Identify a resistor
  • Gatolina
    • Jan 2023
    • 10
    • Brasil
    Identify a resistor
    Hi! This is probably a dumb question but I can't really figure out the value of this resistor.
    Can anyone help?
    Thanks!
  • R_J
    • 9608
    Re: Identify a resistor
    0.47Ω non-inductive
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8703
      0.47Ω, ±5%
      One key is that the metallic bands (silver/gold) are not significant digit colors and since there are at least two significant digits, it's not the black side that goes first.
      • Gatolina
        • Jan 2023
        • 10
        • Brasil
        Thank you so much!
        • adamok7
          • Feb 2023
          • 20
          • Kazakhstan
          0.46Ω, ±5%
          Flame-retardant resistor type "Anti-pulse".
          • Gatolina
            • Jan 2023
            • 10
            • Brasil
            Originally posted by eccerr0r
            0.47Ω, ±5%
            Thank you for the reply.
            What does this black stripe means?
            • R_J
              • 9608
              In most cases the last black band indicates non-inductive
              If it was White, it would be Fusible
              In some cases it is Temperature Coefficient (Black= 250ppm/K)
              • Gatolina
                • Jan 2023
                • 10
                • Brasil
                Thank you!!
                • gica69
                  Need help to identify and to locate a 0.33 ohms fusible resistor for power supply
                  by gica69
                  I have a quad charger that is split into 4 separate sections and one section doesn’t charge anymore. I have located what I think is a thermistor and on the shrink tube it says 125 degrees C. I cut the shrink tube and it's a 33 ohms resistor. It measures a little less than 1/2 inch in length. I am including pictures of it. Please help me identify it. So, it should test at 0.4ohms and probably go up in resistance with the rise in temp. On the board it clearly says R for resistor. But it has to be a special one.
                  Resistor shows orange range silver gold and green lines.
                  Thanks in adv...
                  07-21-2025, 09:49 PM
                • jinu_j
                  by jinu_j
                  Hi
                  05-03-2025, 10:51 PM
                • mikey5791
                  Need help to replace burned resistor in 350w atx psu
                  by mikey5791
                  Hi to all forum members,
                  Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
                  The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
                  Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
                  Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
                  12-26-2024, 04:55 AM
                • MidnightRoller
                  Can a resistor lose resistance after hot air?
                  by MidnightRoller
                  I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
                  I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
                  02-02-2022, 11:46 PM
                • sikocan
                  Identify resistor R802 PS4 Pro PSU
                  by sikocan
                  Hi team, can you help identify value of this resistor. From a PS4 Pro. PCB board model: N300A004L. Location of resistor is R802 as pictured....
                  11-01-2022, 07:33 PM
