how can i find the watts of smd resistance
  • Xristakis795
    • Mar 2021
    • 162
    • Greece
    hi
    in a pcb circuit of welding machine
    i have three resistances smd 4.7 ohm burnt in series with std2nb80t4 also burnt
    with hole on the middle
    this mosfet is connected on primary of an transformer and it seems take dc voltage
    how can i calculate the watts of smd resistances to be sure i have choice the right value
    can i take from an older pcb smd resistance with the same size?
    is right ?
    • 31199
    Re: how can i find the watts of smd resistance
    you can only try to guess from the physical size
      • Jul 2011
      • 6065
      Or if there is a big enough pad you could external mount if you have any extra space in the enclosure ( just an idea )
      I have done this with surface mount LEDs before you do have to take your time doing and do not be in a hurry
      • jiroy
        • Jun 2016
        • 2416
        • Lebanon
        That's a long story and needs lot of efforts and spare time . Each company makes its catalogue and put its own specs ; sometimes they follow international standards and sometimes they create their own .
        To add on difficulties , many small business companies do not even bother issuing catalogues , while some big companies on the other hand , make their catalogues discrete and difficult to get .
        That's said , a respected catalogue would put the whole specs of a smd resistor , with even its diameters , L x L x H , including the pins diameters and kind of package , wattage , etc ..
        If you know which company made the resistor and do have its catalogue , you're a king , otherwise Only a good knowledge and a high level understanding of Electronics study , plus a long experience , can fill all these gaps ..
        • Xristakis795
          • Mar 2021
          • 162
          • Greece
          ok
          i want to thanks all for your useful advices
          • petehall347
            • Jan 2015
            • 4439
            if you replace with one same size and ohms then you can measure volts across it and use ohms law to see if its ok for the circuit
            • cind12
              GTX 1080 TI Gigabyte Aorus low resistance on vmem
              by cind12
              Hi guys, i was wondering, i've got 9Ohms on Vmem, one of the mosfet was shortet to ground, so i've desoldered hi and low mosfets nad still low res, then i removed all of the memory chips, and the resistance is still low, so did you had maybe a card with that low res on memories, and the card was working fine ?
              Removed the U1866Q and still without result, i dont have thermal cam so can't see where is hot spot when incjeting voltage.
              The resistance on core is ok 0.1Ohm ((Power 0.8V when on)
              Resistance on 12V 4K ohms (Power present when on)
              Resistance on 12V PEX 4K ohms...
              12-08-2023, 09:09 AM
            • defame5
              Rx 570 not giving image. Voltage measurements included.
              by defame5
              Hey all, I've been trying to fix a rx570 XFX XXX edition 8gb. Keep in mind I've no knowledge so I've been doing this solely using tutorials. Any help is appreciated.
              8pin connector led is open when pc boots, but nothing else happens (no image).
              Fans don't spin. Before the gpu broke completely, the fans used to spin at max rpm at the start and there were some wonky things happening in general, so it was probably defective already.
              Everything below is based on this video: https://youtu.be/2Yz7HfzggYc?si=UM8VOndmqJX1gfgJ
              PCIe pins are all ok. They have similar...
              12-21-2024, 05:27 PM
            • sect-sin
              HP PROBOOK 440 G6 Mosfet dying again and again
              by sect-sin
              Hello all,
              I have at least three notebooks with a very similar issue, and I do not know how to solve them, or at least diagnostically how to narrow down the error. I kindly like to ask you to help me with the HP Probook 440 G6 I have (DAX8JMB16E0 REV:E) now. I cant find any schematics or boardviews, they are available on paid sites only.
              Symptoms are: The notebook powers on, power and charging light lights up, there is fan spin, keyboard backlight works, CPU heats up, but no screen backlight, and no POST. I get 5 blinking error codes, though I am not sure about this as...
              12-09-2022, 05:03 PM
              by Vesko356
              08-11-2023, 03:27 AM
            • Nagy Daniel
              Lowest possible resistance on laptop motherboard rail - Guide Table request
              by Nagy Daniel
              Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
              I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
              I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
              So, I generated a table with AI so I can...
              03-04-2025, 08:24 AM
