2r55a
  • mike9h29
    • Mar 2011
    • 60
    2r55a
    Can some one give me equivalent to SCK 2R55A please?
    I Think it is a NTC Thermistor (I found this info from a post on this site!)
    Mario
  • Toasty
    • Jul 2007
    • 4171
    Re: 2r55a
    SCK-2R55A
    2.5Ω - Zero power resistance (25°C)
    5A - max steady current
    120mΩ - resistance at max current (25°C)
    -40 to +170 °C - operating temp range
    veritas odium parit
    • mike9h29
      • Mar 2011
      • 60
      Re: 2r55a
      Originally posted by Toasty
      SCK-2R55A
      Thanks for the info.
      I am trying to source this part, but I cant find it on ebay.
      Is there any other part number that is equivalent to this part please?
      Mario
      • Toasty
        • Jul 2007
        • 4171
        Re: 2r55a
        Using those specs, try DigiKey or Mouser.
        Inrush limiter
        I found 1 that is close.
        Hint: be a little "loose" with the specs.
        veritas odium parit
        • mike9h29
          • Mar 2011
          • 60
          Re: 2r55a
          Inrush limiter
          Thanks. Will check again.
          Is it normal for these to crack when there`s a surge?
          I was testing a TFT PSU that was blowing the fuse every time.
          I fried 5 fuses before I found out that the bridge rectifier is shorted!
          Then I found this part cracked.
          Mario
          • Toasty
            • Jul 2007
            • 4171
            Re: 2r55a
            heh
            No, it's normal for these to crack when there is a problem... They are in -series- with the hot side (or should be...) of the mains.
            That's why you should be using this circuit to test before fully applying line power. Saves a box of fuses.
            If the light comes on full and stays that way, then there's something wrong on the mains side.
            If it comes on briefly and goes dark/dim (I use a clear bulb), then the mains side is probably fine and the problem lies deeper in the supply.
            Toast
            veritas odium parit
            • mike9h29
              • Mar 2011
              • 60
              Re: 2r55a
              heh
              Toast
              Wow!
              Many thanks for your help.
              Will use the bulb to test psus in the future.
              Mario
              • Toasty
                • Jul 2007
                • 4171
                Re: 2r55a
                Just change the bulb wattage or add another in parallel to increase the current allowed. Some bigger (wattage) supplies need more *oomph* to get started.
                Did you find the replacement (it was at DigiKey).
                veritas odium parit
                • mike9h29
                  • Mar 2011
                  • 60
                  Re: 2r55a
                  to tell you the truth I did not had time to search for it at Digikey today. Hopfully I will search for it tonight.
                  I have another small question regarding electronics. maybe you can help me please?
                  What is a starting capacitor or resistor please?
                  Mario
                  • Toasty
                    • Jul 2007
                    • 4171
                    Re: 2r55a
                    >>What is a starting capacitor or resistor please?<<
                    In what type of device?
                    veritas odium parit
                    • maybenever
                      • Dec 2010
                      • 158
                      Re: 2r55a
                      In the old days of fuse boxes, my Dad would screw a bulb in place of a fuse, then take the circuit apart until the light when out.
                      No one but he and I could seem to understand it.
                      • Toasty
                        • Jul 2007
                        • 4171
                        Re: 2r55a
                        Either you lived in an old house.......
                        .....or you've just severely dated yourself...
                        veritas odium parit
                        • mike9h29
                          • Mar 2011
                          • 60
                          Re: 2r55a
                          In a switch mode psu.
                          • Toasty
                            • Jul 2007
                            • 4171
                            Re: 2r55a
                            The startup resistor would be what gets the main switcher going until the PWM control circuit can take over. That can only happen if there is sufficient voltage to drive the PWM chip. Its a power resistor that is connected to the base/gate of the main switcher.
                            Startup capacitor in smps keeps the PWM controller running (stores energy) until the power fully comes up.
                            veritas odium parit
                            • mike9h29
                              • Mar 2011
                              • 60
                              Re: 2r55a
                              Thanks again for your detailed reply!
