Help identifying a resistor
  • alfredomfr1
    • Oct 2014
    • 318
    • usa
    I need help identifying this resistor color code (see the picture)
    Thanks in advance
  • petehall347
    • Jan 2015
    • 4426
    • United Kingdom
    Re: Help identifying a resistor
    what does it measure as ?
    • alfredomfr1
      • Oct 2014
      • 318
      • usa
      around 1ohm, but maybe is defective
      • R_J
        • 9535
        0.39Ω 5% non inductive, If it measures around 1Ω it is ok, Check your meter lead resistance, it is likely around 0.5Ω
        • petehall347
          • Jan 2015
          • 4426
          • United Kingdom
          build a wheatstone bridge .
          • alfredomfr1
            • Oct 2014
            • 318
            • usa
            R J how you read the color code, starting with orange? because I was using a color code calculator online and the result was 39 ohms, but I believe I'm doing something wrong
            • R_J
              • 9535
              Orange = 3
              White = 9
              Silver = x0.01Ω
              Gold = +/- 5%
              Black = non inductive
              • alfredomfr1
                • Oct 2014
                • 318
                • usa
                Right. Thanks R J
                • alfredomfr1
                  • Oct 2014
                  • 318
                  • usa
                  Thanks Petehall347
                  • Donny2023
                    • Jul 2023
                    • Japan
                    I tried asking AI
                    • eccerr0r
                      Solder Sloth
                      • Nov 2012
                      • 8696
                      LOL Though I don't think resistor manufacturers are helping, AI has a ways to go...
                      • ugamazing
                        Assistance with identifying resistor value on 820-02918 A2992 board?
                        by ugamazing
                        Working on a 2023 M3 A2992 unit with 820-02918 board, and it uses a new USB-C power architecture, with rectangular controllers. I do not have a perfect-matching board, so have been repairing this one the old-fashioned way (slowly).
                        I managed to blow-away a single resistor that I can't find and can't determine the value of. It connects to ground, so I went ahead and stuffed it with a 100K resistor in case it's a simple pull-up. But, I'm now having issues with that side of the board, and am curious if it's possibly related to this resistor! I have no schematics and no board view, so...
                        09-06-2024, 08:33 AM
                      • dutchgaucho
                        Need help identifying resistor on Asus FA507RC DA0NJNMBAD0 schematic
                        by dutchgaucho
                        Hi colleagues,
                        Looking for a schematic DA0NJNMBAD0 or the MP2845A 6-phase PWM controller.
                        Working here on a DA0NJNMBAD0 rev D motherboard (Asus FA507RC) with liquid damage. Board has some tiny corrosion around the MP2845A controller and one resistor is missing. I need to know the value of the resistor, but no schematics are available. Not even for the MP chip or anything similar (this is a 6 phase PWM controller).
                        On one side of the pad 20V is present. The other side connects to a cap and to pin 16 of the MP2845A. Resistor seems too small for VCC...
                        11-09-2023, 11:27 AM
                      • jinu_j
                        by jinu_j
                        Hi
                        05-03-2025, 10:51 PM
                      • DubTechnic
                        Need help identifying resistor.
                        by DubTechnic
                        So obv a 10k resistor. But I can't find wattage rating for it. Came from an automotive pcm. If that helps. Input voltage starts at 12v but I'm sure drops down to 3 and 5 etc.
                        Thanks in advance. And sorry if this is ridiculous. I'm still a bit of a novice.
                        09-24-2024, 08:19 AM
                      • MidnightRoller
                        Can a resistor lose resistance after hot air?
                        by MidnightRoller
                        I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
                        I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
                        02-02-2022, 11:46 PM
