I love repairs like this
    I bought an Xbox 360 for £35 because the disk tray was jammed.
    Solution: take the case off and tweak it up slightly.
    I didn't even need to replace the DVD drive, so that saved me £18.
    I left the case off for now until I can properly fix it, but I'm not bothered about replacing it.
    Works perfectly, could hardly disagree with the price!
    The TV also was a dumpster find for just £20 and £5 to fix the caps.
    FFXIII works very well on it .
    Home cinema system total cost just under £100. (5.1 system was free.)
  • Rulycat
    • Apr 2010
    • 724
    • United Kingdom
    Re: I love repairs like this
    Wow. Now that's epic scavenging. Is this the early gen one that had a high RROD rate, are you going to perform the clamping mod? (where you change the clamp used for the GPU cooler or something so the solder doesn't melt out of place)
      It's almost 5 years old, you think it will go before too soon even though it survived the rest of its life?
      • Rulycat
        • Apr 2010
        • 724
        • United Kingdom
        It could. My brother had two fail on him.
          Any idea to tell which models are affected?
          • Rulycat
            • Apr 2010
            • 724
            • United Kingdom
            I'm not sure. They kept shrinking the chips and newer ones are ok. Have a look on wiki and it might tell you.
            • 370forlife
              Large Marge
              • Aug 2008
              • 3112
              If they have an HDMI port on the back and a little heatpipe coming from the gpu heatsink to just in front of the cpu heatsink, they are less likely to fail. I say less likely, as they still do.
              • Agent24
                I see dead caps
                • Oct 2007
                • 4963
                • New Zealand
                I got a DVD drive once for $1 because the owner had dismantled it for some reason and couldn't put it back together.
                Took me about half an hour to figure it all out and it's still working to this day
                -David VanHorn
                  No luck...
                  It doesn't have HDMI, only component and composite video.
                  Similar stories with old computers that people don't want to clean up - HDD formatted, new install of Ubuntu or XP... done.
                  • mockingbird
                    • Dec 2008
                    • 5484
                    Looks like you have a Xenon. Which DVD drive do you have? It is the TS-H943?
                      TS-H963 made by Toshiba-Samsung.
                      • ImpossibleRepairs
                        Pad repair
                        by ImpossibleRepairs
                        Howdy good peoples;
                        looking for some advice on Pad repairs, want ti expand my skills
                        Working on a HP board that went for a swim; There was a short in what appeared to be the Data IC (there was corrupted data that we recovered) ;
                        First picture is the donor Board, clean removal;
                        Second picture is board im working on; As soon as I started prepping the pads to re work the IC, the damage started;
                        As a side note, Im using good equipment M series Thermal tronics iron with a 1.6m tip; Good quality locally produced flux, good quality...
                        05-11-2024, 05:19 PM
                      • Andriy Andrusyk
                        How to Identify My GPU When CPU-Z and Physical Labels Disagree?
                        by Andriy Andrusyk
                        I recently bought a used GPU that was advertised as an MSI GeForce GTX 1080 Ti. The backplate label also identifies it as a GTX 1080 Ti, and the label looks untampered.
                        However, when I run CPU-Z, it detects the GPU as a Radeon RX 480.
                        I inspected the PCB and found a second label near the gold connector reading: V341 VER:1.1 From what I've found online, V341 PCBs are typically used for Radeon RX 480, while GTX 1080 Ti cards usually use a V360 PCB.
                        Is it possible the card was BIOS-modded or relabeled? What's the most reliable way to verify the actual GPU model I have?
                        05-13-2025, 01:32 PM
                      • KYBOSH
                        Creating a Testing Jig for TV Repairs -
                        by KYBOSH
                        I was watching a YT episode from Nick's TV Repair and he literally had a test jig comprised of all the internal components of a TV on a wooden board.
                        I thought that was amazingly smart as I always thought that TV repair businesses had a room of various actual TVs they would use to do testing.
                        My question is how was he able to connect this generic looking external display to the jig? The connectors are intentionally covered up by cardboards so we cant see it but i wonder if its a custom in-house device or something that could be purchased online?
                        04-29-2025, 10:22 PM
                      • stormanimal83
                        somebody familiar with hasboard repairs? BM1397AD interchangeable with Bm1397AG ? S17+ and T17+
                        by stormanimal83
                        i got myself a complete Antminer T17+ with 3 dead hasboards for a very good price.... for parts i bought S17PRO boards.... i replaced all missing resistors and changed some asics because they were bad... but wihout a tester... i used the miner instead and changed firmware to awesome miner firmware for better and faster diagnoses via miner log and lower fan speed...
                        for my understanding and what i read on the internet these asics should be interchangeable in one chain but in my case i´m getting no more communication to none of the asics on all 3 boards. 2 of the boards weren´t in...
                        04-13-2025, 04:26 AM
                      • LeeBa
                        ASUS ROG Zephyrus GA401IV - It won't start - voltage present after repairs
                        by LeeBa
                        please I have this APL6012 circuit on my NB defective - it heats up. I soldered it but the NB still won't start. All voltages are present - except for battery charging.
                        The NB can be turned on, the keyboard lights up, the current consumption is slightly over 1A. All voltages are present. But nothing happens. It's just that as everything heats up, the current slowly increases.
                        Should the NB turn on without this circuit or does it need it to start? I don't know if that circuit communicates with the EC.
                        Thank you very much for your responses.
                        Libor​...
                        12-28-2024, 10:20 AM
