Comet Triplexer CFX-514 Repair Notes
  • Jack Crow
    It's a CLASOB!
    • May 2008
    • 823
    Just finished working on a failed CFX-514.
    Back Story
    A triplexer is a filter device that allows different bands of radios to share a single antenna.
    In this case a Ham 6M (52mhz) Ham 2M (146mhz) and a Ham 70CM (445mhz).
    This radio stack was located at a friends tower site.
    One day when I went to turn on the stack the 2M and the 6M units did not work well, UHF was mint.
    When I jacked the antenna directly into the radios they worked just fine. Had a huge loss in the triplexer, and it is rated for a fraction of a dB.
    Took it home.
    Just got around to messing with it.
    Checked it with a sig gen and a spec an. Had about 30dB losses in the two bad paths.
    Did some DC checked and those showed shorts where there should be none.
    Took out four caps and one coil and the shorts went away.
    Tried to measure the caps and those showed no shorts.
    Replaced them with new parts since I had them out anyway and carefully re installed the coil.
    Now the unit works like a charm.
    Suspect a mechanical failure rather than an electronic one. Some painted or internal area of the filter wore out and made contact with the circuit board parts. The space in the case is tight and a little bit of slop in installing the parts may have been all it needed to punch through, short, and fail.
    A lesson in how not all electronics problems are caused by electronics parts but mechanical issues.
    Be well all.
    Jack Crow aka Radio Mike in VA
    "You are, what you do, when it counts"
    The Masso
    "Gravity, the quickest way down"
    Mayor John Almafi
    "You ever drop an egg, and on the floor you see it break?
    You go and get a mop so you can clean up your mistake.
    But did you ever stop to ponder why we know it's true?
    If you drop a broken egg you will not get an egg that's new?"
    MC Hawking
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: Comet Triplexer CFX-514 Repair Notes
    had one of those a while back that failed short due to a solder ball.killed the sav17 2m pa in the customers standard c5900.lots of lousy soldering in there.if it was branded mfj it could believe it.this happened when the rig was new and just out of warrenty.$950+ for the 5900 in 97.customer was pissed.it sat in a drawer till now.
    • Jack Crow
      It's a CLASOB!
      • May 2008
      • 823
      KD8ADU,
      Now that is an expensive way to do things.
      Lots of things can 'take out' an amp but this one is an irritant for sure.
      I use a bunch of plexers for a lot of different tasks.
      Mostly for 6 and 2M stuff.
      Seems a 5/8ths antenna on 2M makes a fairly good 1/4 wave on 6m.
      You may not know that I make a lot of APRS tracker radios for clients.
      I take old two way radios (Midlands) and convert them up for Ham service. Then add the mods to make them work with APRS trackers.
      Been working on an experiment to open up a new band for APRS, in this case 6M on 50.62mhz. This is Bob B's idea WB4APR.
      At this point we have two big digi's in the area. One co located with WA4TSC/R (-6) that covers very well.
      NV4FM (-6), that gets most of Fairfax County Virginia.
      Back to duplexers for a moment.
      On my car KA2ZEV-6 and KA2ZEV-8 I have the two trackers sharing one GPS input signal and one antenna. This works great.
      Just a note, for radios I do not intend to sell I use the 'ugly' parts.
      My for sale units are much nicer.
      http://www.flickr.com/photos/9010884...7626491727033/
      The above link will take you to a photo of the 6 and 2M radio with the shared GPS signal ribbon cable and the diplexer.
      In my truck I have the shared GPS data deal but seperate radio antennas.
      Look up KA2ZEV-5 and -9.
      Even numbers for the car, odd numbers for the truck.
      In the case of the truck's voice radios, they share one antenna. Have a
      70-0375C set up for 6M and a
      70-1495B set up for 2M.
      Each one makes 110 watts. So a good diplexer was required.
      Never had an ounce of trouble with this set up.
      Use one more on the desk stack here. Using one of the tri plexers.
      Have an 80 watt VHF and a 40 watt UHF radio, plus a real odd ball.
      There is an experiment being run out of the other side of the state. A guy has an experimental permit to run 3kW on 70.005mhz CW. Set up an old Mid Band radio for that and all I get are spurs from various computing gadgits.
      If life was easy.
      Be well there.
