Furnace problems
  • Junk Parts
    Court Jester
    • Jun 2006
    • 8953
    Furnace problems
    Ok the power is back on but I can't get my furnace to lite off. Its a natural gas unit with a standing pilot light. The pilot light never went off but since I couldn't get the unit to kick I shut it all the way down and started from square one. I got the pilot burning again but it stll wouldn't lite off the main burner. Next the thermostat went blank. In the past years here we have had to replace the thermostat a few times. I bought a new one yesterday but haven't installed it yet. Its only a simple two wire setup. here is my dumb question.... If I short the two wires at the thermostat as a test shouldn't this cause the furnace to kick in? Can I check at the thermostat with my VOM for voltage without blowing out my furnace control board??? My friend Chuck could fix this but I'd rather do it myself. It has to be something simple wrong here.
    Mark Twain
    John Paul Jones
    Rod Serling
  • smason
    • 1652
    Re: Furnace problems
    Yes, shorting the wires should make the furnace come on.
    If you're testing at the thermostat, it should be 24vac ( I think, maybe 48, I'm a bit foggy at the moment)
    Is there a switch near the furnace that may have gotten turned off?
    We have one on the wall by a shelf, and sometimes manage to accidentally turn it off.
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      shorting the 2 wires should turn it on.control voltage is 24vac.
      thermostat if its a digital one runs from the 24v or batteries.the suggestion to check the switch or breaker is a good one.
      • Toasty
        • Jul 2007
        • 4171
        The thermocouple sits in the pilot light flame. It's the fine piece of tubing leading to the bracket that holds the pilot and runs back to the main gas valve.
        It can fail one of 2 ways:
        It prevent the pilot light from staying lit. (yours is working this far)
        It can prevent the main gas valve from opening.
        If you cross the 2 thermostat wires, you should hear the gas valve -clunk- and you should see the pilot light flame get bigger so it hits the burner. Shortly after the pilot flame gets bigger, the gas valve will move again and open to supply the burners with gas.
        Other possibilities are a failed or stuck lower and upper fan temperature limit switches. Low is usually set from 100-110°F and high is around 175°F. This is adjustable. Pay attention if you need to change it to NOT ROTATE the dial. HOLD the dial and move the sliders.
        Then there is a high temp cutout that prevents the whole unit from overheating (usually not adjustable).
        Report findings.
        Toast
        veritas odium parit
        • Junk Parts
          Court Jester
          • Jun 2006
          • 8953
          The furnace has a breaker in our main pannel. It also has two off switches. One is the Red plated emergency shutoff in the hallway. The other is located near the furnace both of these and the furnace breaker are switched on. I checked the 24 volt side in the furnace and at the thermostat and got zero volts at both places. My brother is on his way over to fix this thing or at least try to. Me !
          Mark Twain
          John Paul Jones
          Rod Serling
          • Junk Parts
            Court Jester
            • Jun 2006
            • 8953
            Toasty I saved that for my brother to look at when he gets here.
            Mark Twain
            John Paul Jones
            Rod Serling
              • 31278
              if this is a furnace that heats water in a coil to feed radiators & sinks then check the pressure safety switch on the incoming water supply.
              • Toasty
                • Jul 2007
                • 4171
                AC scale on meter, yes?
                Transformer should be humming(lightly) and a little warm.
                If switches are on, and its cold, then it sounds like the transformer is toast. Quickie (cheap) fix.
                Toast
                veritas odium parit
                • Junk Parts
                  Court Jester
                  • Jun 2006
                  • 8953
                  We have 120 vac comming into the furnace. The 24 vac out of the little transformer is at 0. We are calling a furnace repairman we know to fix it. Sorry my report isn't detailed Toasty. I'm tired and done thinking about the thing for today. I have electric heaters in place. We will be fine until its fixed.
