Hello i ordered an RGB controller that is 12v in and 12v out i also ordered RGB led that support 3 V. The controller have a brigthness controller and the lower setting keep it at 2.3 volt max. all color work but if i use fade that make the led flash very fast and they burn. i whas wondering id my led are juste bad or its the controller ?
Trouble whit RGB led and controller
Re: Trouble whit RGB led and controller
LEDs are driven in current not voltage. The voltage required depends only on the LED, as soon as the voltage input exceeds the breakdown voltage of the LED, the LED will start conducting (aka light up), and it'll eat all the current that the supply gives it. If this current is not limited the LED will burn.
12v LEDs are inherently current limited because they are just regular LEDs in series with a resistor. This is why you can dim such LEDs by dropping the voltage. You need a current source in series with your RGB LEDs. You can just use a resistor sized appropriately, so that at "max" brightness of your RGB controller you do not exceed the current rating of the LED, or check here for a simple adjustable current source using a LM317 if you need a little more control. You can find that at any radio shack or similar store.A working TV? How boring!Originally posted by PeteS in CARemember that by the time consequences of a short-sighted decision are experienced, the idiot who made the bad decision may have already been promoted or moved on to a better job at another company.Comment
Afther some testing i found that my controller at max power output the same voltage it get from the supply. My solution is to use a 5v supply and 3 resistor for the - of each colors since they dont have the same maximum voltage. i tested it all day like this and no burn led!!! I whas thinking about using a 7805 to get 5v in my car. My project is to have all light in my car dash RGB!!Comment
i'd rather use a switchmode step down converter. that 7805 is going to need a HUGE heatsink if you're going to connect it to the car battery..
if you don't want to build your own, look for cellphone chargers that plug into the cigarette lighter socket.
the ones for sony ericsson phones with the "fastport" connector usually put out 5V.
i've got one that looks like the one pictured in the auction below. i'd recommenc popping it open and replacing the generic crapcaps though.
http://cgi.ebay.com/120710805517
or just get one of those USB car chargers. those have to be 5V for sure lol
by master3112I have an ASUS ROG Strix- G513IH-HN008, motherboard G513-6050A3249301- MB-A04 (A4)
When I received the device, the device has no function. After an investigation, I found that the PWM CONTROLLER RT6575B (U6100) is getting warm and there is a short circuit at the 3V3 output. This normally supplies 3V3 for the embedded controller IT5571E-128 (U301). When measuring and analyzing with a thermal imaging camera, I found that some components are damaged: SLG4E42553VTR (U8500), IT5571E-128 (U301), LAN RTL8111H (U450), LOGIC 74LVC1G08GW (U1900), RT6575B (U6100) All these components are on... -
by PipolupsHi there !
I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...10-08-2024, 11:58 AM -
by ronnygraciasThe treadmill was working fine, one day the belt snapped and after checking the unit I also noticed that the display is now showing the Controller comm error. So I opened it up and the treadmill had two boards. One is a power supply board and the other is the motor controller. I noticed there was a mouse nest, so I took power supply board out, cleaned it up, replaced the big capacitor and that did nothing. Then I took apart the motor controller and cleaned that up, and when I plugged it in, it started right up. I thought I fixed it. But when the belt arrived, I installed it and tried to power...4 Photos
by sam_sam_samThis happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
I am comparing them to a brand new one that I installed
The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
I going to let it run for several days before I remount back on the wall next to the... -
by sam_sam_samI recently bought a used tankless hot water heater and the controller board is completely dead no power up when power is applied the display board works however the main controller board does not work correctly at all the fuse is good
I bought a used replacement controller board that also had issues that I was able to fix and now the tankless water heater works correctly now
However I would like to know if I could figure what happened to this controller board if possible
Tomorrow I will take some better pictures of both side of both boards
The... - Loading...
