM
            • tony359
              by tony359
              11-28-2023, 05:18 AM
            • MegaZAC
              Onkyo TX-SR805 noise in one channel
              by MegaZAC
              Surprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
              Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
              There's some logic behind it. As soon as I select an input I get only left...
              04-23-2025, 10:09 PM
