ground falt
+ More Options
Posts
  • skystormfarms
    Banned
    • Mar 2011
    • 160
    Re: ground falt
    3 weeks
    • Mad_Professor
      A Mech Warrior
      • Feb 2011
      • 1587
      Re: ground falt
      Originally posted by skystormfarms
      3 weeks
      have you tested any other outlet on the strip, or is the one that is scorched the only one with a reversed hot/neutral.
      • skystormfarms
        Banned
        • Mar 2011
        • 160
        Re: ground falt
        yes
        • Mad_Professor
          A Mech Warrior
          • Feb 2011
          • 1587
          Re: ground falt
          yes what? yes that you tested other outlets or yes that's the only one?
          • skystormfarms
            Banned
            • Mar 2011
            • 160
            Re: ground falt
            • Mad_Professor
              A Mech Warrior
              • Feb 2011
              • 1587
              #26
              Re: ground falt
              I don't know about your PSU, if I were you I would test it on a throw away old computer. Call GE and see what they have to say about this. Obviously it's a defective power strip, if they can't do anything for ya, talk to a lawyer and prove that your PSU works fine but you could have been seriously injured or killed from the defective power strip.
              • skystormfarms
                Banned
                • Mar 2011
                • 160
                #27
                Re: ground falt
                did that and a mobo powerd up no problem and i don't want to sue dont have the monny
                • Mad_Professor
                  A Mech Warrior
                  • Feb 2011
                  • 1587
                  #28
                  Re: ground falt
                  one more thing how did you test to see if the hot was reversed?
                  The hot could test neutral if it's damaged, the only way is from hot to ground and neutral to ground, one will read 120 and other 0.
                  Glad that PSU works, call GE see if they will replace the strip.
                  • skystormfarms
                    Banned
                    • Mar 2011
                    • 160
                    #29
                    Re: ground falt
                    i did hot to ground and neutral to ground
                    • Mad_Professor
                      A Mech Warrior
                      • Feb 2011
                      • 1587
                      #30
                      Re: ground falt
                      Glad I could help. Seeing those scorch marks reminds of a close call I had when I was working as electrician apprentice.
                      • skystormfarms
                        Banned
                        • Mar 2011
                        • 160
                        #31
                        Re: ground falt
                        wow aclose call this is the secont time i have ben blown acros the room
                        • delaware74b
                          • Apr 2009
                          • 628
                          Re: ground falt
                          That breaker panel IS a liability. Zinsco/Zinsco by Sylvania lost their UL listing years ago. The panel is about 40 years old and has same problems as Federal Pacific. Breakers don't trip, known to fall out of panel, and ALUMINUM bus bars.
                          This link is no joke:
                          http://www.youtube.com/watch?v=uMV1jmDn3o4
                          I've seen this in the field in both FPE and Zinsco's. If one of these breakers jams (or jammed intentionally), it will never trip.
                          As far as polarity of outlets is concerned - here's something to help you remember: Short slot is hot. Neutral is the slightly longer than the hot.
                          Stupidity should be a crime, especially for drivers. I have NO patience for them.
                          • skystormfarms
                            Banned
                            • Mar 2011
                            • 160
                            #33
                            Re: ground falt
                            ((())) o no not good not good at all but mine is GE witch i wold is just as good as the zincos
                            • skystormfarms
                              Banned
                              • Mar 2011
                              • 160
                              #34
                              Re: ground falt
                              oop's it is a zinco
                              • delaware74b
                                • Apr 2009
                                • 628
                                Re: ground falt
                                skystormsfarms - GE is actually one of the better panels. As an electrician, I've installed more than I care to count. Never had a bus failure or main breaker failure. They carry a lifetime warranty on the panel and breakers, full copper bus (it's coated with a silver-colored compound). I've seen some of their older panels (over 30 years) with no problems to be found.
                                FWIW, Cutler Hammer CH-series also has the lifetime warranty but their BR-series is only 10-years. Square-D is unclear on their warranty.
                                • skystormfarms
                                  Banned
                                  • Mar 2011
                                  • 160
                                  #36
                                  Re: ground falt
                                  well it was a ge product that blew me acros the room
                                  • delaware74b
                                    • Apr 2009
                                    • 628
                                    Re: ground falt
                                    Skystormfarms, look at the third picture in your first post. Multi-color handles in a single line is the trademark design of Zinsco. Also, the breakers are 1-inch thick with 2 handles, with or without a handle tie (two single pole breakers for 2 120-volt circuit or a 2-pole breaker for a 240 volt circuit).