                  Mark Twain
                  John Paul Jones
                  Rod Serling
                  • Krankshaft
                    • Jan 2007
                    • 2328
                    If your furnace has a standing pilot it's probably as ancient as mine.
                    Did you hold the button on the thermocouple shutoff gas valve?
                    After lighting the pilot trace the thermocouple tube to the thermocouple gas shut off hold the button all the way down for a few seconds then release.
                    The tiny voltage induced from the heat to the thermocouple holds the gas valve open this prevents the burner from from flooding the house with gas should the pilot go out.
                    If the transformer isn't getting power check the emergency shutoff switch for the furnace there should be a red switch plate that says burner on it. I believe it's code for all furnaces to have one.
                    • Junk Parts
                      Court Jester
                      • Jun 2006
                      • 8953
                      I held the button in for a full 60 seconds like the destructions said to.
                      Mark Twain
                      John Paul Jones
                      Rod Serling
                      • Krankshaft
                        • Jan 2007
                        • 2328
                        Well then it sounds like a dead transformer or a wiring problem to it.
                        Does your gas solenoid have a test knob on it? Mine does.
                        You can turn it and it will allow you to open the gas valve manaually to see if the thermocouple is working release the knob and it will close. If the burner fires up the thermocouples fine and it's an electrical problem.
                        • Junk Parts
                          Court Jester
                          • Jun 2006
                          • 8953
                          I'm going with it being and electrical issue because I have no volts going to the thermostat from the transformer. There is A/C power going to it.
                          Mark Twain
                          John Paul Jones
                          Rod Serling
                          • delaware74b
                            • Apr 2009
                            • 628
                            Disconnect the secondary side of the transformer and see if you have 24-27 volts AC on the secondary. If 0 volts, replace the transformer. If you have 24-27 volts, look for a shorted component.
                            Stupidity should be a crime, especially for drivers. I have NO patience for them.
                            • Junk Parts
                              Court Jester
                              • Jun 2006
                              • 8953
                              I took a real close look at the terminals on the transformer and I think I can see what caused the problem. One of the thermostat wires shorted to another terminal on the transformer. My furnace fixing friend John is going to take care of it in the morning. Since I think it got shorted I'm going to hang the new thermostat I have here too. Hope nothing expensive got fried.
                              Mark Twain
                              John Paul Jones
                              Rod Serling
                              • Toasty
                                • Jul 2007
                                • 4171
                                Success?
                                veritas odium parit
                                • kc8adu
                                  • Nov 2003
                                  • 8832
                                  • U.S.A!
                                  burnt up the transformer no doubt.too bad you are nor close by.i could grab one out of spare parts in about 30 seconds.replace it yourself and save the call.hell radioshack has a 25.2vac 2 amp unit that will do.
                                  • SolomonMan
                                    Nest Thermostat Discussion...
                                    by SolomonMan
                                    All,
                                    I was over my sons place helping him with projects today. (Broken Dryer Belt, a Couple leaking pipes (One cracked - that got me over there),and Thermostat swap.
                                    The Energy company offered a Rebate on the Nest Thermostat System (Not the Learning One) last year and we picked it up and its sat in the shipped box for about a year now.
                                    Anyways I was thinking it would be a quick job as I currently have a Nest Learning Thermostat at my place and it was not a problem to install. (Old Rheem 90 Furnace)
                                    At my boy's place he has a York Stellar...
                                    12-11-2022, 10:54 PM
                                    Samsung ATIV Book 9 Lite Notebook Specification for Upgrade or Repair
                                    This specification for the Samsung ATIV Book 9 Lite Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Book 9 Lite boardview and Book 9 Lite schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                                    09-06-2024, 05:27 AM
                                    HP lite Hybrid (2-in-1) Specification for Upgrade or Repair
                                    This specification for the HP lite Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the lite boardview and lite schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP lite Hybrid (2-in-1)...
                                    09-07-2024, 07:19 AM
                                    09-07-2024, 07:12 AM
