What use are these couplers?
  • Radio Fox
    • Jan 2010
    • 281
    I found these couplers on eBay a few weeks ago. I was wondering what possible use they could be put to?
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...=STRK:MEWAX:IT
    ________________________________________________
    Invisible airwaves crackle with life
    Bright antennae bristle with the energy
  • mockingbird
    • Dec 2008
    • 5484
    Re: What use are these couplers?
    Those are BNC couplers. Looks like they are for European television cable wire. Old ethernet couplers would have fasteners.
    • seanc
      • Nov 2008
      • 1319
      I was going to say 'those couplers are useful because', but now I can't understand what the point is either. You're just going male > female > male
      • Agent24
        I see dead caps
        • Oct 2007
        • 4953
        • New Zealand
        Only if you used both at the same time!
        But I think they just took the photo that way so you know what each end looks like.
        -David VanHorn
        • Toasty
          • Jul 2007
          • 4171
          Not BNC. BNC has pins on the outside on the female connector, and a slotted rotating sleeve on the male.
          >>Looks like they are for European television cable wire.<<
          Yes.
          PAL (Belling Lee) connectors. Looks like it's used to extend the connector from the back of a TV or to fit a threaded connector (the side with the splits). From pictures of the TV's the connector on the back looks to be recessed. If your cable has a large insulator blob at the end, it might not fit into the TV properly.
          http://en.wikipedia.org/wiki/TV_aerial_plug
          These look similar to an RCA connector in size, but RCA has a long male pin and conversely the female side would need to be as deep.
          Toast
          veritas odium parit
          • Radio Fox
            • Jan 2010
            • 281
            Exactly. As the listing says, they are male one end & female the other.
            Sorry everyone else, I should have made it clearer in my first post. They are used for TV aerial connections in the UK, but all they will do is extend the plug on the end of your aerial coax lead by about half an inch. What's the point of that?
            Unless, as Toasty pointed out, you have a recessed socket on your TV and a non standard sized plug on the end of your aerial lead, but I have never come across that before.
            Someone, somewhere must have a use for them though, as he has sold 2 packs.
            • Agent24
              I see dead caps
              • Oct 2007
              • 4953
              • New Zealand
              I just realized you are right - these things make no sense. Only sensible reason would be as you say, a recessed socket.
              -David VanHorn
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                As Toasty said:
                ""... used to extend the connector from the back of a TV or to fit a threaded connector (the side with the splits).""
                It converts to a slip-fit.
                The splits let it slip over threads.
                Cheap dollar store cables for TV-to-VCR or whatever sold here do the same trick at the back of the TV end. [Or both ends.]
                No threads and a split outer ring.
                Mann-Made Global Warming.
                - Dr Seuss
                • Agent24
                  I see dead caps
                  • Oct 2007
                  • 4953
                  • New Zealand
                  Aah.. Guess I can't read then. ha ha
                  -David VanHorn
                  • Radio Fox
                    • Jan 2010
                    • 281
                    Yep. That would be true if a threaded plug existed which was compatible with the Belling Lee socket, but I don't think one exists.
                    • PCBONEZ
                      Grumpy Old Fart
                      • Aug 2005
                      • 10661
                      And therefore when you have a cable with a threaded plug on the end [which isn't compatible with the Belling Lee socket] you would need this adapter to make you cable compatible with the Belling Lee socket on the back of the TV.
                      ~ Ahem...
                      - Dr Seuss
                      • Radio Fox
                        • Jan 2010
                        • 281
                        ~ Ahem...
                        But you cannot convert a threaded plug to a Belling Lee plug, if a threaded plug doesn't exist which can be converted. There isn't a threaded plug with the same pin dimensions or outside diameter dimensions which the Belling Lee socket could fit over.
                        • PCBONEZ
                          Grumpy Old Fart
                          • Aug 2005
                          • 10661
                          Coax comes with all kinds of threaded plugs.
                          They just aren't Belling Lee.
                          Things get interesting when people need adapters for things from across the big pond that are standard on one side but not the other.
                          And as image of a different adapter shows, there is a threaded plug with the same dimensions as Belling Lee.
                          - Dr Seuss
                          • Toasty
                            • Jul 2007
                            • 4171
                            Is there a shot of the threaded side of that? It looks like an 'F' to B-L adapter, which would have a very small receptacle on the threaded side. If it has the B-L size hole there, then I think we found a match.
                            I have come across many "wacky" connectors and adapters in my travels. I put nothing out of the realm of possibilities. I've even made a few myself.
                            Toast
                            veritas odium parit
                            • PCBONEZ
                              Grumpy Old Fart
                              • Aug 2005
                              • 10661
                              I dunno. Youre next sentence pretty much explains why I'm not gonna look that hard.
                              Yup, especially when you get into test equipment and propriety industrial parts as used in places like, um, Nuke plants, the possibilities become endless.
                              I've already seen lots of things that 'don't' or 'shouldn't' exist that have some peculiar purpose unfathomable to anyone outside of some specialty so I don't really question if a purpose exists for something just because I can't think of one.
