Faulty multimeter + can you identify this component inside?
  • Agent24
    I see dead caps
    • Oct 2007
    • 4951
    • New Zealand
    I have recently discovered that the mA range for my multimeter doesn't work, and before you ask: Yes I have checked the fuse and the fuse is fine
    It has two settings, one for 200uA to 200mA and one for 10A (both DC)
    Connecting up a circuit which should be drawing 100mA I get a 0.10 reading on the 10A DC range which looks all OK.
    However on the 200mA range where I should get 100 I get nothing.
    It's not just the meter isn't reading the current, the current doesn't appear to be flowing at all. A simple circuit with an LED lights up on the working 10A range but on the other ranges the LED doesn't light and the display shows nothing.
    When I opened it up I noticed a strange component I don't recognise. It's soldered where the silkscreen shows a resistor symbol but I don't think it's a resistor.
    I have attached photos... Its the thing marked "75S" which looks like a cross between a Tantalum and a Disc Ceramic
    -David VanHorn
    • 31007
    Re: Faulty multimeter + can you identify this component inside?
    that looks like a self-resetting polyfuse.
    • Agent24
      I see dead caps
      • Oct 2007
      • 4951
      • New Zealand
      Interesting, I had not thought of a polyfuse. But I thought polyfuses looked like Disc Ceramics rather than this one? Besides, the meter is quite cheap and uses a standard fuse already.
      In any case I think I have found out why the meter isn't working. When I say I 'checked the fuse' I didn't actually test it, just looked at it.
      Turns out that while the fuse wire appears intact, the fuse is actually open circuit. Maybe it broke when the meter was dropped? (happened a few times)
      -David VanHorn
      • smason
        • 1652
        I learned a long time ago not to trust a visual check of a fuse.
        I won a $40.00 bet with a friend who insisted a standard glass fuse was fine. I tested with a meter, and it was open. If you really looked hard, you could see under the metal end cap ot was blown.
        • Agent24
          I see dead caps
          • Oct 2007
          • 4951
          • New Zealand
          I guess I learned that just now But I'm kicking myself because I know better and I know that I should have checked it properly anyway
          Open circuit rectifiers and switching transistors look fine from the outside too...
          -David VanHorn
          • Krankshaft
            • Jan 2007
            • 2328
            The filament probably broke where it connects to one of the end tubes.
            I once had a fuse that still passed current but was blown the filament vaporized but the vaporized metal still made contact across the end caps.
            It was a slow blow so I guess it could have also vaporized along the ceramic center insulator slow blow filaments are wound around.
            The fuse looked black and silver inside.
            I caused the blown fuse by accidentally shorting VCC and ground. It was a cheap Kinyo 5.1 sound system they actually used a bunch of diodes in forward configuration to step down the voltage to the amp ICs. I jumped one of these diodes during testing.
            The result was low supply voltage from the transformer since it couldn't pass full current the voltage dropped.
            It caused hours of headbanging for me since the fuse was soldered inline with a transformer secondary lead and completely heat shrunk over. I thought there was no fuse the amp was so cheap. Luckily eventually I found it.
            It's funny how one of the simplest of electronic components can cause so much trouble.
              • 31007
              it should have been a sand-filled ceramic fuse in a meter btw.
              cheap bastards!
              • Agent24
                I see dead caps
                • Oct 2007
                • 4951
                • New Zealand
                cheap bastards!
                It's a cheap meter, only $20 from DSE...
                What is the advantage of a ceramic type? Should I get a ceramic one for the replacement?
                -David VanHorn
                  • 31007
                  ceramic fuse wont explode into a mess of glass bits if something goes very bad!
                  • Flaku_34
                    Acer Nitro XV273 and Predator XB273, look inside and disassembly guide.
                    by Flaku_34
                    Introduction:
                    Hello everyone, this topic is more of a knowledge sharing and look inside type of post, but for someone working on this model of display it might be useful. Recently I bought Acer Nitro XV273 XB MIIPRZX with busted electronic, but screen was intact, price was incredibly low, so I took a gamble and bought the unit and try to fix it. As I dug inside, I found out that my motherboard was not responding, although all voltages seemed fine. I wasn't able to find any reliable information about this monitor on the web (only some pictures of motherboards from Ebay). By some research...
                    04-18-2024, 12:47 PM
                  • PanicMechanic
                    Extech EX330 multimeter current range offset fault
                    by PanicMechanic
                    My multimeter has developed this fault, a few months ago. I tried to fix it, but had no success.
                    The fault is that on the current ranges it never shows 0. Does not matter if the probes are open or shorted.
                    As you can see from the pics, the offser is the same (just multiplied for other rages):
                    -4.9 uA
                    -0.49 mA
                    -0.49 A
                    I don't know what exactlly caused the fault.
                    The meter had a battery leak before I noticed the fault, but I am not sure if the fault was present before that happened. I just did not noticed. The battery leaked...
                    05-11-2021, 11:13 PM
                  • Byte_76
                    Faulty memory slot on Tekram Slot 1 motherboard
                    by Byte_76
                    I have a Tekram P6PRO-A5 Rev. 1.01 which has an issue with one of the memory slots and with the floppy port.
                    When a memory module is installed into the slot which is closest to the north bridge, the board will beep and won't post. The same memory module works in the two remaining slots.
                    Also, the floppy drive does not work regardless of bios settings.
                    Please help me to identify the possible cause of the faulty memory slot and the floppy drive port as well.
                    I have examined the board under my digital microscope and did not find any broken traces....
                    04-12-2025, 06:58 AM
                  • dj8452000
                    How To Test a P-channel Trench Mosfet Using A Multimeter In Diode Mode
                    by dj8452000
                    I am new to electronics and I'm understanding most of what I'm reading but I have a mosfet on my board that I've identified as a P-channel Trench Mosfet. I haven't a clue how to test this and what I should expect to see with the multimeter probes. I am hoping someone with years more experience than myself can help me understand how to use a multimeter to read this. Please look at the drawing I have attached to this and can you try to explain to me what I should be doing with my multimeter in diode mode and what results I should expect from a good mosfet?...
                    02-18-2025, 08:28 AM
                  • jimmiscom
                    Pegatron D15D Rev 2.1 faulty smd - can be identify ?
                    by jimmiscom
                    hello to all.
                    can anyone knows more details from the smd of the photo.
                    i search on the internet with the numbers shown on the component but i didnt find anything. it burned and i want to replace it.
                    thank you...
                    11-28-2021, 03:53 AM
