Electric blanket resistor
  • cliffpage
    • May 2009
    • 6
    Electric blanket, can't find name on it anywhere, think label came off years ago. Double size, some years ago one side stopped working, I found a resistor had failed in the controller. As I don't use my side of the electric blanket I turned it round so my wife could use the good side. Now the resistor has gone in that side too. Well I think it is a resistor. The mains live wire goes on one end of this component and then the other end goes to the workings of the controller. pic of the component att'd . stamped in the metal is F400H250V . I don't know what F400H means. 250V presumably means 250 volts (I am in the UK). Can anyone tell me this is a resistor for certain? from the colours it is 400 ohms with 2% tolerance, do you agree? it is ceramic with a wire through it with sand in. It does not solder in , it pushes in. I can't find any resistors like this , that don't solder in. So perhaps it's not a resistor. A fuse? but the coloured stripes don't suggest a fuse and it does not mention Amps on it. Any helpful comments please.
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8706
    Re: Electric blanket resistor
    That looks like a standard 5mm x 20mm fuse size and really is a fuse, what's the specific circuit that this protects, the whole heater or just the controller? How many watt heater is it?
    A 4A fuse is possible I suppose but this is unusual though not unlikely. After all, diodes and capacitors have been color bar coded in the past (along with numeric codes).
    • R_J
      • 9610
      It is a 400ma Fast blow fuse. Littlefuse 5x20mm series 0216
      • cliffpage
        • May 2009
        • 6
        Hi, thanks for response, I have now included a pic of inside of controller. the component fits in the holders either side of the white mains cable at bottom. quite a primitive design. one time it stopped working because the component came out of the holder at one end, which could happen just from knocking the controller about I think. I don't know much about this kind of stuff. I assumed all colour banded stuff is always a resistor. I am learning. Thanks
        • cliffpage
          • May 2009
          • 6
          pic, mains cable is at right end, the pic turned 90 degrees when i uploaded it. no idea of wattage, no labels anywhere. think label came off years ago
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8706
            400mA indeed makes more sense for F400, but if it was powering the heater, that wouldn't, though maybe a 50W blanket isn't that useless? If it's like a 50W heater then yes 0.4A fuse is correct, especially after seeing those 1N400x diodes...
              • 31267
              it's about 100w at 240v
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8706
                you dont run fuses up to the limit...
                • redwire
                  • 3912
                  No offense but just buy a new electric blanket. They don't last forever, they get washed and moved a lot and are a major cause of fire, which led to the legislation requiring arc fault circuit breakers for bedroom circuits.
                  I recommend buying a new one because the pictures look like an old European design and taking the controls apart has mangled the plastic.
                  If the fuse is blowing there is an overload happening somewhere which is likely to be the resistance wire loop.
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8706
                    Unfortunately I'd have to agree with redwire on this. It's odd that a "dumb" blanket blew a fuse unless you knew you did something dumb to it (unsure what though...). Likely something unsafe has happened to it and the new fuse you put in will also blow shortly.
                    • CG2
                      • Nov 2022
                      • 37
                      I can't tell how that particular circuit works, but I took a broken controller apart a couple of years ago out of curiosity. power came in via a thermal fuse which was glued to a high value resistor wired in parallel to the main heating wire. In normal use little current passes through that resistor, but if the heater breaks, it soaks up everything, overheats and pops the thermal fuse. Bin it and buy a new one.
                      50-60 watts per side is common for an electric underblanket. It's surprising how hot that makes a bed when there's a duvet insulating it above. And run for an hour uses less electricity than boiling the kettle for a hot water bottle.
                      • magneh
                        Is this some kind of fuse resistor ?
                        by magneh
                        Hello guys
                        Taking a look at some KNX domotic modules that were toasted due to some kind of electrical failure, I found out 2 weird looking resistors.
                        Seem to me like some kind of fuse resistor?
                        After diggin a bit seems like a fuse wirewound resistor wafer or whatever that is
                        They are very toasted but I think the 5 band colours are RED GOLD BLACK ORANGE ORANGE or the opposite, not sure which is the first band.
                        The red band is larger than the 4 others, but I dont have much experience with these components.
                        Also one of the orange...
                        02-10-2025, 07:54 AM
                      • ttmi100x
                        HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
                        by ttmi100x
                        Greetings everyone,
                        I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
                        The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
                        Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
                        Upon closer inspection...
                        07-31-2024, 06:36 PM
                      • corrize
                        Replacing resistor fuse in Sony DV charger
                        by corrize
                        Hello, I have 2 old chargers for Sony DV, and I found the same resistor fuse dead. Fuse is a crossing component : 0,47 Ohms (0,125W deduced because the lenght is 3mm). But I can’t find the same for buy.
                        So, I want to replace by another like 0 Ohms, 1 Ohms 0,125W,
                        It is the same please ? I guess it’s the same, the only change should be the time to burn ? Thanks...
                        06-30-2025, 06:59 PM
                      • corrize
                        A funny fuse story – Lumix LX100 II
                        by corrize
                        Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                        I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                        The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                        There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                        And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                        10-19-2023, 09:58 AM
                        Surface Mount Fuses Fundamentals Datasheet
                        TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                        TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                        10-07-2024, 06:07 AM