                              So, I have a monitor (I posted in the monitor section already), that works fine if I switch it on 1 second after I switch the wall socket on. But, If I switch the Main Socket on and leave the monitor off for more than 5 seconds, it will not switch on.
                              Could this be a Startup Capacitor / Resistor issue please?
                              Mario
                              • Toasty
                                • Jul 2007
                                • 4171
                                Re: 2r55a
                                Not familiar enough with monitors to venture a guess. You need to continue the discussion that you started over there. From what I read, a bad regulator or something on the logic board makes sense.
                                veritas odium parit
                                • nmbb
                                  Can not find Model/Value of Thermistor.
                                  by nmbb
                                  Machine: Autoclave.
                                  Brand/Model: SANYO MLS-3780
                                  Manual: (Sorry search option not working on this PDF)
                                  Hello guys, this autoclave running with 2 thermistors already connected TH1 and TH3(on CN1,CN2 sockets). One for the water temperture and second one for chamber temperature. But there is another emtpy socket for optional third thermistor CN2 wich is for TH2 for object temperature. I wanna add the third thermistor TH2 to CN2 socket. But i can't figure what model/brand/value i need to use. In manual document, there is no info about TH1 and TH3 model number...
                                  06-02-2022, 05:55 PM
                                • Use2bavolvo
                                  Magic chef oven - thermistor ref voltage issue
                                  by Use2bavolvo
                                  I am having an issue with my wall oven temperature control is ~180f out of spec. The thermistor is measuring correctly but I noticed the ref voltage appears to be off. With the thermistor wires attached it's reading ~3.4vdc with the thermistor disconnected it's around I9.8vdc. my understanding is the temp is read off the resistance from the thermistor which leads me to believe the issue is with the ref voltage.
                                  Another observation is the temp setting and readout at lower temps is way off meaning the oven thinks room temp is 300f and bake relay doesn't engage unless temp setting...
                                  01-19-2023, 01:32 AM
                                • Quantum IC
                                  Sony KDL-40BX450 LCD. Thermistor gets too hot 10 seconds after turning on the TV
                                  by Quantum IC
                                  Hello every one,
                                  This TV came to me with the problem that it was totally dead.
                                  The problem was the two MOSFETs and a fuse resistor in the power supply.
                                  The original MOSFETs were KF7N50F and I repalced them with SLF65R700S2.
                                  The original fuse resistor was 0.1 Ohm 1/2W. I didn't find a similar fuse resistor and I replaced it with 0.1 Ohm 5W ceramic resistor.
                                  When I plug the TV the ST-BY LED turns on, when I press the power button on the TV, the ST-BY LED turns off and the TV doesn't turn on until the second time I press the power button is when the TV turns on,...
                                  01-14-2022, 12:06 AM
                                • fab13
                                  Thermistor exploded in two when turning on ps4 fat
                                  by fab13
                                  Hi there,
                                  I have a fat PS4 with the fuse (5a) of the power supply which blows with each power on and there was a loud snap in the power supply and again the same problem after replacing the fuse.
                                  I did not find a short circuit
                                  The component that broke in two is an SCK 084 thermistor (See photo)
                                  and measured at 11 ohm
                                  So far I haven't received a thermistor.
                                  Do you think that if I replace the thermistor and the fuse it should go away, because I have the impression that there is a strong current demand as soon as you press...
                                  11-05-2022, 06:29 PM
                                • magneh
                                  Motorbike PCB - burned Diodes ( PJ78) - help to identify identical or equivalent
                                  by magneh
                                  Hello everyone
                                  Got a motorbike PCB that had 3 burned diodes.
                                  The smaller ones have the marking PJ78 GS1M
                                  And one larger one PJ78 GEX
                                  Can someone help me identify them so I can be able to replace with same or equivalent?
                                  Photos attached
                                  Apreciate !
                                  Thank you...
                                  05-19-2025, 07:38 AM
