Pad repair
  • ImpossibleRepairs
    • 27
    Pad repair
    Howdy good peoples;
    looking for some advice on Pad repairs, want ti expand my skills
    Working on a HP board that went for a swim; There was a short in what appeared to be the Data IC (there was corrupted data that we recovered) ;
    First picture is the donor Board, clean removal;
    Second picture is board im working on; As soon as I started prepping the pads to re work the IC, the damage started;
    As a side note, Im using good equipment M series Thermal tronics iron with a 1.6m tip; Good quality locally produced flux, good quality 1.5mm wick, and high grade 63/37 C18 wire, With proven technique, I'm going to assume this damage started when the chip failed;
    I do know of some techniques, have fixed holes through boards, done simple track repairs, but this is just a whole
    new level for me ? ( understand the solder is flowing over exposed board on the copper and this is probably all just going to ground, im too anal to let something like tha out of the shop; So would love to hear how you would fix this;
    please and thanks as always
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8351
    Comes from not using leaded solder first with a combination of not enough heat. Easy this one. Scratch the remaining trace so the copper is visible, solder the component on one pad and take a thicker wire straight over from the trace and pad to the missing pad and solder the component to it. Then put a dab of conformal coating, or green PCB paint over it.
    Sure there are other methods like cutting the pad of the donor and glueing it to the other board etc… but that's a lot of effort for this that doesn't get paid.
    • ImpossibleRepairs
      • 27
      Ok yep so before I clean on a Lead free board, use lesd solder first like as if I was doing a through hole removal and clean; Makes sence;
      The IC is a QFN series might have to try and use that donor board; I could be wrong; I like that method for J leg types thats tops;
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8351
        Unless there is a lot of dirt on the board, I don’t clean it before component removal. I clean the spot before component replacement once the bad parts have been taken off the board.. After the repair is done I either clean it good with 99% IPA and a toothbrush, or stick it in my ultrasonic cleaner.
        Some old solder on the boards specifically if they are oxidized, you need to flux and add new solder, before taking anything off…
        If you just use more heat of the hot air, you risk delayering the board. Yes, the traces with the green stuff come off the board itself and make a big bubble. Sometimes the SMD component is glued to the board. Keep that in mind. There are so many ways to damage a board, it’s not funny.
        • ImpossibleRepairs
          • 27
          By Cleaning, I guess I should have worded it differently;
          I was removing the old solder before re tinning the pads; I cleaned the oxidisation after hot air removal of the chip; I re fluxed, then used wick, didn’t move around etc etc, didn’t try and lift the iron then the wick none of it; I’ll make a point of adding more tin lead first in future, saves the risk of extra damage I guess;
          Ive obviously done something wrong, one of those things that will mess with me until I work it out lol; Im still going to partly blame the chip; it has failed after all 🤣🤣
          I appreciate your time advice; 👍
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8351
            That ripped off pad is in a very convenient location. There are much dumber locations to deal with. But as long you got one solder pad to solder to you are golden. Trickier it becomes once you got no solder pads to solder to.
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
            • howardc64
              by howardc64
              Problem
              08-04-2024, 10:36 PM
            • ohren
              Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
              by ohren
              I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
              I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
              The models launched in 2018 and 2019 respectively....
              09-08-2023, 05:24 PM
            • howardc64
              by howardc64
              07-24-2025, 05:17 PM
            • m1ch43lzm
              by m1ch43lzm
              05-12-2025, 08:37 PM
