Need help identifying resistor.
This topic has been answered.
  • DubTechnic
    • Oct 2023
    So obv a 10k resistor. But I can't find wattage rating for it. Came from an automotive pcm. If that helps. Input voltage starts at 12v but I'm sure drops down to 3 and 5 etc.
    Thanks in advance. And sorry if this is ridiculous. I'm still a bit of a novice.
  • Answer selected by DubTechnic at 09-24-2024, 09:04 AM.
    harp
    • Jun 2022
    • 664
    • Planet Earth
    Tantalum capacitor... 47000000pF, 47uF/10V, positive + side is marked strap.
    K is tolerance class, not "kilo". Is should not be on 12v rail...
    • harp
      • Jun 2022
      • 664
      • Planet Earth
      • DubTechnic
        • Oct 2023
        Well lol I definately learned something. Thanks!
        • Crystaleyes
          • Sep 2021
          • 500
          • Brazil
          Well, the important thing is that you learnt. 😁
          • truclacicr
            • Apr 2019
            • 377
            • australia
            Those tantalum caps were notorious for catastrophic failures. I saw one catch fire like a match-head while I was testing a board in a minicomputer chassis. I have replaced hundreds of them during my working life.
            I would replace it with a safer, modern part.
            • ugamazing
              Assistance with identifying resistor value on 820-02918 A2992 board?
              by ugamazing
              Working on a 2023 M3 A2992 unit with 820-02918 board, and it uses a new USB-C power architecture, with rectangular controllers. I do not have a perfect-matching board, so have been repairing this one the old-fashioned way (slowly).
              I managed to blow-away a single resistor that I can't find and can't determine the value of. It connects to ground, so I went ahead and stuffed it with a 100K resistor in case it's a simple pull-up. But, I'm now having issues with that side of the board, and am curious if it's possibly related to this resistor! I have no schematics and no board view, so...
              09-06-2024, 08:33 AM
            • Ledian
              EDM-041 Schematics or help identifying a resistor?
              by Ledian
              Hello all! I am looking for the schematics for a EDM-041 PS5 Slim board? I'm currently repairing one and looks like the resistor right in front of the HDMI port was broken off, I don't know what the specs are for it though and was hoping the schem's would help with that! Or if someone knew what the model number for the resistor is that would be awesome as well!...
              12-16-2025, 01:33 PM
            • dutchgaucho
              Need help identifying resistor on Asus FA507RC DA0NJNMBAD0 schematic
              by dutchgaucho
              Hi colleagues,
              Looking for a schematic DA0NJNMBAD0 or the MP2845A 6-phase PWM controller.
              Working here on a DA0NJNMBAD0 rev D motherboard (Asus FA507RC) with liquid damage. Board has some tiny corrosion around the MP2845A controller and one resistor is missing. I need to know the value of the resistor, but no schematics are available. Not even for the MP chip or anything similar (this is a 6 phase PWM controller).
              On one side of the pad 20V is present. The other side connects to a cap and to pin 16 of the MP2845A. Resistor seems too small for VCC...
              11-09-2023, 11:27 AM
            • mrkmpn
              Help identifying resistor?
              by mrkmpn
              This resistor is on a small board the fan connects to in a Brother MFC L5900DW. The fan does not work, and when testing this resistor it shows no reading all the way from 4M ohms, down the a continuity test, so appears to have failed open.
              I've tried using a coupld of resistor calculators online, but I'm not sure which end is which on the resistor, and going both directions on the calculators I run into a value that doesn't have the correct color as an option.
              I, believe the colors are black gold violet black orange, but maybe I'm mistaken on one of th...
              01-19-2023, 11:09 AM
            • jinu_j
              by jinu_j
              Hi
              05-03-2025, 10:51 PM
