CD Servo Board with unusual problem
  • japlytic
    • Oct 2005
    • 2086
    I am planning to repair the CD servo board on a Kenwood RXD-G2 hifi system. The problem is that the sound is distorted on the outermost tracks on the CD (it is not over 74 minutes). There are a couple of Jamicon capacitors; nearly all of them are below 1uF. Should I replace all of the electrolytics 4.7uF and below with tantalum or polyester units?
  • linuxguru
    • Apr 2005
    • 1564
    Re: CD Servo Board with unusual problem
    I have a similar issue (drop-outs near the outer edge of a CD) with a Technics SL-PD867 5-CD changer, but only with some CDs - I think it's probably dust on the lens or CD.
    • dood
      Deputy dood
      • Mar 2004
      • 2462
      Ensure that the CD transport can freely move all the way to the outside, and that it's not binding anywhere. You may need to grease the screw drive.
      Ludicrous gibs!
      • japlytic
        • Oct 2005
        • 2086
        CD transport is OK (it is not a screw drive). Replaced all of the capacitors 4.7uF and below with polyester units, with the 4.7uF unit being a tantalum unit (All of the capacitors replaced were in the analog signal processing section). CD player section now works perfectly . I guess the place where we last got it serviced thought it was a problem with one of the ICs - don't overlook small-value electrolytic capacitors, especially those below 1uF.
        • arneson
          • Sep 2005
          • 1267
          Thanx for tips like this. I would have also gone for the chip.
          Jim
          • m1ch43lzm
            by m1ch43lzm
            05-12-2025, 08:37 PM
          • PNI E.
            Dyson v15 problem with the dust detector board
            by PNI E.
            Hi guys, I have a Dyson v15 that didn’t work. The battery blink 10 times. If i disconnect the cable of the dust detector board, the Dyson turn on but after some seconds stop because didn’t feel the flow of the air because I disconnected the bird sensor, if I connect the Dyson is death. I notice the big mosfet I think with 3 pins. If I check the mosfet I have a short circuit from the center pin ne the left pins…so I think that s the problem or I wrong? The problem I can’t understand what type of mosfet is….someone can help it s hard to find. New board...
            10-02-2025, 10:18 AM
          • huj3r
            Sony KDL-40Z4500 LCD with stripes and 9 blinks (possible BGC board or harness problem
            by huj3r
            Hi there!
            I have a Sony Bravia KDL-40Z4500 which shows a colored vertical stripes pattern when turning on, with a central black shadow that slowly dissipates within the first 10 seconds.
            Photo of the situation after the black shadow dissipates:
            After this behavior the red LED will blink 9 times, then pause for a bit, and blink again 9 times, in a loop.
            I checked the manual (available here) and this corresponds to "HFR error", quoting from the manual:
            > This indicates HFR Communication error. [ HFR Communication...
            08-15-2023, 10:55 AM
          • howardc64
            by howardc64
            Problem
            08-04-2024, 10:36 PM
