Christmas lights - Something I am doing wrong
  • Francesc V.
    Tempus fugit
    • Nov 2022
    • 231
    • Catalonia
    Hi:
    i am trying to repair this Christmas lights from my parents. They are incandescent lights, no led lights.
    I have tried with 12V a 24V small lights that I found in Aliexpress but is obvious that are not the right ones. They last microseconds connected. Do they blow because of Amps or Volts?
    If I measure the Amps in the string........it's only 90mA. If I measure the Volts in the "green box"......it's between 0 and 190V, but doing a little bit of maths from the number of bulbs in series.......it's only about 6V per lamp.
    Could you please explain me "the basics" and recommend me the right bulbs?
    I never thought that changing a light bulb would be that difficult.
    Thank you in advance,
    Francesc.
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Re: Christmas lights - Something I am doing wrong
    Light bulbs burn out when they are expected to dissipate more watts than they can at the time. Watts is volts times amps.
    These tiny lamp Christmas light strings are usually run in series to reduce the number of connections needed and hence cheapen the light. Since they all are in series, they all need to pass the same current.
    However how much current will pass through depends on the characteristics of each bulb and the one that can pass the least current will end up getting the most voltage and if it can't deal with the volts times amps it will burn. So to keep things simple, the lamps all need to match, perfectly.
    Also note that most Christmas light strings' lamps are specially designed such that they sort of short out when they burn out so they appear to not light yet the rest of the lamps light up - until it is removed from the socket. So, watch out for that.
    BTW usually these strings are not rectified and are all AC lamps, so you will barely get any current reading in DC ampere modes as the average current will be zero in AC.
    • Francesc V.
      Tempus fugit
      • Nov 2022
      • 231
      • Catalonia
      Thank you for the feedback.
      Did same test, but now measuring AC Amps.......and results are quite different. There are 3.4A peaks there.
      Where the heck they sell these bulbs? Not able to find it anywhere. Anybody knows?
      Regards,
      Francesc.
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8701
        That's yet another issue with these bulbs, they peak for a very very short time a fairly high current. The bulb you get needs to survive this for that very short period but does not need to sustain it. I would imagine they would be no more than 300mA or so steady state.
        You should search for "Christmas Tree replacement bulbs" or something like that, don't try looking for generics as they may not be designed for these strings.
          • 31066
          back to basics.
          you have 3 wires so 2 or 3 strings of lamps - probably 2.
          how many lamps are there?
          • redwire
            • 3910
            Many of these chinese Christmas light controllers use SCR's to drive strings, each 1/2 wave. Some have a diode stashed inside the string as well. It depends on the patterns and colours. Three wires in the string could give a mux. of 4 possibilities.
            OP your multimeter might not be true-RMS and give wrong readings for current and voltage with 1/2-wave AC.
            Also, if there is no fuse in the controller box, I would not use these, too dangerous.
            • jiroy
              • Jun 2016
              • 2416
              • Lebanon
              From its end , when you get chinese , that what you get ...
              • Francesc V.
                Tempus fugit
                • Nov 2022
                • 231
                • Catalonia
                Yeap.........I think I will suggest my parents to throw them away and move it to "LED".
                • bialag
                  Lenovo ThinkPad E14 Gen 5 - Not Powering On - 3 Blinking Lights - 20 volts 0.224 amps
                  by bialag
                  I have a Lenovo here that does not want to power on. The motherboard appears to be clean, no sign of corrosion or obvious fried components. When plugged in, I see 3 blinking lights and then off. It would cycle the 3 blinking lights every 10 seconds or so as long as I have the adapter plugged in. Amp meter shows 20 volts, 0.224 amps, no fan spin, red light indicator near the charge port.
                  Thermal camera shows a section of the motherboard that is warmer than the rest. It is near the connector labels JRTC1 (CMOS battery). Diode measurement to ground for pin 1 = OL,...
                  03-25-2025, 05:56 PM
                • marce002
                  UT210E clamp meter amps measurements wrong
                  by marce002
                  Hello all
                  I have an UT210E clamp meter that went wrong doing amps measurements in continuity DC, it shows an offset of around 4/5A when first set, (lever at DC 10A) at 2A DC shows fixed 0L always......,,,,,, and also does not allow me to (zero button) , and as i said it is even worse in the 2A !! setting which do nothing and shows "0L"... when you can measure DV in 20A after achiving a ZERO with many RESET ZERO times , you can measure with a lot of offset..... eg 1A current is measured at around 650 mamps, . Similarly, a 4A current is shown at around 3A. |O
                  05-08-2020, 11:52 AM
                • Fisher8865
                  MacBook Pro A1990 stuck at 5v .592 amps
                  by Fisher8865
                  Hi guys
                  I have a MacBook Pro A1990 that takes 4.9 Volts and .592 to .615 amps on one port. The other port on the left side power cycles with about the same amount of volts an amps but quickly power cycles. The same thing happens on the other side but opposite. So on the left side the bottom port stays on and on the right side it's the top one. I think it is a CD3215 chip but I am not sure how to test it or where to get one. I have checked for voltage at ppbus_g3h and it has 12.6 V which is also on fuses f7000 and f7001 I checked pp1v2_s3 and it has 1.2 V then...
                  05-30-2024, 07:36 PM
                • caphair
                  Christmas lights string keep blowing
                  by caphair
                  I have a series-parallel incandescent style Christmas lights. The first string has gone out, I find a blown bulbs. The bulbs are rated at 2.5v .425w.
                  The only other bulbs I have around are rated at 2.5 .2w. I tried replacing the .4w bulbs with the .2w and when plugged in, lights flashed momentarily then went out again.
                  I now find that other .4w bulbs have blown and the .2w seems ok.
                  Could this have happened because of mixing the wattage? I figured the .2w replacement would have been brighter and the rest a little dimmer but still working.
                  12-22-2020, 07:25 AM
