can you fix XL4015 Step-Down CC/VC low voltage problem
  • harp
    • Jun 2022
    • 599
    • Planet Earth
    I notice some issue with handy XL4015 Step-Down DC Module with CV/CC Control, so I ask if that can be fix or lower/minimise effect...
    Its about that module cant hold CC when voltage is set less than 1.7v
    If you have that module, please confirm that.
    Here is visualisation table for fixed 100mA CC, measuring output in short :
    set 3.0v - 100mA/0.00v in short
    set 2.0v - 100mA/0.00v in short
    set 1.8v - 100mA/0.00v in short
    set 1.7v - 100mA/0.00v in short
    set 1.6v - 300mA/0.00v in short
    set 1.5v - 900mA/0.00v in short
    set 1.4v - 1.8A/0.45v in short
    In schematic pin #2 is going to voltage set trimpot, and near TL431 trimpot is for set current.
    I'll be glad if I can modified it for more reliable use, but dont know how, it will be awesome if it can work with low voltage and correctly hold current.
    • 31044
    Re: can you fix XL4015 Step-Down CC/VC low voltage problem
    just a thought,
    i'm probably a bit wrong but it looks like the overcurrent from the comparater goes through an led.
    maybe the led voltdrop is the issue at what ii frankly well below the voltage drop of an led!
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      There's a limit to what you can do with a circuit that "simple" ... probably running it at its limits when running it that low of a voltage.
      Oh and yes agreed you probably get a little better (but not perfect) behavior if it didn't use an LED there.
      • harp
        • Jun 2022
        • 599
        • Planet Earth
        I place jumper over led, and it is better, but not very reliable.
        The voltage fluctate about 0.2v, maybe depend on heating some component...
        With jumper over led and 100mA set, I can lower voltage to 1.40v, and get 107mA measured on short. But, if I lower a just one bit over, say 1.37v it "limit" randomly arround 300-700mA. On 1.5v it seems work ok...
        Ok, the fact is that with jumper is enhanced version
        I will replace led with 000 resistor.
        Thank you!
          • Jul 2011
          • 6040
          By the way this is a charging board and yes you can go down to almost 0 volts at different current rates I had one do this and it not suppose to work that way
          I did have one module that the current adjustment did not work correctly and I got weird results like that sometimes it go to 0 volts shorted and sometimes it would not I just stripped it for parts
          The only difference between the modules that have the meter module and ones that do not is the pot controls on the meter modules ones have the pot adjusters are on the side and ones pot adjusters are pointing up which makes it impossible to adjust the pot controls unless you remove the meter module and you can not mount the the meter module
          The higher the voltage/current ratio will depend what your voltage will be try another module and see if work correctly or not you do not have to get it with the meter module
          Here is the same buck converter that uses the red circuit board the black circuit board is also interchangeable as well
          https://www.ebay.com/itm/13260658909...Bk9SR7TZo83UYQ
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8701
            err... a diode still needs to be there, simply shorting the LED out will cause problems - replace with a regular diode, hence it would only be a little better. Even a red LED probably better than a green one there if that's what it was.
            oh...btw... shorting it out will be the best you can do with what you have, anyway. however you should note you cv mode is broken with the LED shorted out.
            • DynaxSC
              Extreme High Current & Low Voltage Short Killer ??
              by DynaxSC
              Hi Folks
              I'm looking for a extreme high current short killer solution for a reasonable cost.
              I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
              After taking off the socket, the shorts dissappear again.
              The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
              10-15-2024, 10:13 AM
            • Stephen
              MacBook Pro 14" A2442 Short on PPBUS_AON but no short present when injecting voltage!
              by Stephen
              I check PPBUS_AON and there is a short present on the line, the computer shows a short when testing for short to ground, so when I inject voltage into the line, I get 0AMPS so no short is showing up. I have replaced a blown cap on this board that exploded and tested for the short and it is now removed. Any suggestions? I tested voltage at the line when the fuses are connected and I am getting 1.2 Volts at the line.
              02-06-2025, 12:03 PM
            • Victor Moreira Silva
              Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
              by Victor Moreira Silva
              I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
              Well, my decice specs are the following:
              Model: Acer Nitro 5 AN517-54-55T5
              CPU: Intel Core i5-11400H
              GPU: NVIDIA GeForce GTX 1650
              Motherboard: GH51G LA-L181P Rev:1c
              The symptom:
              When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
              05-26-2025, 10:49 AM
            • aaronkatrini
              Help me find the short circuit on this WORKING Nvidia GTX1650
              by aaronkatrini
              Recently picked up this GTX1650 at a local flea market for a low price and wanted to use it on my secondary PC. I first tested the card and saw the fan spin for a split second and then nothing. Immediately I thought of a short circuit. Disassembled and found a shorted SMD capacitor, injected voltage into it (1V/4A) and two Mosfets got hot immediately (QN3103 & QN3107). Desoldered these Mosfets and the card turned back to life.
              Bought replacements from Aliexpress and replaced them afterwards. Tried the card but still the saw the fan spin for a split second...
              04-18-2024, 03:15 PM
            • Geeker007
              9th Gen Dell Optiplex Micro PC motherboard repair: Short Circuit?
              by Geeker007
              Hi All, I have a 9th Gen Dell Optiplex micro PC motherboard which doesn't power on. When I connect the motherboard with power adapter, it goes into safe mode and turns off. So from info I have gathered online, it looks like there is a short circuit on the motherboard. So can you guys help me with figuring out the issue?
              I am new to electronics repair, so my queries could be naive but I am ready to learn.
              So I have a multimeter and a solder with me. But I can try to get a variable voltage power supply with a thermal camera as well. From what I seen online, best way is...
              01-28-2025, 03:31 PM
