I am curious about how to measure the ON resistance of a bipolar transistor (of which the datasheet does not specify) at varying Base to Emitter voltages, whereas MOSFET datasheets specify an ON resistance at a given Gate to Source voltage.
Measuring bipolar transistor ON resistance
Re: Measuring bipolar transistor ON resistance
The data is given you just don't know how to interpret it. The parameter you are interested in is Vce (sat) which is the static voltage drop of the bipolar transistor when it is saturated ie fully ON. Vce (sat) times the RMS current going thru the transistor, gives the power dissipation of the device.
As far as i remember (big bipolars are too slow for my taste so i don't work with them too often), in most datasheets there is also a Vce (sat) vs Ib plot. Same as Vgs vs Rdson for mosfets.Last edited by Th3_uN1Qu3; 03-27-2011, 08:48 AM.Originally posted by PeteS in CARemember that by the time consequences of a short-sighted decision are experienced, the idiot who made the bad decision may have already been promoted or moved on to a better job at another company.
by cind12Hi guys, i was wondering, i've got 9Ohms on Vmem, one of the mosfet was shortet to ground, so i've desoldered hi and low mosfets nad still low res, then i removed all of the memory chips, and the resistance is still low, so did you had maybe a card with that low res on memories, and the card was working fine ?
Removed the U1866Q and still without result, i dont have thermal cam so can't see where is hot spot when incjeting voltage.
The resistance on core is ok 0.1Ohm ((Power 0.8V when on)
Resistance on 12V 4K ohms (Power present when on)
Resistance on 12V PEX 4K ohms... -
by Nagy DanielHi, I'm Daniel, and I'm new to the world of repairing motherboards.
I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
So, I generated a table with AI so I can... -
by sigmeyerOk , so i got this TV from a friend of mine.So to start it off Its a plasma TV.When turned on it the red light comes on , then after a couple seconds the light goes off, and it repeats like that. You can hear the Relay click on for a few seconds then off ... So it wasnt an obvious short on the mains input thats for sure. I opened it up , and mind you, i have never seen an inside of a plasma TV so it suprised me to say the least. There are 3 massive power boards. The main one , then we have the board that is connected to another board which then goes to the TV (i assume those are some kind of drivers...
by magnehHello
Got this speaker from a friend , defective. Power led comes on and off , in a loop.
Disassembled, got the board out, and after a bit of measuring I found a low resistance on a 5v6 line. With a bit of current I found a transistor heating up on that line (labeled T1 and 113 as on pic).
After removing this guy, I got a value of 0.7 in diode mode on that 5v6 line, which before had 0.02 or something like that.
I tested powering it up without the IC, and the speaker turns on and stays on, and works fine
Still, I need to replace this transistor.... -
by tony359Good day all,
I have a question about some old monochrome Apple monitors.
Inside those monitors there is one bipolar capacitor. From the schematics I have it's part of the horizontal linearity circuit.
A friend replaced a bipolar 4.7uF 25V capacitor with a Nichicon bipolar 4.7uF 25V. The cap popped after about one hour. The new capacitor was much smaller than the original one but that's not a surprise as the original one was from 1980. (I am not sure whether the original was was actually 4uF and was replaced with a 4.7uF?)
The new capacitor:...-
- Loading...
