HV wire
  • timelessbeing
    • May 2011
    • 32
    Re: HV wire
    The glue was barely touched. The short actually carved a path through the PCB.
    The inverter was overdriven by 2V or so. Would that have contributed to the arcing?
    • Pyr0Beast
      • Feb 2009
      • 406
      Re: HV wire
      Yes it would have.
      • timelessbeing
        • May 2011
        • 32
        Re: HV wire
        The inverter input should be between 11-12V. Since I am using it in an automotive application, voltage can vary between 11 and 14V. By my calculations, a 5.6Ω ballast resistor should even it out.
        • timelessbeing
          • May 2011
          • 32
          Re: HV wire
          Ugh! More arcing... this time between the black box and the white connector. This high voltage stuff is tricky.
          • timelessbeing
            • May 2011
            • 32
            Re: HV wire
            kinda sucks not being able to edit entries...
            So I removed all the carbon, thoroughly cleaned the board with solvent, put on several coats of laquer, and surrounded with silicone, plugged it in and ... instant arcing. Bah!
            Then I removed ALL the added material down to bare board and leads, plugged it in, and it is completely stable. Nota bene, air is the best dielectric.
            • emeskay
              Lenovo Yoga 710 15ISK, 80U00002US battery cable wire broken.
              by emeskay
              We have an Lenovo Yoga 710 15ISK that we use as a secondary laptop. To cut a long story short, around May 2023, while traveling, I connected the laptop into an electrical outlet that was already switched on. Something made a "pfft" sound and the laptop refused to turn on after that. After getting back home, I gave the the laptop for repair to an informal repair person. He replaced the adapter and an internal motherboard part, but after he returned it I noticed that the LCD did not look normal. Essentially, every alternate horizontal line on the screen had gone missing. The laptop was...
              08-06-2024, 07:13 AM
            • technicalspecialist
              Vintage fan repair, copper wire question
              by technicalspecialist
              I currently have a customer's vintage fan on the work bench to repair.
              It uses an induction motor with 4 poles. One of the poles is open.
              I couldn't find the break so i cut off the original wire.
              I have measured the other poles and the resistance is about 28 ohms per pole and I measured the diameter of the wire with my digital calipers and it is 0.35mm in diameter.
              I need to work out how much 0.35mm diameter enamelled copper wire i need to order for it to be 28 ohms. I have used this calculator and it says i need 160.35 metres.
              The enamelled copper...
              03-16-2023, 12:54 PM
              Heater element wire type instead of a fuse when troubleshooting a short circuit DIY
              by sam_sam_sam
              I was Ollie today which is a close out / surplus outlet store I do not go in there to often because you find things that you should not be tempted by but that is a another story
              I saw a small space heater that used a wire type of heater element which I been looking for a while but not really hard mind you but when I saw this I grabbed it I going to go back tomorrow and buy the last one that is like the one I bought today because I need the heater element and the ceramic insulators and more of heat element wire because this one has two different wattage settings one 1300 watts ( tap...
              12-16-2023, 08:39 PM
            • kalemaroni
              Dell DC Brown wire
              by kalemaroni
              There are 3 pins on the back of this DC jack. Centre both left and right edges are the grounds for the black wires and a centre bottom is for the red wire. Where does the brown wire solder to? ...
              08-26-2025, 10:10 AM
            • GlenBrim
              1070 GPU. DVI port removed, wire in its place, why? Stuck on low clocks too.
              by GlenBrim
              I got this recently as-is. Gigabyte 1070 video card.
              DVI port is removed. I don't know why.
              A wire is soldered across two spots where it looks like the DVI port was. I don't know why.
              I've read of people simply ripping out DVI ports and the rest of the cards still working fine. Never read anything about soldering a wire in there for some reason.
              The card seems to work fine, except it's stuck in low clock speeds. While starting a game or benchmarking, the clocks may momentarily increase to around where they should be, then goes way back down and stays...
              02-14-2024, 02:08 AM