                              If the part in question had a hole through the tip [for soldering the center wire] I'd say it's simply a crimp-on PAL [aka Belling Lee] connector for the end of a cable.
                              - Dr Seuss
                              • Radio Fox
                                • Jan 2010
                                • 281
                                They just aren't Belling Lee...
                                I agree, but for the theory that the adapters on eBay are to convert a threaded to a non-threaded connector, then they obviously have to be compatible.
                                ...And as image of a different adapter shows, there is a threaded plug with the same dimensions as Belling Lee.
                                As you said yourself in your following post, you don't know what the threaded end is, so how can you say that it has the same dimensions as a B-L?
                                It is a B-L plug to F socket, as shown below (as Toasty suspected). There is no way you could force a Belling Lee socket into an F socket without the aid of a big hammer.
                                Of course, I agree that there are many weird & wonderfull plugs & sockets out there that I have never come across, and possible at some time a threaded plug with similar dimensions to a B-L may have been made for a specific application.
                                I still think that it's pretty unlikely that the 2 buyers of those adapters bought them for that purpose though. I bet they bought them by mistake, thinking they were male - male, or female - female adapters.
                                I notice that no feedback was given or received for the items.
                                • PCBONEZ
                                  Grumpy Old Fart
                                  • Aug 2005
                                  • 10661
                                  And you don't know what the dimensions are on the female end in you original post so you don't know if that end is Belling Lee in the first place.
                                  - Dr Seuss
                                  • PCBONEZ
                                    Grumpy Old Fart
                                    • Aug 2005
                                    • 10661
                                    You see this guy...
                                    Without that OP connector this might be too f*cking fat to fit into the back of some TV sets.
                                    What I would like to know is why you are spending so much time obsessing over a connector you say you don't have a use for.
                                    - If you want one just to make your junk box look more full, buy one.
                                    - Dr Seuss
                                    • Toasty
                                      • Jul 2007
                                      • 4171
                                      ...and send one to me. I like wacko connectors!
                                      veritas odium parit
                                      • ADATA_C008/16GB
                                        10-character number and 4-characters string on USB Standard-A, "male" plug? Meaning and usage?
                                        by ADATA_C008/16GB
                                        I bought "ADATA C008 / 16GB" USB Flash Drive yesterday, and I'm curious about meaning and usage of this 10-characters number and 4-charatcer string on USB Standard-A, "male" plug.
                                        11-10-2024, 11:47 AM
                                        RJ45 Block Diagram / Schematic
                                        RJ45 network connectors are most commonly found at either end of an Ethernet (wired internet) connection. At first glance, they appear similar to the familiar telephone plugs and jacks which connect landlines to walls or switchboards. However, RJ45 connectors are typically slightly larger.
                                        The term RJ45 connector is widely used today to describe both male RJ45 plugs and female RJ45 sockets. The plugs, sometimes called modular connectors, are usually found on the end of Ethernet cables. The sockets or jacks are generally embedded in the device...
                                        10-31-2024, 04:18 AM
                                      • ratdude747
                                        New Design: Helper Board for Video Head Units
                                        by ratdude747
                                        Over the last several years I've had Android head units in my truck (1995 Ranger), there's been some issues that have always bugged me... or I solved in a less than "ideal" manner. I've designed/ordered PCBs and ordered parts for a board to hopefully fix all of these in a better way, and I'd like to share the design here.
                                        Attached is a .zip of the KiCAD files, Schematic, Gerber Files, and BOM from digikey (ok, it's a downloaded excel of my order I placed, close enough...)
                                        The issues this board corrects are (and what I currently am doing that sucks):
                                        1. This
                                        05-19-2020, 09:24 PM
                                      • mkdj
                                        MacBook Air A2337 (820-02016) - 5V, won't turn on - please help me understand why
                                        by mkdj
                                        About me, my goal and the equipment I (don't) have:
                                        I am brand new to this forum, and I am eager to learn about repairing laptops. I have an engineer background although I haven't done electronics for a while. I have watched several Youtube videos in the last two months, trying to understand how to diagnose a faulty motherboard. I have a USB-C Amp meter and a classic multi meter. No DC Power Supply to inject voltage, no soldering iron to replace components.
                                        About my issue and my goal:
                                        A friend of mine has a MacBook Air M1 A2337 that does not...
                                        04-03-2025, 08:28 AM
                                      • evanh1122
                                        Asus G14 GA402XV not booting after force shutdown
                                        by evanh1122
                                        Hey everyone, a couple of weeks ago my Asus G14 GA402XV-G14.R94060 froze completely (the first time this happened), so I had to force shutdown. Ever since that, it has never booted again. Pressing the power button makes the power led to go on (drive led never blinks) and the keyboard also lights up. If the board gets hot enough, the fans will spin. Sometimes, if I'm not plugged into power, pressing the power button won't do anything at all. After a couple of seconds though, it just turns off. I tried unplugging the battery and holding the power button for 60 seconds, which supposedly resets CMOS,...
                                        02-22-2025, 04:12 PM
