How many 1U servers can I run with 20 amps?
  • mockingbird
    • Dec 2008
    • 5484
    I'm thinking of setting up an older 1U server in someone's rack, but he pays for a maximum of 20 amps and I am concerned that it will overloaded.
    OTOH, with two 1U servers already running, the meter is only showing 2A.
    Let's assume there will be five servers with 4 harddrives on each, let's say each server is drawing no more than 300W. All the information I've read so far leads me to believe it should not be a problem, but what concerns me is that with video cards, people suggest there should be two rails that supply at least 15A each. If one high end video card can draw 30 amps, how can these servers be drawing such a minute amount?
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    Re: How many 1U servers can I run with 20 amps?
    A server does not have a high-end video card. Actually, some have no video card at all. Also there isn't a whole lot of dissipation capability in a 1U case, so if it's 1U you can bet it's power efficient. Or has some darn noisy fans.
    A working TV? How boring!
    • mockingbird
      • Dec 2008
      • 5484
      So you're telling me that these videocards really draw 30 amps when I'm playing Movie Battles II maxxed out at 1280x1024 and chugging away at 30fps? I have a Radeon 2900XT, the thing is a power hog I hear, though I do have a 750W PSU in that PC.
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        12x30=480w. Not too hard to believe. Tho i believe it applies to today's high end, the 2900 is quite old.
        A quick google reveals a consumption of about 350w for the 2900.
        • severach
          • Aug 2007
          • 1055
          A Kill A Watt is a cheap way to get an instant answer.
          sig files are for morons
          • smason
            • 1652
            WTF? A video card drawing 30A? Holy excrement!
            I'm not a gamer so I normally ignore high end video cards, but 30A?
            A 100W 20 metre HF transmitter barely gets to 20A.
            • Krankshaft
              • Jan 2007
              • 2328
              A thing to mention the Kilawatt meters aren't true RMS.
              They claim to be on the package but when I hooked one up to my modified sine wave (square wave) UPS inverter and pulled the plug it registered 0 volts. I commend it for giving up and not registering some fictional voltage that is too low but I wish they wouldn't have lied on the package.
              Back on topic I believe you're referring to video card current draw from the PSU?
              Yes at full load they can draw up to their max current it depends on how graphics intensive the game is. A graphics card is just a GPU like a CPU the more it's loaded the more current it will draw.
              But servers don't have high end graphics cards they're not designed for that.
              • santel
                • Mar 2011
                No possible way a video card draw 30 Amps, that would be like 500Watts + cpu etc etc = 800Watts. will require a 1000Watts supply or more.
                • PlainBill
                  • Feb 2009
                  • 7034
                  You're getting confused between current drawn from the AC line (at 120 VAC) and current drawn by a video card (at 12VDC). If your video card is drawing 30 Amps, that's 360 Watts. Assuming the power supply is 80% efficient, that's less than 4 Amp from the AC line.
                  PlainBill
                  • PCBONEZ
                    Grumpy Old Fart
                    • Aug 2005
                    • 10661
                    TDP of CPU(s) [in watts] x 1.25 [The 1.25 is for VRM efficiency/losses]
                    +plus+
                    5 to 15 watts/stick of RAM depending on what kind it is. [Google it]
                    +plus+
                    20 watts/HDD [typical watts on spin-up from dead stop]
                    +plus+
                    35 watts for basic mobo power [approximation used in most PSU calculators]
                    +plus+
                    10 watts/add-in card [general slot power is +5v, slots limited to 2 amp on +5v]
                    +plus+
                    5 watts/LAN chip [wild guess]
                    -divided by-
                    PSU effieciency
                    =Equals=
                    Pretty Darned Close [in watts]
                    Skipped Opticals because when in use the HDDs are already spun-up from a dead stop and using much less than the 20 watts.
                    Mann-Made Global Warming.
                    - Dr Seuss
                    • PCBONEZ
                      Grumpy Old Fart
                      • Aug 2005
                      • 10661
                      The steady state condition is not what you should look at.
                      Look at what they pull when starting up.....
                      - Dr Seuss
                      • omega
                        Troubleshooting of redundant F750E-S0 Dell PowerEdge Server
                        by omega
                        Hello all,
                        as a beginner electronics hobbyist, after a few years I would like to place another post on this Forum section, given that I did not succeed in finding any useful advice among the other posts.
                        Over the last years, I have been using a PowerEdge Dell Server with two redundant PSUs, namely the 750W F750E-S0 ones (aka 06W2PW). Unfortunately, last summer one of them failed (perhaps owing to an overheating), and the server had for working to take into account the other one only. Of course I opened and tried to troubleshoot the failed PSU, but each cap I tested seemed to...
                        02-09-2024, 03:34 PM
                      • survivalbloke
                        shorted power rail - drawing 3.5 amps but no heat?
                        by survivalbloke
                        This board is out of an HP laptop. There is no voltage present at pin 8 of the Winbond BIOS chip. A nearby coil is a near dead short to ground. Injected 1v and it drew 2.8a but nothing was warm on the board. Then I upped the voltage to 2.5 and 3.5a were drawn, but still no heat. Is that crazy?
                        02-28-2023, 04:30 PM
                        HP ZBook 15v G5 Mobile server 15v Specification for Upgrade or Repair
                        This specification for the HP ZBook 15v G5 Mobile server can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15v G5 boardview and 15v G5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP ZBook 15v...
                        09-06-2024, 11:39 AM
                      • platinumsteel
                        Macbook Pro 2015 820-4924 Drawing 0.08 amps not Turning On
                        by platinumsteel
                        Hi gooday guys.i have a Macbook Pro 2015 820-4924 that is drawing 0.08 amps .My friend told me he was trying to change the keyboard and something touched and he heard a spark.But i don't see any visible signs of corrosion or anything burnt. I have greenlight and orange light on magsafe.Below i have listed the present and missing rails. Hope you guys can maybe lead me on the right track thanks.
                        PPBUS_G3H = 12.57V
                        PPBUS S5 HS COMPUTING = 12.57V
                        PPBUS S5 HS OTHER5V = 12.57V
                        PPBUS_S5_HS_OTHER3V3 = 12.57V
                        PP3V42 G3H = 3.42V
                        PPVRTC G3H = 0V
                        PP5V S5 =...
                        05-17-2021, 03:07 PM
                      • Stephen
                        A2991 Logic Board issue, 20volts 0 amps help!
                        by Stephen
                        Customer plugged in samsung monitor into the board and used it as a power supply, killed UG800 and UG400. I replaced those two with an exact donor board we had In stock and working, board pulls 5volts and then gets like 2.89 amps on the left side. The singular port is the port that failed. Used a perfectly working chips from donor (board was locked) Now I only get 5volts 0 amps on that power and then 20volts 0 amps on the two left side ports, I checked for DFU and nope nothing, computer not turning on. No shorts present anymore. I am confused as I used the exact components from an identical...
                        09-10-2025, 03:16 PM