                                    GE uses all black handles, 1-inch or 1/2-inch breakers. Bryant used to make breakers with colored handles that fit GE's and vice-versa but doing so voided UL listing of the panel and also voided the warranty. A GE breaker will trip faster than a Zinsco almost to the nuisance level of tripping (regardless of age).
                                    • Mad_Professor
                                      A Mech Warrior
                                      • Feb 2011
                                      • 1587
                                      #38
                                      Re: ground falt
                                      The "GE" I was referring to was the power strip not the load center.
                                      edit: then reading up I see he replied with a zinsco panel.
                                      Looks like they are working if they tripped but still I think you should have the panel inspected by a licensed electrician to ensure proper functionality.
                                      • skystormfarms
                                        Banned
                                        • Mar 2011
                                        • 160
                                        #39
                                        Re: ground falt
                                        yes but i rent and i am not even aloud to replase a switch so what do i do
                                        • barry101
                                          Apple 820-3662 VCore shorted to ground.
                                          by barry101
                                          Hi, Would appreciate some help.
                                          I have an Apple Late 2013 15" A1398 MacBook Pro with Logic Board 820-3662.
                                          Get charger light but no fan spin or chime. No liquid damage.
                                          Found PPBUS and VCORE both shorted to ground. Other rails were ok.
                                          Removed VCORE MOSFETS U7310, U7320 and U7330. Found U7330 was in fact shorted.
                                          With the 3 MOSFETS removed, get PPBUS and fan spin. VCORE is still hard shorted to ground (0 ohms).
                                          Attempted voltage insertion on VCORE to locate short using bench supply set at 1.0 VDC and 4.95 Amps (max current for my...
                                          06-24-2025, 07:34 AM
                                        • Chaks
                                          Ground Plane For 5dBi ISM Band 865-870Mhz Embedded Ceramic Antenna
                                          by Chaks
                                          TAOGLAS ANTENNA MODEL: ISPC.86A.09.0092E
                                          The specs says ...
                                          High antenna efficiency 868MHz ISM Band
                                          5dBi Peak (when placed on 30cm x30cm ground plane) - Broadside to Zenith Radiation Pattern
                                          The antenna is 50x50 mm square and How do I fix it on the Ground Plane of 300 x 300 mm (aluminium sheet 3mm thick).
                                          1. Should I Fix it with a glue.
                                          2. Should I fix it with a double side adhesive tape
                                          3. Should I fix it with Screws (the screw head may just clamp the antenna to the aluminium...
                                          12-09-2024, 11:06 AM
                                        • Rolin
                                          Dell Laptop - over 14V between Chassis Ground and Circuit Ground?
                                          by Rolin
                                          Someone brought me a Dell laptop that had a loose power jack inside (power jack on a cable, not soldered to motherboard). Once disassembled found one of the wires was broken off the power jack. I replaced the jack and it won't turn on, but the metal shell of the jack inadvertently touched the metal hinge and suddenly it got power. I checked voltage from the metal chassis ground and the circuit ground and I get over 14V ? Has anyone seen this before? Typically is it some kind of filter cap that shorted? Very strange...
                                          10-30-2022, 10:18 PM
                                        • loopster
                                          645 G9 with Ryzen 5 PRO 5675U | Resistance to ground of CPU?
                                          by loopster
                                          Hello everyone, I have a 645 G9 here with a Ryzen 5 PRO 5675U.
                                          This board has a blown inductor component above the driver chip to the CPU coil, and I am wondering whether the CPU is shorted/dead.
                                          Could anyone please measure the resistance to ground on the leftmost coil/inductor to the CPU?
                                          My resistance value is 2.2 Ohms, which doesn't look good to me.
                                          Thanks to everyone willing to give a value.​
                                          06-05-2025, 02:33 PM
                                        • playit
                                          450watt power supply 5v, 3.3v short to ground wire,in output rail ,connectors
                                          by playit
                                          hello everyone , working zebronics power suply 450 watts , 5v ,3.3v givin short to ground black wire, also in circuit at output, resistor was charred but shows right values , after removing resistors 39ohms, 51 ohms, there was no short , no continuity beeps with ground , but after replacing new resistors (now i am not switching it on) ,again short still exists . when i put bigger ohm resistor like 100k ohm , no short beeping sound comes , lower ohm resistor gives continuity beeps ,other big ones donest , as its a working psu , i am confused what to remove now or how to go further now .
                                          09-02-2023, 02:43 AM