      Herndon VA
      The Masso
      Mayor John Almafi
      MC Hawking
      • smason
        • 1652
        I have a Comet Diplexer kicking around somewhere. Used it to go with a dual band antenna on my Alinco 590 which has seperate VHF and UHF connectors.
        I always thought they were fairly good quality. Better than anything from Mostly F__ing Junk.
        I just started playing around with a Tinytrak4, cool little unit.
        • Jack Crow
          It's a CLASOB!
          • May 2008
          • 823
          Sam,
          If your interested I have 'articles' on how to make the most of the TT4. How to test with it to get the variables lined up to optium.
          Catch me here or off list at
          ka2zev@yahoo.com
          Be well
          Mike aka Jack Crow
          The Masso
          Mayor John Almafi
          MC Hawking
          • kc8adu
            • Nov 2003
            • 8832
            • U.S.A!
            even with the best stuff a dud sneaks out occasionaly.
            the customer bought the rig and triplexer at r&l at the same time.the triplexer waited till just over a year to kill the pa.and it didnt just crack.i can fix cracked pa modules.it killed the final.
            oh well the rig needed all the sm lytics replaced anyway.all c5900's do.and some white led's in the display so the bulbs dont cook it.now its what it should have been when new!
            • shelby5041
              clock radio / radio lifespan?
              by shelby5041
              hi
              ive got a modern digital clock radio approx 15yrs old
              my question is how long can a clock radio or a simple radio last ss farcas operating hours?
              since elec components have limited hour lifecspan i would imagine the radio or clock radio would eventually fail.
              the reason i ask is because i have my clock radio on radio function 24/7 for the past 7 years and its still working fine....i leave the radio on ..never turn off past 7years...thats approx 60000 hours
              it uses very little power just a few watts i would imagine that may have something...
              09-14-2024, 03:30 AM
            • UserXP
              Vintage SONY Digital Clock Radio ICF-C12W no audio
              by UserXP
              Dear all,
              I have this old radio clock by Sony from the early 80s, I guess. The clock display works, but is dim, the function board appears to be OK - but the radio unit shows no signs of life. It doesn't produce a single noise, crack or anything from either FM or AM band. It's like it doesn't even power up.
              i opened the radio and it is full of some TRACON gray capacitors. They only have their negative strip printed, voltage and capacitace markings - no series, no temperature marking, nothing else.
              My question is, do you know of this brand of capacitors and how bad are...
              07-21-2025, 08:35 AM
              HP EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point EliteDesk 800 i7-7700T Specification for Upgrade or Repair
              This specification for the HP EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point boardview and EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information....
              09-12-2024, 02:00 PM
            • Omron
              Kenwood KDC 3051G Car Radio permanently stuck in Demo Mode please help
              by Omron
              Hello Guys! I have trouble with my car radio Kenwood KDC 3051G I hope someone more knowledgeable can help me, I tried everything in my power that I stumbled upon online.
              My radio is permanently in demo mode, it says Press Volume Knot Cancel Demo and when I press it nothing happens.
              - Tried to unplug radio and plug it back in into power,
              - Tried to reset radio by holding reset button key for 5,10,30 seconds while in power and without power, plugging it back in, it wouldn't work.
              - Tried to hold 3,6 while turning it back on and then pressing 1,2...
              05-23-2024, 01:27 PM
            • BOSCHNJAK
              by BOSCHNJAK
              ABOUT ME INTRODUCTION FILE
              2
              024 BEV, BIH, SARAJEVO START PROJECT: ELECTRIC VEHICLE TOYOTA 4 RUNNER CONVERSION http://www.bev.ba/TOYOTA4RUNNER/index.html
              2023 BEV, BIH, SARAJEVO START PROJECT: SECRETS AND MANUFACTURING PLANS (AS MY REPLICA) OF THE LIBERTY ENGINE 2.0.
              2022 BEV, PROJECT ?
              2021 BEV, PROJECT ?
              2020 BEV,BiH, Sarajevo: PROJECT IS: HOW TO SWITCH OFF PERMANENT MAGNET FIELD and HOW TO SWITCH ON PERMANENT MAGNET FIELD?
              2019 BEV, Croatia, Ston:, Broce: PROJECT - PROJEKT ELEKTRIČNI GLISER http://www.bev.ba/ELEKTRICNIVANBRODSKIMOTOR/indexHR.htm...
              12-28-2023, 02:09 PM
